How to change imx8 registers
2,042 次查看
inigovicentewal
I want to know JTAG_MOD in which mode is by default (Test mode to Debug mode) and how it can be changed.
Is it possible to get to the lowest level of the iMX8M mini board with the Dstream debugger or is there any restriction?
标记 (3)
1,965 次查看
Hi Iñigo
JTAG_MOD by default is low according to Table 64. i.MX 8M Mini 14 x 14 mm functional contact assignments
i.MX 8M Mini Applications Processor Datasheet for Consumer Products
Usage is described in Table 7. JTAG recommendations i.MX 8M Mini Hardware Developer’s Guide
and https://community.nxp.com/thread/480454
1,966 次查看
Hi Iñigo
