How can I enable DMA capabilities for the CAN driver on the IMX8MPlus EVK board (Cortex-A53) running Linux? Could you please provide suggestions?
I am based on i.MX8QMPlus(i.MX8MPlus)- Target - EVK - based on Linux with CAN driver Enabled ( I am compiling the same with yocto build environment).
Now, i have to enable the DMA capabilities for CAN driver.
Could you please provide suggestions from where to start and what modifications are needed?
- RR
