I want to build imx-xen with early_printk logs, and how to enable it, please?
thanks
Solved! Go to Solution.
Which version of BSP are you using?
Do you mean you enable it and then got failed? any error message?
If possible, please tell me the steps what you have done. So, I can try it on my side.
Jimmy
Jimmy
Thanks, Jimmy
I got it via openning CONFIG_DEBUG options
