How to compile have cargo build within a meta-layer
3,732 次查看
cbugk-dannie
I was following this example on inheriting cargo.bbclass and compiling a simple project:
https://www.youtube.com/watch?v=aPsMuSU-Btw
However, I got following error:
NOTE: Executing Tasks
ERROR: my-test-0.1-r0 do_compile: ExecutionError('/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257', 101, None, None)
ERROR: Logfile of failure stored in: /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/log.do_compile.24257
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Using rust targets from /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/rust-targets/
| NOTE: cargo = /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/recipe-sysroot-native/usr/bin/cargo
| NOTE: cargo build -v --frozen --target aarch64-poky-linux-gnu --release --manifest-path=/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git//Cargo.toml
| error: the lock file /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git/Cargo.lock needs to be updated but --frozen was passed to prevent this
| If you want to try to generate the lock file without accessing the network, remove the --frozen flag and use --offline instead.
| WARNING: /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257:185 exit 101 from '"cargo" build -v --frozen --target aarch64-poky-linux-gnu --release --manifest-path=/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git//Cargo.toml "$@"'
| WARNING: Backtrace (BB generated script):
| #1: oe_cargo_build, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 185
| #2: cargo_do_compile, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 157
| #3: do_compile, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 152
| #4: main, /opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/temp/run.do_compile.24257, line 198
ERROR: Task (/opt/yocto/imx-6.6.3-1.0.0-build/sources/meta-my-test/recipes-cargo/install/my-test_0.1.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5745 tasks of which 5743 didn't need to be rerun and 1 failed.
I had run `bitbake -f my-test core-image-minimal`. BBLAYERS was appended as well.
Simply: How to compile and install a Rust program into iMX93EVK ?
标记 (1)
3,684 次查看
cbugk-dannie
I am a fool, more precisely a newbie. The repo I was referring to (https://gitlab.com/pbarker.dev/rust/print-rand) had no Cargo.lock file. I ran it manually on my machine copied file over and voila!
The path the repo was downloaded was `/opt/yocto/imx-6.6.3-1.0.0-build/build_fsl-imx-wayland/tmp/work/armv8a-poky-linux/my-test/0.1/git/` by default. Well I can override that somehow. This was a non-issue. Well hopefully helps other noobs out in the future.
Edit: Some other pitfalls:
* `IMAGE_INSTALL` did not work in my case, but `CORE_IMAGE_EXTRA_INSTALL` allowed me to add custom layer's bb files to `bitbake core-image-minimal` build. Recipe name is irrelevant for all I can tell.
* On first run, I encountered missing crate hashes. Luckily the fix is printed on. Adding those with a `.inc` file beside the `.bb` file was sufficient to get over it without modifying .bb file `cargo bitbake` command generates.
5 回复数
3,685 次查看
cbugk-dannie
3,678 次查看
Bio_TICFSL
Good
3,714 次查看
Bio_TICFSL
Rust is not include in the default BSP, you have to add it to yocto.
https://interrupt.memfault.com/blog/rust-in-yocto
3,687 次查看
cbugk-dannie
cbugk-dannie
cbugk-dannie
BTW, this line in the original post tells me cargo itself is functional:
What I am missing is not knowing how to use the default Yocto behaviour of --frozen with an ordinary cargo project.
But I suppose this is outside of the scope of NXP. Still, ou guys commented on having scripts and all on some other posts on this forum. So thought worth a shot, would appreciate any such tips if any.
3,695 次查看
cbugk-dannie
Firstly, thanks.
I get following error when added `DEPENDS += " meta-rust "` to bb file. I thought `meta-rust` was absorbed into `oe-core`, so do I really need it on nanbield?
Loading cache: 100% |########################################################################################################################| Time: 0:00:00Loaded 5451 entries from dependency cache. NOTE: Resolving any missing task queue dependencies ERROR: Nothing PROVIDES 'meta-rust' (but /opt/yocto/imx-6.6.3-1.0.0-build/sources/meta-my-test/recipes-my/company/my-test_0.1.bb DEPENDS on or otherwise requires it) ERROR: Required build target 'my-test' has no buildable providers.
Missing or unbuildable dependency chain was: ['my-test', 'meta-rust'] Summary: There were 2 ERROR messages, returning a non-zero exit code.
Edit: I also added it as another echo of `BBLAYERS` in imx-setup-release.sh and to manifest of repo tool. However, nanbield is not compatible with this modus operandi:
```ERROR: Layer rust-layer is not compatible with the core layer which only supports these series: nanbield (layer is compatible with mickledore honister hardknott gatesgarth kirkstone)```
%3CLINGO-SUB%20id%3D%22lingo-sub-1861495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E5%85%83%E5%B1%82%E4%B8%AD%E7%BC%96%E8%AF%91%20Cargo%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E7%BB%A7%E6%89%BF%E4%BA%86%20cargo.bbclass%20%E5%B9%B6%E7%BC%96%E8%AF%91%E4%BA%86%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%9A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaPsMuSU-Btw%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaPsMuSU-Btw%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3CBR%20%2F%3E%20%60%60%60%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%89%A7%E8%A1%8C%E4%BB%BB%E5%8A%A1%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Amy-test-0.1-r0do_compile%3A%E6%89%A7%E8%A1%8C%E9%94%99%E8%AF%AF%EF%BC%88'%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257'%EF%BC%8C101%EF%BC%8C%E6%97%A0%EF%BC%8C%E6%97%A0%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Flog.do_compile.24257%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E6%95%B0%E6%8D%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%20%7C%20DEBUG%EF%BC%9A%E6%89%A7%E8%A1%8C%20shell%20%E5%87%BD%E6%95%B0%20do_compile%3CBR%20%2F%3E%20%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Frust-targets%2F%20%E7%9A%84%20rust%20%E7%9B%AE%E6%A0%87%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9Acargo%20%3D%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcargo%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9Acargo%20build%20-v%20--frozen%20--target%20aarch64-poky-linux-gnu%20--release%20--manifest-path%3D%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%2FCargo.toml%3CBR%20%2F%3E%7C%20%E9%94%99%E8%AF%AF%EF%BC%9A%E9%94%81%E5%AE%9A%E6%96%87%E4%BB%B6%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2FCargo.lock%20%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%EF%BC%8C%E4%BD%86%E5%B7%B2%E4%BC%A0%E9%80%92%20--frozen%20%E4%BB%A5%E9%98%B2%E6%AD%A2%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%3CBR%20%2F%3E%7C%20%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%B0%9D%E8%AF%95%E5%9C%A8%E4%B8%8D%E8%AE%BF%E9%97%AE%E7%BD%91%E7%BB%9C%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%94%9F%E6%88%90%E9%94%81%E5%AE%9A%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%B7%E5%88%A0%E9%99%A4%20--frozen%20%E6%A0%87%E5%BF%97%E5%B9%B6%E6%94%B9%E7%94%A8%20--offline%E3%80%82%3CBR%20%2F%3E%7C%E8%AD%A6%E5%91%8A%EF%BC%9A%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%3A185%E4%BB%8E'%E2%80%9Ccargo%E2%80%9Dbuild%20-v%20--frozen%20--target%20aarch64-poky-linux-gnu%20--release%20--manifest-path%3D%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%2FCargo.toml%E2%80%9C%24%40%E2%80%9D'%E9%80%80%E5%87%BA101%3CBR%20%2F%3E%20%7C%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9B%9E%E6%BA%AF%EF%BC%88BB%20%E7%94%9F%E6%88%90%E7%9A%84%E8%84%9A%E6%9C%AC%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%20%7C%20%231%3A%20oe_cargo_build%2C%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%2C%E7%AC%AC%20185%20%E8%A1%8C%3CBR%20%2F%3E%7C%20%232%3Acargo_do_compile%2C%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%EF%BC%8C%E7%AC%AC%20157%20%E8%A1%8C%3CBR%20%2F%3E%7C%20%233%3A%20do_compile%2C%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%EF%BC%8C%E7%AC%AC%20152%20%E8%A1%8C%3CBR%20%2F%3E%7C%20%234%3A%E4%B8%BB%E8%A6%81%E7%9A%84%EF%BC%8C%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Ftemp%2Frun.do_compile.24257%EF%BC%8C%E7%AC%AC%20198%20%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fsources%2Fmeta-my-test%2Frecipes-cargo%2Finstall%2Fmy-test_0.1.bb%3Ado_compile%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%205745%20%E9%A1%B9%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%205743%20%E9%A1%B9%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E9%A1%B9%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E4%BA%86%E2%80%9Cbitbake%20-f%20my-test%20core-image-minimal%E2%80%9D%E3%80%82BBLAYERS%20%E4%B9%9F%E8%A2%AB%E9%99%84%E5%8A%A0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%AE%80%E5%8D%95%E6%9D%A5%E8%AF%B4%EF%BC%9A%E5%A6%82%E4%BD%95%E7%BC%96%E8%AF%91%E5%B9%B6%E5%AE%89%E8%A3%85%20Rust%20%E7%A8%8B%E5%BA%8F%E5%88%B0%20iMX93EVK%20%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E5%85%83%E5%B1%82%E4%B8%AD%E7%BC%96%E8%AF%91%20Cargo%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E5%85%83%E5%B1%82%E4%B8%AD%E7%BC%96%E8%AF%91%20Cargo%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%AF%E4%B8%80%E4%B8%AA%E5%82%BB%E7%93%9C%EF%BC%8C%E6%9B%B4%E7%A1%AE%E5%88%87%E5%9C%B0%E8%AF%B4%E6%98%AF%E4%B8%80%E4%B8%AA%E6%96%B0%E6%89%8B%E3%80%82%E6%88%91%E6%89%80%E6%8C%87%E7%9A%84%20repo%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fgitlab.com%2Fpbarker.dev%2Frust%2Fprint-rand%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.com%2Fpbarker.dev%2Frust%2Fprint-rand%3C%2FA%3E%20%EF%BC%89%E6%B2%A1%E6%9C%89%20Cargo.lock%20%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E5%9C%A8%E6%88%91%E7%9A%84%E6%9C%BA%E5%99%A8%E4%B8%8A%E6%89%8B%E5%8A%A8%E8%BF%90%E8%A1%8C%E4%BA%86%E5%A4%8D%E5%88%B6%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E7%9E%A7%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8B%E8%BD%BD%20repo%20%E7%9A%84%E8%B7%AF%E5%BE%84%E9%BB%98%E8%AE%A4%E4%B8%BA%E2%80%9C%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2F%E2%80%9D%E3%80%82%E5%A5%BD%E5%90%A7%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E8%A6%86%E7%9B%96%E5%AE%83%E3%80%82%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%B8%8C%E6%9C%9B%E5%B0%86%E6%9D%A5%E8%83%BD%E5%B8%AE%E5%8A%A9%E5%85%B6%E4%BB%96%E6%96%B0%E6%89%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%BC%96%E8%BE%91%EF%BC%9A%E5%85%B6%E4%BB%96%E4%B8%80%E4%BA%9B%E9%99%B7%E9%98%B1%EF%BC%9A%3CBR%20%2F%3E%20*%20%E5%9C%A8%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E2%80%9CIMAGE_INSTALL%E2%80%9D%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%BD%86%E2%80%9CCORE_IMAGE_EXTRA_INSTALL%E2%80%9D%E5%85%81%E8%AE%B8%E6%88%91%E5%B0%86%E8%87%AA%E5%AE%9A%E4%B9%89%E5%B1%82%E7%9A%84%20bb%20%E6%96%87%E4%BB%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E2%80%9Cbitbake%20core-image-minimal%E2%80%9D%E6%9E%84%E5%BB%BA%E4%B8%AD%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E9%A3%9F%E8%B0%B1%E5%90%8D%E7%A7%B0%E6%97%A0%E5%85%B3%E7%B4%A7%E8%A6%81%E3%80%82%3CBR%20%2F%3E*%20%E7%AC%AC%E4%B8%80%E6%AC%A1%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%A2%E5%A4%B1%E7%9A%84%E6%9D%BF%E6%9D%A1%E7%AE%B1%E5%93%88%E5%B8%8C%E5%80%BC%E3%80%82%E5%B9%B8%E8%BF%90%E7%9A%84%E6%98%AF%EF%BC%8C%E4%BF%AE%E5%A4%8D%E6%96%B9%E6%B3%95%E5%B7%B2%E7%BB%8F%E6%89%93%E5%8D%B0%E5%87%BA%E6%9D%A5%E4%BA%86%E3%80%82%E5%9C%A8%20%60.bb%60%20%E6%96%87%E4%BB%B6%E6%97%81%E8%BE%B9%E6%B7%BB%E5%8A%A0%20%60.inc%60%20%E6%96%87%E4%BB%B6%E5%B0%B1%E8%B6%B3%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E4%BF%AE%E6%94%B9%20.bb%E6%96%87%E4%BB%B6%20%60cargo%20bitbake%60%20%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E5%85%83%E5%B1%82%E4%B8%AD%E7%BC%96%E8%AF%91%20Cargo%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3Ecbugk-dannie%3CBR%20%2F%3E%20cbugk-dannie%3CBR%20%2F%3E%E8%B4%A1%E7%8C%AE%E8%80%85%20I%3CBR%20%2F%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E5%8F%A5%EF%BC%8C%E5%8E%9F%E5%B8%96%E4%B8%AD%E7%9A%84%E8%BF%99%E4%B8%80%E8%A1%8C%E5%91%8A%E8%AF%89%E6%88%91%E8%B4%A7%E7%89%A9%E6%9C%AC%E8%BA%AB%E6%98%AF%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E7%9A%84%EF%BC%9A%3CBR%20%2F%3E%20%60%60%60%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E9%94%81%E5%AE%9A%E6%96%87%E4%BB%B6%20%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fbuild_fsl-imx-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fmy-test%2F0.1%2Fgit%2FCargo.lock%20%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%EF%BC%8C%E4%BD%86%E5%B7%B2%E4%BC%A0%E9%80%92%20--frozen%20%E4%BB%A5%E9%98%B2%E6%AD%A2%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E6%88%91%E6%89%80%E4%B8%8D%E7%9F%A5%E9%81%93%E7%9A%84%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%E6%99%AE%E9%80%9A%E7%9A%84%E8%B4%A7%E7%89%A9%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20Yocto%20%E8%A1%8C%E4%B8%BA%20--frozen%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E8%B6%85%E5%87%BA%E4%BA%86%20NXP%20%E7%9A%84%E8%8C%83%E5%9B%B4%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E4%BD%A0%E4%BB%AC%E8%BF%98%E6%98%AF%E5%9C%A8%E8%BF%99%E4%B8%AA%E8%AE%BA%E5%9D%9B%E7%9A%84%E5%85%B6%E4%BB%96%E4%B8%80%E4%BA%9B%E5%B8%96%E5%AD%90%E4%B8%8A%E5%AF%B9%E8%84%9A%E6%9C%AC%E5%92%8C%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E5%8F%91%E8%A1%A8%E4%BA%86%E8%AF%84%E8%AE%BA%E3%80%82%E6%89%80%E4%BB%A5%E8%AE%A4%E4%B8%BA%E5%80%BC%E5%BE%97%E4%B8%80%E8%AF%95%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%99%E6%A0%B7%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%E5%85%83%E5%B1%82%E4%B8%AD%E7%BC%96%E8%AF%91%20Cargo%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BD%93%E5%B0%86%20%60DEPENDS%20%2B%3D%20%22%20meta-rust%20%22%60%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20bb%20%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E4%BB%A5%E4%B8%BA%20%60meta-rust%60%20%E5%B7%B2%E7%BB%8F%E8%A2%AB%E5%90%B8%E6%94%B6%E5%88%B0%20%60oe-core%60%20%E4%B8%AD%E4%BA%86%EF%BC%8C%E9%82%A3%E4%B9%88%E5%9C%A8%20nanbield%20%E4%B8%8A%E6%88%91%E7%9C%9F%E7%9A%84%E9%9C%80%E8%A6%81%E5%AE%83%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A00%E4%BB%8E%E4%BE%9D%E8%B5%96%E7%BC%93%E5%AD%98%E5%8A%A0%E8%BD%BD%E4%BA%86%205451%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E9%94%99%E8%AF%AF%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E2%80%9Cmeta-rust%E2%80%9D%EF%BC%88%E4%BD%86%2Fopt%2Fyocto%2Fimx-6.6.3-1.0.0-build%2Fsources%2Fmeta-my-test%2Frecipes-my%2Fcompany%2Fmy-test_0.1.bb%E5%8F%96%E5%86%B3%E4%BA%8E%E6%88%96%E9%9C%80%E8%A6%81%E5%AE%83%EF%BC%89%E9%94%99%E8%AF%AF%EF%BC%9A%E6%89%80%E9%9C%80%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%E2%80%9Cmy-test%E2%80%9D%E6%B2%A1%E6%9C%89%E5%8F%AF%E6%9E%84%E5%BB%BA%E7%9A%84%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E7%BC%BA%E5%A4%B1%E6%88%96%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BE%9D%E8%B5%96%E9%93%BE%E4%B8%BA%EF%BC%9A%5B'my-test'%2C%20'meta-rust'%5D%20%E6%91%98%E8%A6%81%EF%BC%9A%E6%9C%89%202%20%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%BC%96%E8%BE%91%EF%BC%9A%E6%88%91%E8%BF%98%E5%B0%86%E5%85%B6%E4%BD%9C%E4%B8%BA%20imx-setup-release.sh%20%E4%B8%AD%E2%80%9CBBLAYERS%E2%80%9D%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%9B%9E%E6%98%BE%E6%B7%BB%E5%8A%A0%E5%88%B0%20repo%20%E5%B7%A5%E5%85%B7%E7%9A%84%E6%B8%85%E5%8D%95%E4%B8%AD%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8Cnanbield%20%E4%B8%8E%E8%BF%99%E7%A7%8D%E8%BF%90%E4%BD%9C%E6%96%B9%E5%BC%8F%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%60%60%60%E9%94%99%E8%AF%AF%EF%BC%9Arust-layer%20%E5%B1%82%E4%B8%8E%E4%BB%85%E6%94%AF%E6%8C%81%E4%BB%A5%E4%B8%8B%E7%B3%BB%E5%88%97%E7%9A%84%E6%A0%B8%E5%BF%83%E5%B1%82%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%9Ananbield%EF%BC%88%E8%AF%A5%E5%B1%82%E4%B8%8E%20mickledore%20honister%20hardknott%20gatesgarth%20kirkstone%20%E5%85%BC%E5%AE%B9%EF%BC%89%60%60%60%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
