Thank you Bio_TICFSL for the reply,
Power Management | Android Open Source Project
Will you please provide your input,
Wake sources
The Integrator must disable the appropriate wake sources when the device is in suspend mode. Common wake sources include heartbeats, modem, Wi-Fi, and Bluetooth. The only valid wake source must be an interrupt from the VMCU to wake up the SoC. This assumes that the VMCU can listen to the modem for remote wakeup events (such as remote engine start). If this functionality is pushed to the AP, then another wake source to service the modem must be added.
Thanks & Regards,
VInothS,
Vinothkumar Sekar
