How to enable DMA Capabilities for CAN Driver for IMX8MPlus EVK - based on Linux
2,068 次查看
radhak4x
How can I enable DMA capabilities for the CAN driver on the IMX8MPlus EVK board (Cortex-A53) running Linux? Could you please provide suggestions?
I am based on i.MX8QMPlus(i.MX8MPlus)- Target - EVK - based on Linux with CAN driver Enabled ( I am compiling the same with yocto build environment).
Now, i have to enable the DMA capabilities for CAN driver.
Could you please provide suggestions from where to start and what modifications are needed?
- RR
标记 (3)
7 回复数
1,776 次查看
radhak4x
Can someone please suggest ..!
2,062 次查看
rd24
I am also looking for a solution for enabling DMA in CAN driver for iMX8. Please help.
2,000 次查看
Bio_TICFSL
There is no DMA CAN for cortex M4. you can find the Flexcan code driver explanation in the Linux Reference manual.
https://www.nxp.com/docs/en/reference-manual/IMX_REFERENCE_MANUAL.pdf
regards
1,548 次查看
radhak4x
Which Section you were referring to ? could you please elaborate ?
1,979 次查看
radhak4x
Thanks for the Quick response, however i am based on IMX8MPlus EVK board (Cortex-A53).
1,967 次查看
radhak4x
Could you please elaborate on the cortex A 53 processor ? Thanks in advance
1,698 次查看
radhak4x
Can someone please elaborate the case.
