How to connect EIM for i.MX6SL
ko-hey
Senior Contributor II
Hi all
Let me confirm about the connection of EIM for i.MX6SL.
My customer plan to boot from NOR-SPI flash(16bit).
In that case, is the above connection correct ?
P.S.
I refer to the following link.
https://community.nxp.com/message/437106
Ko-hey
Hi Ko-hey
it is correct with left column should be AUS=0 Address shifted according to port size,
connecting the address signals one to one (for example, A0→A0 and A1→A1).
and right column should be AUS=1.
ko-hey
Is following table correct ?
AUS=0
AUS=1
NOR
ADDRESS
EIM_ADDR[22]
EIM_ADDR[23]
A[22]
EIM_ADDR[21]
EIM_ADDR[22]
A[21]
EIM_ADDR[20]
EIM_ADDR[21]
A[20]
EIM_ADDR[19]
EIM_ADDR[20]
A[19]
EIM_ADDR[18]
EIM_ADDR[19]
A[18]
EIM_ADDR[17]
EIM_ADDR[18]
A[17]
EIM_ADDR[16]
EIM_ADDR[17]
A[16]
EIM_AD[15]
EIM_ADDR[16]
A[15]
EIM_AD[14]
EIM_AD[15]
A[14]
EIM_AD[13]
EIM_AD[14]
A[13]
EIM_AD[12]
EIM_AD[13]
A[12]
EIM_AD[11]
EIM_AD[12]
A[11]
EIM_AD[10]
EIM_AD[11]
A[10]
EIM_AD[9]
EIM_AD[10]
A[9]
EIM_AD[8]
EIM_AD[9]
A[8]
EIM_AD[7]
EIM_AD[8]
A[7]
EIM_AD[6]
EIM_AD[7]
A[6]
EIM_AD[5]
EIM_AD[6]
A[5]
EIM_AD[4]
EIM_AD[5]
A[4]
EIM_AD[3]
EIM_AD[4]
A[3]
EIM_AD[2]
EIM_AD[3]
A[2]
EIM_AD[1]
EIM_AD[2]
A[1]
EIM_AD[0]
EIM_AD[1]
A[0]
DATA
LCD_DAT[21]
LCD_DAT[21]
DQ[15]
LCD_DAT[20]
LCD_DAT[20]
DQ[14]
LCD_DAT[19]
LCD_DAT[19]
DQ[13]
LCD_DAT[18]
LCD_DAT[18]
DQ[12]
LCD_DAT[17]
LCD_DAT[17]
DQ[11]
LCD_DAT[16]
LCD_DAT[16]
DQ[10]
LCD_DAT[15]
LCD_DAT[15]
DQ[9]
LCD_DAT[14]
LCD_DAT[14]
DQ[8]
LCD_DAT[13]
LCD_DAT[13]
DQ[7]
LCD_DAT[12]
LCD_DAT[12]
DQ[6]
LCD_DAT[11]
LCD_DAT[11]
DQ[5]
LCD_DAT[10]
LCD_DAT[10]
DQ[4]
LCD_DAT[9]
LCD_DAT[9]
DQ[3]
LCD_DAT[8]
LCD_DAT[8]
DQ[2]
LCD_DAT[7]
LCD_DAT[7]
DQ[1]
LCD_DAT[6]
LCD_DAT[6]
DQ[0]
Ko-hey
Hi Ko-hey
yes correct
