I am using i.MX7ULP now and I want to enable A7 LDO.
I got some clues in 36.2.3.1 of IMX7ULPRMV2_RevC.pdf.
However, I don't know how to modify the parameter (please refer to the following image) of eFuse.
As I know, once the parameter be enabled, M4 will set PMC_0_CTRL[LDOEN] bit and the current of A7 domain will be from the internal LDO. Isn't it?
In addition, I can't find "fuse map" in the document as well.
Could you help me, please?
