Hi peng
as for loading apk with adb help one can look at
Using ADB with your Sabre Board
http://2012ftf.ccidnet.com/pdf/0066.pdf
Hi Peng
Following solutions to install apk on SDB board.
You can copy apk using USB driver. Or using ADB connection.
you can install your application.
Saurabh
Hi Saurabh,
Copying apk using USB driver ?
Hi Peng,
It typo error,
Copy you apk to USB disk, and connect USB disk to SDB boad.
And install apk.
Saurabh
