How to do the communication between the A core and M core on the i.MX8QM?
1,015件の閲覧回数
charleshuang
Senior Contributor II
Hi NXP
Do you have SOP about "How to do the communication between the A core and M core on the i.MX8QM" ?
3 返答(返信)
987件の閲覧回数
Zhiming_Liu
Please refer 2.8 Remote Processor Messaging in this manual: https://www.nxp.com.cn/docs/en/reference-manual/IMX_REFERENCE_MANUAL.pdf
The M core sdk examples are here: https://github.com/nxp-mcuxpresso/mcux-sdk-examples/tree/main/mekmimx8qm/multicore_examples
To load it , you can refer 4.7.4 Running the Arm Cortex-M4/7/33 image in this guide:
https://www.nxp.com.cn/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
Zhiming
958件の閲覧回数
charleshuang
Hi @Zhiming_Liu
We are trying to run the test M40.bin, which will display the PRMSG message on the M40.
We are trying to run "pingpong" and load the "imx_rpmsg_pingpong",  the device cannot get any message from M core and A core.
Have you tested the 'communication between the A core and M core' image for the i.MX8MQ demo board?
Please share it with me, and we will test it.
932件の閲覧回数
Zhiming_Liu
Are you using imx8qm-mek-rpmsg.dtb?
For the tty driver, you need install imx_rpmsg_tty.ko in /lib/modules, the you can use /dev/ttyRPMSG with echo "MESSAGE" > /dev/ttyRPMSG*.
Zhiming
