How to convert vmlinux into uImage
3,994 次查看
davidzhou
Contributor V
I have imx6ul and Linux 4.15
I am trying to use uImage for booting process. Currentlt zImage is created from vmlinux ( I believe).
The vmlinux is ELF 32-bit LSB relocatable, ARM, version1, statically linked, not stripped.
I converted from vmlinux into uImage. Using bootm, everything is fine upto kernel_entry(); Stuck when control is transferred into kernel. The loadaddr of the vmlinux is 0x001010100. Usning mkimage, I set loadaddr and entry point to 0x80008000. The command as follows:
mkimage -A arm -T kernel -C none -O linux -a 0x80008000 -e 0x80008000 -n "Linux" -d vmlinux uImage
By the way, what is the best way to make uImage?
What did I missed?
Thank you,
David Zhou
3,047 次查看
davidzhou
Contributor V
I worked out a way to create uImage by installing tool chain, and use:
make -j8 LOADADDR=0x80008000 uImage
The uImage is good
Thank you,
David
