How to cross-compile OpencryptoKi for yocto linux on imx6sl board?
ashishsbn
I am trying to cross compile opencryptoki for imx6sl board which is running yocto linux.
The Opencrypto project has numerous dirs, subdirs and makefiles.
I am using arm-poky-linux-gnueabi-gcc toolchain and setting path as:
export ARCH=arm
export PATH=$PATH:/home/ashish/Desktop/SDK/stct_iog1/source/yocto/build/tmp/sysroots/x86_64-linux/usr/bin/cortexa9hf-vfp-neon-poky-linux-gnueabi
export CROSS_COMPILE=arm-poky-linux-gnueabi-
How can i set flags to use existing makefiles.
Any ideas ,  already cross compiled opencrypto for another target are welcome.
Opencrypto makefile from top directory looks like this:
if ENABLE_TESTCASES
TESTDIR = testcases
endif
if ENABLE_LIBRARY
MISCDIR = misc
endif
if ENABLE_DAEMON
MISCDIR = misc
endif
SUBDIRS = usr man $(MISCDIR) $(TESTDIR)
PLease help here.
Ashish S
Original Attachment has been moved to: opencryptoki-master.zip
Labels (4)
Bio_TICFSL
OpencryptoKi  is part of the meta-security layer in the Yocto community bsp, please check it:
OpenEmbedded Layer Index - recipes
meta-security - Security tools for Internet connected devices
regards
