How to enable Digital mic in var-som-mx6 board
1,265件の閲覧回数
ee150002009
VAR-SOM-MX6 DMic - Variscite Wiki
I already read this document it is given that in alsamixer you have to set oversampling rate but i can not  find anything in alsamixer that can set oversampling rate. I'm using 4.9.11 kernel version.
2 返答(返信)
1,175件の閲覧回数
ee150002009
Hi Bio_TICFS,
   Sorry for the late reply I want to use both digital as well as line in microphone but when i apply that patch only digital mic is working and line is not working. How can i use both ?
1,175件の閲覧回数
Bio_TICFSL
Hello Ayush,
Alsamixer is always resampling all streams to default. Proper file for change this is ~/.asoundrc
http://www.alsa-project.org/main/index.php/Asoundrc
You can check result here: cat /proc/asound/card0/pcm0p/sub0/hw_params.
