How to connect CLKIN/OUT pins
已解决
跳至解决方案
1,342 次查看
arnemaathuis
In my application(i.MX8M Nano Dual) i do not need any of the CLKINx and CLKOUTx functionality.
can i leave these pins(H26/H27/J26/J27) unconnected or should i pull them to a certain voltage level.
thanks in advance,
Arne Maathuis, Sintecs, NL
标签 (1)
1 解答
1,264 次查看
gusarambula
Hello Arne Maathuis,
CLKINx pins can be used to drive some of the internal PLL instead of the SYS_XTAL. If you won’t be using these pins these can be left floating.
I hope this helps!
在原帖中查看解决方案
1 回复
1,265 次查看
gusarambula
I hope this helps!
