How to disable TZASC module in i.MX6ULL?
rahuldhobi
I have enable TZASC module by setting fuses in bootloader. I have enabled it by using following command.
fuse prog 0 6 0x10000000
Now I want to disable TZASC. How to disable it using fuse?
Hi Rahul
unfortunately burning fuse is irreversible operation and fuse can not be
restored to original state.
