How to communicate between M4 and A9 running linux on i.MX6SoloX?
2,662 次查看
ernestlih
I consider using i.MX6soloX. And I have a question about dual core communication.
Linux will run on A9 for GUI and signal processing will be done on M4.  I wonder whether A9 running linux and M4 can exhange data. As for amount of data, 4kB/s needs to be sent to A9 from M4 and 1kB/s to M4 from A9.
Ernest
5 回复数
2,235 次查看
joanxie
2,235 次查看
ernestlih
Hello Joan,
Thanks for your answer.
I have decided to use i.MX6 Solo and a seperate DSP instead of using i.MX6 Solox for some reasons.
i.MX6 evaluation board is available only for automotive. My application is for industrial market not for automotive.
Can I purchase a i.MX6 Solo SABRE board?
Ernest
2,235 次查看
joanxie
you can buy imx6DL SDP board
SABRE Platform for Smart Devices|NXP
2,235 次查看
vadimfilippenko
Dear Joan Xie,
1. how can I use second link to rpmsg code?
2. I am running pingpong application OK and I can compile this appl in eclipse for M4 SoloX COM.
But I have some problems to compile for A9/linux. I've built toolchain and other images with bitbake, but can't build the chain in eclipse with headers files like linux/module.h which mentioned in rpmsg example. I can't find out which sources/folders should I use. Could you help me with a piece of advise?
2,235 次查看
joanxie
for the second link the patch I sent to you , one can find the path is "/drivers/rpmsg/Kconfig "
to apply the patch,
rpmsg-sysfs/rpmsg_sysfs_interface.patch at master · codeauroraforum/rpmsg-sysfs · GitHub
