Thanks!
I have compiled & flashed automotive android 11 in i.MX8QM MEK. Image is working fine for me & could test the CAN as well using PCAN USB. Now i want to test the HVAC feature, it should send the data to PCAN via IVehicle hal. When i explore the Vehicle hal source code, found that it uses emulator as default. I couldn't see Vehicle hal interface with CAN network.
Can you please guide me how to send or receive CAN data through Vehicle hal? Looking forward to hear from you asap.
Thanks & Regards,
Vipul Kumar
