How to enable CRC image check at bootup for MIMXRT685?
841 次查看
pcpro1789
To enable CRC image check at bootup for MIMXRT685 is it just a matter of following the CRC example in the SDK or is there something more integrated?
标记 (3)
2 回复数
802 次查看
Bio_TICFSL
You can check the checksum of the CRC but will have to work with the example demo in the SDK.
https://mcuoneclipse.com/2018/03/05/tutorial-crc32-checksum-with-the-kboot-bootloader/
768 次查看
pcpro1789
Is there a bootloader configuration tool for the MIMXRT685, similar to the Kinetis Bootloader Configuration utilty?
