How to display dsi to dual lvds using sn65dsi84?
已解决
跳至解决方案
1,456 次查看
hansung_jung
I would like to use sn65dsi84 to display mipi-dsi as dual-link lvds.
However, only imx8m reference can be found.
My processor is imx8qxp, using custom bsp in linux kernel 5.15.71.
I found some imx8m references, but I don't know how to migrate to imx8qxp.
For example, in the sample dts below, I don't know what the replacement for &mipi_dsi_bridge is.
&mipi_dsi_bridge {
status = "okay";
  port@2 {
    mipi_dsi_bridge_out: endpoint {
      remote-endpoint = <&sn65dsi84_in>;
Can I find imx8qxp reference using sn65dsi84?
Thanks in advance.
1 解答
1,432 次查看
Zhiming_Liu
Hi @hansung_jung
Please find arch/arm64/boot/dts/freescale/imx8x-mek.dtsi and refer adv7535 node to port your sn65dsi84 node.
&mipi0_dsi_host {
	status = "okay";
	ports {
		port@1 {
			reg = <1>;
			mipi0_adv_out: endpoint {
				remote-endpoint = <&adv7535_0_in>;
在原帖中查看解决方案
1 回复
1,433 次查看
Zhiming_Liu
Hi @hansung_jung
&mipi0_dsi_host {
	status = "okay";
	ports {
		port@1 {
			reg = <1>;
