How to control ECSPI2 on i.MX8M Mini EVK
1,035 次查看
eric_m_will
I want to use the ECSPI2 interface (available on J1003) on a i.MX8M Mini EVK to send data to a D/A chip and to receive data from an A/D chip. I am running a yocto 4.19.35 linux build, although I could shift to a different release if necessary.
Can someone point me to information that would allow me to exercise the ECSPI2 interface from a C program, ideally in user space? Any associated command line tools would also be welcome.
Thank you,
Eric
950 次查看
Hi Eric
one can look at dts change:
bulix.org / pastebin
imx8mm-nitrogen8mm.dts example
linux-imx6/imx8mm-nitrogen8mm.dts at boundary-imx_4.14.x_1.0.0_ga · boundarydevices/linux-imx6 · Git...
