it depends on which moment you want it to change it.
All i.MX devices feature a first stage boot loader located in ROM called ROM Code which will check where the uboot is located and lauch it, once you are in uboot it is possible to modify the GPIO values.
There is still another option, you cannot modify the ROM Code, but it supports the execution of a plugin image, here you may be able to modify GPIO values before uboot executed.
If you are interested in this last method please let me know and I can share a document draft which explains this option.
Carlos
