How to check the status of leds in imx8m mini in Android OS
3,721 次查看
Ruban1
How to check the status of leds in imx8m mini in Android OS. Can you provide the path where the status of the leds.
Using minicom. to access sys or proc folder in tat gpio and leds.. I am getting permission denied . i am not able to use sudo also how can i resolve these problem in Android 10. 2.3 OS
7 回复数
3,710 次查看
3,693 次查看
Ruban1
Can you provide exact path where i can find the on board led status
3,681 次查看
default image has not such "path where i can find the on board led status".
3,677 次查看
Ruban1
But in yocto i am able to c the status of on board led. why i am not able to see in Android
3,668 次查看
Android have some higher layers for accessing gpios, it is described in more details on
https://developer.android.com/things/sdk/pio/gpio
https://www.digi.com/resources/documentation/digidocs/embedded/android/oreo/cc6/android_r_apix-gpio
3,555 次查看
Ruban1
both the link is not supported in android studio . Send which will support to create in android app.
i am trying to create an app in Android Studio to directly control of GPIO and I2C and UART. can you kindly provide me recommented document which be used to control the pins through APP and required documents .
3,570 次查看
Ruban1
which you sent is for android things. imx8mm is not supporting the app is getting crashed . there  is no package avaliable for getting the avaliable GPIO
