How to control gpio from user space in imx8m plus
2,275 次查看
kamalesh
I am using custom board having yocto image version-6.6.52. Here there is no /sys/class/gpio. Because it is depreceated here. So i need to use lipgpiod.
I am having external gpio pin in board which is GPIO1_IO15. I have checked the device tree. There is no other operations for this pin. So how can i proceed with libgpiod. I have tried, whenever i am trying to access, it is hanging.
Please share any relevant document or methods to try?
Please respond as soon as possible.
Kamalesh
6 回复数
2,260 次查看
Chavira
Hi @kamalesh!
You only have to configure your device tree to manage the gpio.
Please share your device tree and I will help you.
Best Regards!
Chavira
2,255 次查看
kamalesh
Hi Chavira,
Here, I attached the dts. Please give me some details, how it will link also to get some knowledge?
kamalesh
2,217 次查看
Chavira
Hi @kamalesh!
I have added the GPIO1_IO15 to the device tree as a GPIO, please ensure that the same pin is not configured in imx8mp-axon.dtsi file.
After that you should be able to use the GPIO using the next commands:
$ gpioset -c gpiochip0 15=0
$ gpioset -c gpiochip0 15=1
$ gpioget -c gpiochip0 15
You can consult our documentation in the link below:
Embedded Linux for i.MX Applications Processors
The Linux Kernel documentation
Best Regards!
Chavira
2,200 次查看
kamalesh
Hi Chavira,
After uploading the updated device tree, I have used the libgpiod API to set the gpio high, it does not responding anything.
What may be the issue?
Note: I am using Yocto-6.6.52_2.2.0-stable version
Kamalesh
2,188 次查看
Chavira
Hi @kamalesh!
please check if the same pin is not configured in imx8mp-axon.dtsi file.
2,142 次查看
kamalesh
I have taken other gpio instead of this GPIO1_IO15. I have done the same device tree changes. It worked.
Thank you for the support.
Kamalesh
