How to download code to QSPI flash and boot from QSPI flash
已解决
跳至解决方案
1,694 次查看
liqi_wu
hi,
current I use IMX6ULL EVK to do development without any OS(like linux, RTOS and so on).
I use IAR build out hello world project with ram.icf. And then I use JTAG to download hello world.bin to QSPI flash. But it can not work when I config EVK to boot from QSPI.
my user story:
1. use IMX6ULL EVK to do development without linux;
2. build official SDK project with IAR;
3. download code to QSPI flash;
4. boot from QSPI flash and run code in DDR;
How can I do?
By the way, I want to use MFG tool to download code to QSPI flash refer to <Getting Started with MCUXpresso
SDK for i.MX 6ULL Derivatives>. But it failed to download. It always reset cause by POR.
another question, Is the Boot ROM code can be programed?
标签 (2)
标记 (2)
1 解答
1,531 次查看
liqi_wu
The MFG Tool download fail issue is fixed. current I can use MFG Tool to download hello world project to IMX6ULL EVK QSPI flash and boot from it.
在原帖中查看解决方案
1 回复
1,532 次查看
liqi_wu
