Dear Forum,
I am facing some issue bringing up an Ethernet switch and I would like your confirmation about the correct property configure the Ethernet PHY/switch in order to rule out the potential cause.
Concretely, I saw that in most of the case, reset-gpios property is used within the ethphy node (which is working according to my experience with iMX8MP based board) :
$ ag "reset-gpios" arch/arm64/ | grep imx8m
arch/arm64/boot/dts/freescale/imx8mq-thor96.dts:136: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk-pcie1-m2.dts:19: reset-gpios = <&gpio3 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mn-bsh-smm-s2pro.dts:65: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-emcon.dtsi:89: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-phanbell.dts:276: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-var-som.dtsi:122: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-librem5-devkit.dts:545: reset-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-librem5-devkit.dts:889: reset-gpios = <&gpio3 13 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-prt8mm.dts:110: reset-gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mp-evk-usdhc1-m2.dts:24: reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-data-modul-edm-sbc.dts:183: reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-data-modul-edm-sbc.dts:409: reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-nitrogen.dts:141: reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-nitrogen.dts:234: reset-gpios = <&max7323 0 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-kontron-bl-osm-s.dts:133: reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk-dpdk.dts:9: /delete-property/ reset-gpios;
arch/arm64/boot/dts/freescale/imx8mp-msc-sm2s.dtsi:164: reset-gpios = <&tca6424 16 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-msc-sm2s.dtsi:191: reset-gpios = <&tca6424 17 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-adsai.dtsi:277: reset-gpios = <&pca6416 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-adsai.dtsi:287: reset-gpios = <&pca6416 5 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-beacon-som.dtsi:16: reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk-rpmsg.dts:174: reset-gpios = <&gpio4 0 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-evk.dtsi:208: reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-evk.dtsi:338: reset-gpios = <&pca6416 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-evk.dtsi:348: reset-gpios = <&pca6416 5 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-evk.dtsi:366: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-kontron-bl.dts:128: reset-gpios = <&gpio4 27 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-dhcom-pdk2.dts:133: reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-phycore-som.dtsi:91: reset-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-zii-ultra-rmb3.dts:97: reset-gpios = <&gpio3 4 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mn-var-som-symphony.dts:60: reset-gpios = <&pca9534 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-evk-lcdif-rm67191.dts:48: reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk-os08a20-ov5640.dts:39: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-librem5.dtsi:270: reset-gpios = <&gpio3 25 GPIO_ACTIVE_HIGH>,
arch/arm64/boot/dts/freescale/imx8mq-librem5.dtsi:1048: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-librem5.dtsi:1174: reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk-basler-ov5640.dts:61: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-nitrogen-som.dtsi:72: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-nitrogen-som.dtsi:90: reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk-dcss-rm67191.dts:62: reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk.dts:319: reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk.dts:408: reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk.dts:557: reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk.dts:578: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-evk.dts:692: reset-gpios = <&gpio4 0 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-ab2.dtsi:18: reset-gpios = <&pca6416 4 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-ab2.dtsi:152: reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-ab2.dtsi:246: reset-gpios = <&pca6416 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-bsh-smm-s2-common.dtsi:30: reset-gpios = <&gpio4 27 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-bsh-smm-s2-common.dtsi:72: reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk-usdhc2-m2.dts:10: reset-gpios = <&gpio3 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-evk-usdhc2-m2.dts:17: reset-gpios = <&gpio2 19 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-dhcom-som.dtsi:107: reset-gpios = <&gpio3 20 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-dhcom-som.dtsi:123: reset-gpios = <&gpio3 20 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-dhcom-som.dtsi:153: reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-dhcom-som.dtsi:499: reset-gpios = <&gpio1 13 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk.dts:27: reset-gpios = <&gpio3 5 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk.dts:307: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk.dts:555: reset-gpios = <&gpio3 17 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-evk.dts:562: reset-gpios = <&gpio3 16 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-phyboard-polis-rdk.dts:78: reset-gpios = <&gpio2 7 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-sr-som.dtsi:33: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-verdin.dtsi:606: reset-gpios = <&gpio3 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-verdin.dtsi:622: reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-icore-mx8mm.dtsi:41: reset-gpios = <&gpio3 7 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-var-som-symphony.dts:70: reset-gpios = <&pca9534 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mm-beacon-baseboard.dtsi:156: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-beacon-baseboard.dtsi:300: reset-gpios = <&pca6416_1 7 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-zii-ultra.dtsi:29: reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-zii-ultra.dtsi:415: reset-gpios = <&gpio3 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-zii-ultra.dtsi:450: reset-gpios = <&gpio3 25 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-adsai.dts:164: reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-verdin.dtsi:646: reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-verdin.dtsi:707: reset-gpios = <&gpio4 28 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-verdin.dtsi:723: reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-wevk.dts:12: reset-gpios = <&gpio3 5 GPIO_ACTIVE_HIGH>;
arch/arm64/boot/dts/freescale/imx8mq-wevk.dts:48: reset-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mq-kontron-pitx-imx8m.dts:92: reset-gpios = <&gpio1 11 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-ab2.dts:39: reset-gpios = <&pca6416 4 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-ab2.dts:394: reset-gpios = <&pca6416 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-beacon-som.dtsi:17: reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-beacon-som.dtsi:78: phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-tqma8mpql-mba8mpxl.dts:220: reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mp-tqma8mpql-mba8mpxl.dts:250: reset-gpios = <&gpio4 0 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-ab2.dtsi:16: reset-gpios = <&pca6416 4 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-ab2.dtsi:127: reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-ab2.dtsi:219: reset-gpios = <&pca6416 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mn-var-som.dtsi:104: reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-evk.dtsi:283: reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-evk.dtsi:498: reset-gpios = <&pca6416 3 GPIO_ACTIVE_LOW>;
arch/arm64/boot/dts/freescale/imx8mm-evk.dtsi:507: reset-gpios = <&pca6416 5 GPIO_ACTIVE_LOW>;
However, phy-reset-gpios is also used within the FEC node :
mainly for IMX6 :
$ ag "reset-gpios" arch/arm/ | grep imx6
arch/arm/boot/dts/imx6ull-jozacp.dts:111: reset-gpios = <&gpio4 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ull-jozacp.dts:141: reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw51xx.dtsi:131: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-kp.dtsi:191: reset-gpios = <&gpio5 2 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6q-h100.dts:196: reset-gpios = <&gpio6 15 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-wandboard.dtsi:140: reset-gpios = <&gpio4 14 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-wandboard.dtsi:303: phy-reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-ds.dtsi:97: reset-gpios = <&gpio4 10 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-ds.dtsi:232: reset-gpios = <&gpio1 7 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-kontron-bl-43.dts:32: reset-gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6q-cm-fx6.dts:73: reset-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6sx-softing-vining-2000.dts:104: phy-reset-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-softing-vining-2000.dts:127: phy-reset-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-softing-vining-2000.dts:171: reset-gpios = <&gpio2 10 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6qdl-nit6xlite.dtsi:194: phy-reset-gpios = <&gpio1 27 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-plybas.dts:134: reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-tx6.dtsi:268: phy-reset-gpios = <&gpio7 6 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-tx6.dtsi:339: reset-gpios = <&gpio2 22 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sr-som-ti.dtsi:71: reset-gpios = <&gpio5 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-zii-rdu2.dtsi:380: reset-gpios = <&gpio1 2 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-zii-rdu2.dtsi:576: reset-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-zii-rdu2.dtsi:718: phy-reset-gpios = <&gpio1 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-icore-rqs.dtsi:84: reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-tx6ul-mainboard.dts:81: phy-reset-gpios = <&gpio4 28 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-skov-reve-mi1010ait-1cp1.dts:63: reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-evk-btwifi.dtsi:17: reset-gpios = <&gpio5 1 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-prti6q.dts:219: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi:18: reset-gpios = <&gpio5 11 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-dhcom-pdk2.dtsi:206: reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b105pv2.dts:28: reset-gpios = <&tca6424a 21 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sll-evk-btwifi.dts:15: reset-gpios = <&gpio3 24 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b105v2.dts:28: reset-gpios = <&tca6424a 21 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-dmo-edmqmx6.dts:116: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-colibri.dtsi:599: reset-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>; /* SODIMM 106 */
arch/arm/boot/dts/imx6q-novena.dts:226: phy-reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b155v2.dts:30: reset-gpios = <&tca6424a 21 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6qdl-kontron-samx6i.dtsi:272: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sr-som.dtsi:64: phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-pico.dtsi:111: phy-reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-mccmon6.dts:102: phy-reset-gpios = <&gpio1 27 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-skov-cpu.dtsi:69: reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-var-dart.dtsi:186: reset-gpios = <&gpio5 5 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-tx6ul.dtsi:287: phy-reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-tx6ul.dtsi:322: phy-reset-gpios = <&gpio4 28 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-tx6ul.dtsi:358: reset-gpios = <&gpio5 3 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-pico-hobbit.dts:68: reset-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ulz-bsh-smm-m2.dts:21: reset-gpios = <&gpio2 21 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-nitrogen6_max.dtsi:336: phy-reset-gpios = <&gpio1 27 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-victgo.dts:200: reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw5903.dtsi:451: reset-gpios = <&gpio5 17 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-eckelmann-ci4x10.dts:298: phy-reset-gpios = <&gpio1 18 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6-logicpd-baseboard.dtsi:224: phy-reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6-logicpd-baseboard.dtsi:271: reset-gpios = <&gpio3 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-ba16.dtsi:389: reset-gpios = <&gpio7 11 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6ul-pico-pi.dts:71: reset-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-prti6g.dts:104: reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-prtwd2.dts:29: reset-gpios = <&gpio6 10 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabrelite.dtsi:293: phy-reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabrelite.dtsi:354: reset-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>; /* NANDF_D5 */
arch/arm/boot/dts/imx6qdl-sabrelite.dtsi:373: reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw53xx.dtsi:198: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qp-prtwd3.dts:68: reset-gpios = <&gpio5 11 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qp-prtwd3.dts:80: reset-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qp-prtwd3.dts:114: reset-gpios = <&gpio6 10 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qp-prtwd3.dts:139: reset-gpios = <&gpio5 5 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qp-prtwd3.dts:233: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b125pv2.dts:28: reset-gpios = <&tca6424a 21 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6dl-lanmcu.dts:95: reset-gpios = <&gpio6 10 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-lanmcu.dts:131: reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-prtmvt.dts:332: reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sr-som-brcm.dtsi:65: reset-gpios = <&gpio5 26 GPIO_ACTIVE_LOW>,
arch/arm/boot/dts/imx6qdl-aristainetos.dtsi:112: phy-reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-icore.dtsi:165: reset-gpios = <&gpio7 12 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-icore.dtsi:210: reset-gpios = <&gpio5 31 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-mba6.dtsi:186: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-imx6ull-opos6ul.dtsi:20: reset-gpios = <&gpio2 9 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-imx6ull-opos6ul.dtsi:29: phy-reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-dhcom-som.dtsi:144: reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabreauto.dtsi:323: reset-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-gw5400-a.dts:151: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-qmx6.dtsi:116: phy-reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-nitrogen6sx.dts:279: reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-tbs2910.dts:119: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw54xx.dtsi:235: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-evi.dts:148: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw560x.dtsi:277: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-var-dt6customboard.dts:155: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-vicut1-12inch.dtsi:49: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-apf6.dtsi:20: reset-gpios = <&gpio2 8 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-apf6.dtsi:31: phy-reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ull-colibri.dtsi:172: reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; /* SODIMM 106 / RST */
arch/arm/boot/dts/imx6qdl-apalis.dtsi:457: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-apalis.dtsi:494: reset-gpios = <&gpio6 9 GPIO_ACTIVE_LOW>; /* MXM3_13 */
arch/arm/boot/dts/imx6qdl-apalis.dtsi:705: reset-gpios = <&gpio2 4 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6q-marsboard.dts:125: reset-gpios = <&gpio3 31 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-emcon.dtsi:184: phy-reset-gpios = <&gpio5 20 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-phytec-pfla02.dtsi:93: phy-reset-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b1x5v2.dtsi:29: reset-gpios = <&tca6424a 9 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-phytec-phycore-som.dtsi:58: phy-reset-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6ul-ccimx6ulsbcpro.dts:90: phy-reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-sdb.dtsi:205: reset-gpios = <&gpio3 27 1>;
arch/arm/boot/dts/imx6sx-sdb.dtsi:269: phy-reset-gpios = <&gpio2 7 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw5907.dtsi:131: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-b125v2.dts:28: reset-gpios = <&tca6424a 21 GPIO_ACTIVE_HIGH>;
arch/arm/boot/dts/imx6q-bosch-acc.dts:445: reset-gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* Old: 0, SS: HIGH */
arch/arm/boot/dts/imx6qdl-aristainetos2.dtsi:320: phy-reset-gpios = <&gpio7 18 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-sdb-btwifi.dts:38: reset-gpios = <&gpio4 10 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-riotboard.dts:107: reset-gpios = <&gpio3 31 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-savageboard.dtsi:107: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-plym2m.dts:272: reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sl-tolino-shine2hd.dts:90: reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sl-tolino-shine2hd.dts:122: reset-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd.dtsi:300: reset-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd.dtsi:360: reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd.dtsi:448: reset-gpios = <&gpio1 17 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd.dtsi:519: reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-rex.dtsi:105: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd-btwifi.dtsi:27: reset-gpios = <&gpio1 2 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-sabresd-btwifi.dtsi:34: reset-gpios = <&gpio4 7 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-alti6p.dts:225: reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-pico.dtsi:178: phy-reset-gpios = <&gpio1 26 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-pico.dtsi:224: reset-gpios = <&gpio5 27 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-pico.dtsi:242: reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-yapp4-common.dtsi:109: phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-yapp4-common.dtsi:337: reset-gpios = <&gpio_oled 1 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6dl-yapp4-common.dtsi:350: reset-gpios = <&gpio_oled 1 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sx-udoo-neo.dtsi:80: phy-reset-gpios = <&gpio2 1 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sl-evk-btwifi.dts:22: reset-gpios = <&gpio5 17 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sl-evk-btwifi.dts:29: reset-gpios = <&gpio5 16 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-gw52xx.dtsi:205: phy-reset-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6qdl-nitrogen6x.dtsi:269: phy-reset-gpios = <&gpio1 27 GPIO_ACTIVE_LOW>;
arch/arm/boot/dts/imx6sl-warp.dts:64: reset-gpios = <&gpio4 5 GPIO_ACTIVE_LOW>, /* WL_REG_ON */
and IMX93 : https://community.nxp.com/t5/i-MX-Processors/How-to-configure-the-phy-reset-pin-for-imx93x/td-p/1765...
Could you help to clarify my confusion, please ?
Thanks in advance and best regards,
Khang
