How to configure CSF to sign uboot with a different key
rohininarasipur
Even though I generated 4 different key sets using hab4_pki_tree.sh script, I am able to use only the first pair of keys for signing and verification. If I specify second, third or fourth certificate in the configuration file, HAB events (HAB_INV_SIGNATURE and HAB_INV_KEY) are generated during boot. If I choose second CSF and IMG certificate, then should I also change the source index in Install SRK section? How will HAB know which SRK to use for verifying root of trust? And what other changes should I do in my config file to use any certificate pair other than the first CSF and IMG pair?
Rohini
Yuri
  Sorry, but the information you are requesting is treated as confidential info at this time and requires a signed NDA
(Non-Disclosure Agreement). Naturally, we cannot discuss this with you in public anyway, this requires to be handled
as a Service Request (SR).
Support|NXP
Yuri
