How to change the timer frequency of A53 core in imx8qm board ?
zfreeman2321
And where I can see zhe min ~ max frequency value supported ?
thank you
Zhiming_Liu
Hi @zfreeman2321
I don't sure if you want to know armv8 timer ,which it's source code is located in drivers/clocksource/arm_arch_timer.c
zfreeman2321
I am starting Guest OSes using xen, and I want to know how to set the cpu frequency of A53 core where 'xen' runs
