How to compile have cargo build within a meta-layer
3,874件の閲覧回数
cbugk-dannie
I was following this example on inheriting cargo.bbclass and compiling a simple project:
https://www.youtube.com/watch?v=aPsMuSU-Btw
However, I got following error:
NOTE: Executing Tasks
ERROR: my-test-0.1-r0 do_compile: ExecutionError('/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257', 101, None, None)
ERROR: Logfile of failure stored in: /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/log.do_compile.24257
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Using rust targets from /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/rust-targets/
| NOTE: cargo = /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/recipe-sysroot-native/usr/bin/cargo
| NOTE: cargo build -v --frozen --target aarch64-poky-linux-gnu --release --manifest-path=/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git//Cargo.toml
| error: the lock file /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git/Cargo.lock needs to be updated but --frozen was passed to prevent this
| If you want to try to generate the lock file without accessing the network, remove the --frozen flag and use --offline instead.
| WARNING: /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257:185 exit 101 from '"cargo" build -v --frozen --target aarch64-poky-linux-gnu --release --manifest-path=/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git//Cargo.toml "$@"'
| WARNING: Backtrace (BB generated script):
| #1: oe_cargo_build, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 185
| #2: cargo_do_compile, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 157
| #3: do_compile, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 152
| #4: main, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 198
ERROR: Task (/opt/yocto/imx-6.6.3-1.0.0-build/sources/meta-my-test/recipes-cargo/install/my-test_0.1.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5745 tasks of which 5743 didn't need to be rerun and 1 failed.
I had run `bitbake -f my-test core-image-minimal`. BBLAYERS was appended as well.
Simply: How to compile and install a Rust program into iMX93EVK ?
タグ(1)
3,826件の閲覧回数
cbugk-dannie
I am a fool, more precisely a newbie. The repo I was referring to (https://gitlab.com/pbarker.dev/rust/print-rand) had no Cargo.lock file. I ran it manually on my machine copied file over and voila!
The path the repo was downloaded was `/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git/` by default. Well I can override that somehow. This was a non-issue. Well hopefully helps other noobs out in the future.
Edit: Some other pitfalls:
* `IMAGE_INSTALL` did not work in my case, but `CORE_IMAGE_EXTRA_INSTALL` allowed me to add custom layer's bb files to `bitbake core-image-minimal` build. Recipe name is irrelevant for all I can tell.
* On first run, I encountered missing crate hashes. Luckily the fix is printed on. Adding those with a `.inc` file beside the `.bb` file was sufficient to get over it without modifying .bb file `cargo bitbake` command generates.
5 返答(返信)
3,827件の閲覧回数
cbugk-dannie
3,820件の閲覧回数
Bio_TICFSL
Good
3,856件の閲覧回数
Bio_TICFSL
Rust is not include in the default BSP, you have to add it to yocto.
https://interrupt.memfault.com/blog/rust-in-yocto
3,829件の閲覧回数
cbugk-dannie
cbugk-dannie
cbugk-dannie
BTW, this line in the original post tells me cargo itself is functional:
What I am missing is not knowing how to use the default Yocto behaviour of --frozen with an ordinary cargo project.
But I suppose this is outside of the scope of NXP. Still, ou guys commented on having scripts and all on some other posts on this forum. So thought worth a shot, would appreciate any such tips if any.
3,837件の閲覧回数
cbugk-dannie
Firstly, thanks.
I get following error when added `DEPENDS += " meta-rust "` to bb file. I thought `meta-rust` was absorbed into `oe-core`, so do I really need it on nanbield?
Loading cache: 100% |########################################################################################################################| Time: 0:00:00Loaded 5451 entries from dependency cache. NOTE: Resolving any missing task queue dependencies ERROR: Nothing PROVIDES 'meta-rust' (but /opt/yocto/imx-6.6.3-1.0.0-build/sources/meta-my-test/recipes-my/company/my-test_0.1.bb DEPENDS on or otherwise requires it) ERROR: Required build target 'my-test' has no buildable providers.
Missing or unbuildable dependency chain was: ['my-test', 'meta-rust'] Summary: There were 2 ERROR messages, returning a non-zero exit code.
Edit: I also added it as another echo of `BBLAYERS` in imx-setup-release.sh and to manifest of repo tool. However, nanbield is not compatible with this modus operandi:
```ERROR: Layer rust-layer is not compatible with the core layer which only supports these series: nanbield (layer is compatible with mickledore honister hardknott gatesgarth kirkstone)```
%3CLINGO-SUB%20id%3D%22lingo-sub-1861495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E5%86%85%E3%81%A7%20cargo%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81cargo.bbclass%E3%82%92%E7%B6%99%E6%89%BF%E3%81%97%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaPsMuSU-Btw%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaPsMuSU-Btw%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%BE%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20my-test-0.1-r0do_compile%3A%20ExecutionError('%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257'%2C101%E3%80%81%E3%81%AA%E3%81%97%E3%80%81%E3%81%AA%E3%81%97)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2F%20opt%20%2F%20yocto%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20temporary%20%2F%20log.do_compile.24257%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%7CDEBUG%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_compile%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%E6%B3%A8%3A%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Frust-targets%2F%E3%81%AE%E9%8C%86%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%7C%E6%B3%A8%3Acargo%20%3D%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcargo%3CBR%20%2F%3E%7C%E6%B3%A8%3Acargo%20build%20-v%20--frozen%20--target%20aarch64-poky-linux-gnu%20--release%20--manifest-path%3D%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%2FCargo.toml%3CBR%20%2F%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%AD%E3%83%83%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F%20opt%20%2F%20yoc%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20git%20%2F%20Cargo.lock%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AB--frozen%E3%81%8C%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%9B%E3%81%9A%E3%81%AB%E3%83%AD%E3%83%83%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81--frozen%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB--offline%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%7C%E8%AD%A6%E5%91%8A%3A%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%3A185%E3%80%8C%22cargo%22%E3%83%93%E3%83%AB%E3%83%89-v%E3%80%8D%E3%81%8B%E3%82%89101%E3%82%92%E7%B5%82%E4%BA%86%20--frozen%20--target%20aarch64-poky-linux-gnu%20--release%20--manifest-path%3D%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%2FCargo.toml%20%22%24%40%22'%3CBR%20%2F%3E%7C%E8%AD%A6%E5%91%8A%3A%E3%83%90%E3%83%83%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9(BB%E7%94%9F%E6%88%90%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88)%3A%3CBR%20%2F%3E%7C%231%3Aoe_cargo_build%E3%80%81%2F%20opt%20%2F%20yocto%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20temp%20%2F%20run.do_compile.24257%E3%80%81185%E7%95%AA%E7%B7%9A%3CBR%20%2F%3E%7C%232%3Acargo_do_compile%E3%80%81%2F%20opt%20%2F%20yocto%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20temp%20%2F%20run.do_compile.24257%E3%80%81157%E7%95%AA%E7%B7%9A%3CBR%20%2F%3E%7C%233%3Ado_compile%E3%80%81%2F%20opt%20%2F%20yocto%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20temp%20%2F%20run.do_compile.24257%E3%80%81152%E7%95%AA%E7%B7%9A%3CBR%20%2F%3E%7C%234%3A%E3%83%A1%E3%82%A4%E3%83%B3%E3%80%81%2F%20opt%20%2F%20yocto%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20temperature%20%2F%20run.do_compile.24257%E3%80%81198%E7%95%AA%E7%B7%9A%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF%EF%BC%88%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fsources%2Fmeta-my-test%2Frecipes-cargo%2Finstall%2Fmy-test_0.1.bb%3Ado_compile)%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%205745%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%205743%20%E5%80%8B%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20'bitbake%20-f%20my-test%20core-image-minimal'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82BBLAYERS%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B0%A1%E5%8D%98%E3%81%AB%E8%A8%80%E3%81%86%E3%81%A8%E3%80%81Rust%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92iMX93EVK%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E5%86%85%E3%81%A7cargo%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%88%E3%81%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E5%86%85%E3%81%A7cargo%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%84%9A%E3%81%8B%E8%80%85%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fgitlab.com%2Fpbarker.dev%2Frust%2Fprint-rand%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.com%2Fpbarker.dev%2Frust%2Fprint-rand%3C%2FA%3ECargo.lock%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%A7%81%E3%81%AE%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E6%89%8B%E5%8B%95%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E5%87%BA%E6%9D%A5%E4%B8%8A%E3%81%8C%E3%82%8A!%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%82%B9%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%8C%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%E3%80%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%82%E3%80%81%E3%81%A9%E3%81%86%E3%81%AB%E3%81%8B%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%82%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%91%E3%81%B0%E3%80%81%E5%B0%86%E6%9D%A5%E4%BB%96%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B7%A8%E9%9B%86%3A%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BB%96%E3%81%AE%E8%90%BD%E3%81%A8%E3%81%97%E7%A9%B4%3A%3CBR%20%2F%3E*%20%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%80%8CIMAGE_INSTALL%E3%80%8D%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%80%8CCORE_IMAGE_EXTRA_INSTALL%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AEbb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%80%8Cbitbake%20core-image-minimal%E3%80%8D%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E7%A7%81%E3%81%8C%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E*%20%E6%9C%80%E5%88%9D%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%80%81%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%B9%B8%E3%81%84%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%81%E4%BF%AE%E6%AD%A3%E3%81%AF%E5%8D%B0%E5%88%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82'.bb'%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%A8%AA%E3%81%AB%20'.inc'%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81.bb%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%9A%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%A7%E3%81%97%E3%81%9Ffile%20'cargo%20bitbake'%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E5%86%85%E3%81%A7cargo%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3ECBUK-%E3%83%80%E3%83%8B%E3%83%BC%3CBR%20%2F%3ECBUK-%E3%83%80%E3%83%8B%E3%83%BC%3CBR%20%2F%3E%E5%AF%84%E7%A8%BF%E8%80%85%20I%3CBR%20%2F%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E5%85%83%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E3%81%93%E3%81%AE%E8%A1%8C%E3%81%AF%E3%80%81%E8%B2%A8%E7%89%A9%E8%87%AA%E4%BD%93%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%AD%E3%83%83%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F%20opt%20%2F%20yoc%20%2F%20imx-6.6.3-1.0.0-build%20%2F%20build_fsl-imx-wayland%20%2F%20tmp%20%2F%20work%20%2F%20armv8a-poky-linux%20%2F%20my-test%20%2F%200.1%20%2F%20git%20%2F%20Cargo.lock%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AB--frozen%E3%81%8C%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E8%B2%A8%E7%89%A9%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEYocto%E5%8B%95%E4%BD%9C--frozen%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFNXP%E3%81%AE%E7%AF%84%E5%9B%B2%E5%A4%96%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%80%81ou%E3%81%AE%E4%BA%BA%E3%81%9F%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%84%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E4%BB%96%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E4%BE%A1%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%82%82%E3%81%97%E3%81%82%E3%82%8C%E3%81%B0%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E5%86%85%E3%81%A7cargo%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Ebb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB'DEPENDS%20%2B%3D%20%22%20meta-rust%20%22'%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%83%A1%E3%82%BF%E9%8C%86%E3%80%8D%E3%81%8C%E3%80%8Coe-core%E3%80%8D%E3%81%AB%E5%90%B8%E5%8F%8E%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%ABnanbield%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7CTime%3A%200%3A00%3A00%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205451%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B3%A8%3A%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%BD%95%E3%82%82%E3%80%8Cmeta-rust%E3%80%8D%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93(%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fsources%2Fmeta-my-test%2Frecipes-my%2Fcompany%2Fmy-test_0.1.bb%E3%81%9D%E3%82%8C%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99)%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'my-test'%20%E3%81%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%3A%20%5B'my-test'%2C%20'meta-rust'%5D%20%E6%A6%82%E8%A6%81%3A%202%20%E3%81%A4%E3%81%AE%20ERROR%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B7%A8%E9%9B%86%3A%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%9F%E3%80%81imx-setup-release.sh%20%E3%81%AE%E3%80%8CBBLAYERS%E3%80%8D%E3%81%AE%E5%88%A5%E3%81%AE%E3%82%A8%E3%82%B3%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81nanbield%E3%81%AF%E3%81%93%E3%81%AE%E6%89%8B%E5%8F%A3%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E'''%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BCrust-layer%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%B3%E3%82%A2%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3Ananbield(%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AFmickledore%20honister%20hardknott%20gatesgarth%20kirkstone%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)'''%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
