I can show the kernel and uboot log out when rebooting.
But what I facing the problem is when I using Mfgtool to burn my image I need to see the log but I can't.
I used to use console1 and it can print the log out when I using Mfgtool.
But nowadays our layout had changed the debug port to console0 so I need to change the console.
It is no problem to print the kernel and uboot out when rebooting.
The problem is I can't see any log when I using Mfgtool.
