How to debug the cortex-m4 kernel using j-link on the i.MX 8M Mini EVK
4,381件の閲覧回数
bigtruck
dears:
How to debug the cortex-m4 kernel using j-link on the i.MX 8M Mini EVK.
I had a problem debugging on the IAR.
The IAR version I used was 8.40.
The error is shown below
The following is my engineering configuration
I used the j-link Commander program to connect to the target board with the following information
tks!
4,269件の閲覧回数
Hi ryan
recommended to use J-Link PLUS debug probe as described in sect.4.2
attached Getting Started with MCUXpresso SDK for i.MX 8M Mini.pdf
Check that appropriate j-link firmware used : https://www.segger.com/downloads/jlink
use "IAR and Segger tool patch to support MCUXpresso SDK for i.MX 8 devices GA"
https://www.nxp.com/webapp/Download?colCode=SDK_2.7_MX8_GA_Patch&appType=license
Note, there is for option FreeRTOS task aware debugger for GDB, please look at
sect.6.4 FreeRTOS aware debugger plugin Getting Started with MCUXpresso SDK and FreeRTOS OS.pdf
4,270件の閲覧回数
Hi ryan
4,269件の閲覧回数
bigtruck
Thank you very much!
I solved my problem by using the software package "IAR and Segger tool patch to support MCUXpresso SDK for i.mx 8 devices GA"
