How to check i.MX7D ARM frequency
1,632 次查看
felixhsu
Hi All
The i.MX7D have multiple power modes, how to check each power mode ARM frequency by Hardware or software, thanks.
1,447 次查看
igorpadykov
Hi Felix
use the following command to view the current CPU frequency in KHz:
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
please check Chapter 23 CPU Frequency Scaling (CPUFREQ) Driver attached Linux Manual
use register CCM_ANALOG_CLK_MISC0, field LVDS1_CLK_SEL, selects the clock to be routed to anaclk1/1b :
0x00 - Arm PLL;
1,448 次查看
igorpadykov
Hi Felix
0x00 - Arm PLL;
