How to change gadget_multi standard configuration?
2,169 次查看
trongthinh
I modprobe g_multi driver
$ modprobe g_multi file=/dev/mmcblk2p1
On Linux host machine. I found 1 CDC ACM (ttyACM0), 1 RNDS (Ethernet), and Mass Storage. It seems that the driver work correctly, but I need 2 CDC ACM and I don't need MASS STORAGE
How to disable MASS STORAGE and enable 2 CDC ACM (ttyACM0, ttyACM1)?
标签 (3)
标记 (1)
2,040 次查看
nxf63675
Hello trongthinh,
Could you please say me which Kernel version are you using?
Israel.
2,040 次查看
trongthinh
Hi Israel,
My kernel version is 4.19.35-1.1.0+g9370aa309eaf. I have modified some thing in driver, please see patch file below
--- /home/thinhnguyen/***/***/sourceCode/linux-imx/drivers/usb/gadget/legacy/multi.c
+++ /home/thinhnguyen/***/***/Sources/linux-4.19/drivers/usb/gadget/legacy/multi.c
@@ -44,8 +44,8 @@
/***************************** Device Descriptor ****************************/
-#define MULTI_VENDOR_NUM 0x2d6b
-#define MULTI_PRODUCT_NUM 0X0201 /* Multifunction Composite Gadget */
+#define MULTI_VENDOR_NUM 0x1d6b /* Linux Foundation */
+#define MULTI_PRODUCT_NUM 0x0104 /* Multifunction Composite Gadget */
enum {
@@ -363,37 +363,31 @@
goto fail0;
- fi_msg = usb_get_function_instance("acm");
+ /* set up mass storage function */
+ fi_msg = usb_get_function_instance("mass_storage");
if (IS_ERR(fi_msg)) {
status = PTR_ERR(fi_msg);
goto fail1;
- /* set up mass storage function */
- // fi_msg = usb_get_function_instance("mass_storage");
- // if (IS_ERR(fi_msg)) {
- // status = PTR_ERR(fi_msg);
- // goto fail1;
- // fsg_config_from_params(&config, &fsg_mod_data, fsg_num_buffers);
- // fsg_opts = fsg_opts_from_func_inst(fi_msg);
- // fsg_opts->no_configfs = true;
- // status = fsg_common_set_num_buffers(fsg_opts->common, fsg_num_buffers);
- // if (status)
- // goto fail2;
- // status = fsg_common_set_cdev(fsg_opts->common, cdev, config.can_stall);
- // if (status)
- // goto fail_set_cdev;
- // fsg_common_set_sysfs(fsg_opts->common, true);
- // status = fsg_common_create_luns(fsg_opts->common, &config);
- // if (status)
- // fsg_common_set_inquiry_string(fsg_opts->common, config.vendor_name,
- // config.product_name);
+ fsg_config_from_params(&config, &fsg_mod_data, fsg_num_buffers);
+ fsg_opts = fsg_opts_from_func_inst(fi_msg);
+ fsg_opts->no_configfs = true;
+ status = fsg_common_set_num_buffers(fsg_opts->common, fsg_num_buffers);
+ if (status)
+ goto fail2;
+ status = fsg_common_set_cdev(fsg_opts->common, cdev, config.can_stall);
+ if (status)
+ goto fail_set_cdev;
+ fsg_common_set_sysfs(fsg_opts->common, true);
+ status = fsg_common_create_luns(fsg_opts->common, &config);
+ if (status)
+ fsg_common_set_inquiry_string(fsg_opts->common, config.vendor_name,
+ config.product_name);
/* allocate string IDs */
status = usb_string_ids_tab(cdev, strings_dev);
I have 2 ttyGS0/ttyGS1 in /dev/ttyGS* . Both of them work.
