Hello, I would like to check:
1. Are the signals CCM_CLK1_P/N described in iMX6UL datasheet correspond to the pin CLK1_P/N ?
2. The datasheet mentioned that these 2 signals can be used "To output internal SoC clock to be used outside....".
May I know which section in iMX6UL RM describes how to do it? what are the registers? how to select clock source and divider etc ?
3. The closest description I can find in RM is "CCM_CLKO1/2". Are these signals routed to CLK1_P/N pins ?
Thanks!
Thomas
解決済! 解決策の投稿を見る。
Hi Thomas
configuration is described in sect.38.6.6 Miscellaneous Register 1 (PMU_MISC1n)
field LVDS1_CLK_SEL, i.MX6UL Reference Manual (rev.0 8/2015)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6ULRM.pdf
Hi Thomas
