How to compile mfgtool uboot under android 8.1
4,561件の閲覧回数
hannywei
hi
I am using i.mx8m
After modifing uboot source code, I want to know how to  compile mfgtool uboot under android 8.1?
17 返答(返信)
4,090件の閲覧回数
传策薛
Have you solved this problem?
4,090件の閲覧回数
hannywei
NO
4,090件の閲覧回数
传策薛
I sovled it,we should build another mfgtool uboot image,should change the uboot source,and there are some uboot errors we should fix it!
4,090件の閲覧回数
hannywei
Can you share me the change and code?
4,090件の閲覧回数
Rita_Wang
I am confiming it for you.
4,090件の閲覧回数
hannywei
any update?
4,090件の閲覧回数
hannywei
Have you confirmed it?
4,090件の閲覧回数
Rita_Wang
I have If the DDR is the same as our refrence board, you can directly use the default mfgtool. You do not need to build the mfgtool firmware. If you change the DDR you need to rebuild the firmware for your board mfgtool, About the mfgtool uboot here you can use the same one uboot image with your board uboot image.
Have a nice day
Rita
4,090件の閲覧回数
hannywei
HI
The  DDR is same.
Do you have a test? we have tried and failed.
4,090件の閲覧回数
Rita_Wang
Here you can use the default mfgtool u-boot, and you need to copy your board images to the mfgtool file. Could you tell me your details steps?
4,090件の閲覧回数
hannywei
The default mfgtool u-boot can not work.
sure ,I copy the board images to he mfgtool file , i following the guidance document.
the steps is the same as  i.MX8MQ u-boot和mgftool烧写emmc失败
4,090件の閲覧回数
Rita_Wang
You can refer to our user guide document. And here could you tell me which flash you download the images to , EMMC or SD card?
4,090件の閲覧回数
Rita_Wang
4,090件の閲覧回数
hannywei
Not success,my question is same as https://community.nxp.com/thread/479888 。
4,090件の閲覧回数
Rita_Wang
About the mfgtool uboot here you can use the same one uboot image with your board uboot image. You do not need to compile special for it. You can have a try.
Rita
4,090件の閲覧回数
hannywei
hi Rita Wang
any update?
4,090件の閲覧回数
hannywei
Not success,my question is same as i.MX8MQ u-boot和mgftool烧写emmc失败 。
