How to change resolution for mx8-dsi-oled1 display
1,119件の閲覧回数
Bharat
Hello ,
We are using imx8mmevk board with MX8-DSI-OLED1A display which  is working fine with 1920x1080 resolution.We are using panel-raydium-rm67191 driver for display.
How to change resolution from 1920x1080 to 640x480?
Bharat.
1,113件の閲覧回数
igorpadykov
Hi Bharat
MX8-DSI-OLED1A display is specificed to work with 1920x1080 resolution according to
its datasheet. For 640x480 resolution it is necessary to attach lcd supporting that resolution
and make changes in panel-raydium-rm67191 driver : timings in  struct drm_display_mode default_mode,
initialization sequence in struct cmd_set_entry mcs_rm67191[] :
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/gpu/drm/panel/panel-raydium-rm6719...
