How to disable ethanviv driver and enable galcore vivante driver
1,230件の閲覧回数
ravicalm
How to disable ethanviv driver and enable galcore vivante driver could you please help me
2 返答(返信)
1,203件の閲覧回数
Bio_TICFSL
The BSP uses galcore GPU driver by default available at /drivers/mxc/gpu-viv.
Additionally one can add the below line in local.conf
IMAGE_INSTALL += " kernel-module-imx-gpu-viv "
1,193件の閲覧回数
ravicalm
it is not enabled that's why I have posted so many questions on this with bsp version. please tell me what device tree will support and with corresponding configuration which helps me to enable galcore
