How to change flash partition size
8,465件の閲覧回数
stevenyu
We have built a set of firmware, and use mfg_tool to burn these firmware to NAND flash.
If we include too much modules, then the firmware is too big to put to mtd2 partition (we have confirmed that the total NAND flash size is big enough).
=====mfg_tool burn log=====
UTP: sending Success to kernel for command pipe tar -jxv -C /mnt/mtd3.
tar: write error: No space left on device
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00008d00
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00008d00
We have seen below information when booting, and realize mfg_tool make 32MB size for rootfs.
Do you know where we can modify the size of rootfs, and then we can burn firmware via mfg_tool?
=====include little modules, and boot up=====
Creating 4 MTD partitions on "gpmi-nand":
0x000000000000-0x000004000000 : "boot"
0x000004000000-0x000005000000 : "kernel"
0x000005000000-0x000006000000 : "dtb"
0x000006000000-0x000008000000 : "rootfs"
Steven Yu
8 返答(返信)
5,941件の閲覧回数
Hi Steven
please refer to sect.4.6 Flash memory maps, sect.4.6.2 NAND flash memory map
attached Linux Guide.
5,941件の閲覧回数
stevenyu
Hi igor,
Sorry, it should be explained as below:
1. The original mtdparts is as line#26 in attach log file.
bootargs=console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs)
2. We can easily modify mtdparts as line#66 in attach log file.
bootargs=console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:2m(boot),16m(kernel),2m(dtb),-(rootfs)
3. Then, we use mfg_tool to burn uboot,dtb,kernel,rootfs, but the rootfs is too big to put to rest of flash. We think the mfg_tool cannot see the mtdparts variable, and uboot has been overwrite in the beginning of mfg_tool burning process.
Steven Yu
5,941件の閲覧回数
stevenyu
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Apr 07 2017 - 17:10:42 +0800)
CPU: Freescale i.MX6ULL rev1.0 at 396MHz
CPU: Commercial temperature grade (0C to 95C) at 44C
Reset cause: POR
Board: MX6ULL 14x14 EVK
I2C: ready
DRAM: 512 MiB
NAND: 128 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
Display: TFT43AB (480x272)
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Normal Boot
Hit any key to stop autoboot: 0
=> print
baudrate=115200
board_name=EVK
board_rev=14X14
bootcmd=nand read ${loadaddr} 0x4000000 0x800000;nand read ${fdt_addr} 0x5000000 0x100000;bootz ${loadaddr} - ${fdt_addr}
bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
bootdelay=3
console=ttymxc0
ethact=FEC1
ethaddr=00:04:9f:04:b6:9f
ethprime=FEC
fdt_addr=0x83000000
fdt_high=0xffffffff
initrd_addr=0x83800000
initrd_high=0xffffffff
loadaddr=0x80800000
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs) clk_ignore_unused
panel=TFT43AB
Environment size: 961/131068 bytes
CPU: Commercial temperature grade (0C to 95C) at 50C
Reset cause: POR
I2C: ready
DRAM: 512 MiB
NAND: 128 MiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Normal Boot
=> setenv bootargs 'console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:2m(boot),16m(kernel),2m(dtb),-(rootfs)'
=> printenv
baudrate=115200
board_name=EVK
board_rev=14X14
bootdelay=3
console=ttymxc0
ethact=FEC1
ethprime=FEC
fdt_addr=0x83000000
fdt_high=0xffffffff
loadaddr=0x80800000
panel=TFT43AB
Environment size: 959/131068 bytes
=> saveenv
Saving Environment to NAND...
Erasing NAND...
Erasing at 0x3c00000 -- 100% complete.
Writing to NAND... OK
=> reset
resetting ...
===============use mfg_tool to burn===============
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Sep 16 2016 - 18:51:19 -0500)
CPU: Commercial temperature grade (0C to 95C) at 51C
Reset cause: POR
I2C: ready
DRAM: 512 MiB
NAND: 128 MiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
Kernel image @ 0x80800000 [ 0x000000 - 0x554130 ]
## Loading init Ramdisk from Legacy Image at 83800000 ...
Image Name: fsl-image-mfgtool-initramfs-imx6
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 8591032 Bytes = 8.2 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 83000000, end 8300be76
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.1.15+ (bamboo@yb6) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Fri Sep 16 18:10:49 CDT 2016
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 ULL 14x14 EVK Board
Reserved memory: created CMA memory pool at 0x8c000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
Memory policy: Data cache writealloc
PERCPU: Embedded 12 pages/cpu @8bb32000 s16716 r8192 d24244 u49152
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber= mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs) clk_ignore_unused
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 172392K/524288K available (6903K kernel code, 320K rwdata, 2416K rodata, 384K init, 423K bss, 24216K reserved, 327680K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80921fd8 (9320 kB)
.init : 0x80922000 - 0x80982000 ( 384 kB)
.data : 0x80982000 - 0x809d2080 ( 321 kB)
.bss : 0x809d5000 - 0x80a3ee54 ( 424 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
Additional per-CPU info printed with stalls.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS:16 nr_irqs:16 16
mxc_clocksource_init 24000000
Switching to timer-based delay loop, resolution 41ns
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
/cpus/cpu@0 missing clock-frequency property
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80008280 - 0x800082f0
Brought up 1 CPUs
SMP: Total of 1 processors activated (48.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
mxs-dma 1804000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 8392K (83800000 - 84032000)
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) 穢 2001-2006 Red Hat, Inc.
fuse init (API version 7.23)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
21c8000.lcdif supply lcd not found, using dummy regulator
mxsfb 21c8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 60x34
mxsfb 21c8000.lcdif: initialized
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.3
imx-sdma 20ec000.sdma: initialized
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 19, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 234, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xf1
nand: Micron MT29F1G08ABAEAWP
nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
4 cmdlinepart partitions found on MTD device gpmi-nand
gpmi-nand 1806000.gpmi-nand: driver registered.
20b4000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 20b4000.ethernet eth0: registered PHC device 0
2188000.ethernet supply phy not found, using dummy regulator
pps pps1: new PPS source ptp1
fec 2188000.ethernet eth1: registered PHC device 1
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
2184000.usb supply vbus not found, using dummy regulator
2184200.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Mass Storage Function, version: 2009/09/11
LUN: removable file: (no medium)
LUN: removable read only file: /fat
Number of LUNs=1
Number of LUNs=1
g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
g_mass_storage gadget: g_mass_storage ready
mousedev: PS/2 mouse device common for all mice
input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
input: iMX6UL TouchScreen Controller as /devices/platform/soc/2000000.aips-bus/2040000.tsc/input/input1
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
pxp-v4l2 pxp_v4l2: initialized
imx2-wdt 20bc000.wdog: use WDOG_B to reboot.
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Key type dns_resolver registered
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
Registering SWP/SWPB emulation handler
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
VSD_3V3: disabling
can-3v3: disabling
clk: Not disabling unused clocks
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 384K (80922000 - 80982000)
Starting UTP
uuc 0.5 [built Sep 16 2016 02:36:28]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
UTP: received command '$ mount -t debugfs debugfs /sys/kernel/debug'
UTP: executing "mount -t debugfs debugfs /sys/kernel/debug"
UTP: sending Success to kernel for command $ mount -t debugfs debugfs /sys/kernel/debug.
utp_poll: pass returned.
UTP: received command '$ ls -al /sys/kernel/debug'
UTP: executing "ls -al /sys/kernel/debug"
total 0
drwx------ 22 root root 0 Jan 1 00:00 .
drwxr-xr-x 7 root root 0 Jan 1 00:00 ..
drwxr-xr-x 2 root root 0 Jan 1 1970 asoc
drwxr-xr-x 31 root root 0 Jan 1 00:00 bdi
drwxr-xr-x 2 root root 0 Jan 1 1970 ci_hdrc.0
drwxr-xr-x 2 root root 0 Jan 1 1970 ci_hdrc.1
drwxr-xr-x 223 root root 0 Jan 1 00:00 clk
drwxr-xr-x 2 root root 0 Jan 1 00:00 dma_buf
drwxr-xr-x 3 root root 0 Jan 1 1970 dri
drwxr-xr-x 2 root root 0 Jan 1 1970 extfrag
-rw-r--r-- 1 root root 0 Jan 1 1970 fault_around_bytes
-r--r--r-- 1 root root 0 Jan 1 00:00 gpio
drwxr-xr-x 2 root root 0 Jan 1 1970 gpmi-nand
drwxr-xr-x 2 root root 0 Jan 1 1970 hid
drwxr-xr-x 2 root root 0 Jan 1 00:00 ieee80211
drwxr-xr-x 2 root root 0 Jan 1 1970 memblock
drwxr-xr-x 2 root root 0 Jan 1 1970 mmc0
drwxr-xr-x 4 root root 0 Jan 1 00:00 pinctrl
drwxr-xr-x 2 root root 0 Jan 1 1970 pm_qos
-r--r--r-- 1 root root 0 Jan 1 00:00 pwm
drwxr-xr-x 3 root root 0 Jan 1 00:00 regmap
drwxr-xr-x 8 root root 0 Jan 1 00:00 regulator
-r--r--r-- 1 root root 0 Jan 1 1970 sleep_time
-r--r--r-- 1 root root 0 Jan 1 1970 suspend_stats
drwxr-xr-x 2 root root 0 Jan 1 1970 ubi
drwxr-xr-x 2 root root 0 Jan 1 1970 ubifs
drwxr-xr-x 2 root root 0 Jan 1 00:00 usb
-r--r--r-- 1 root root 0 Jan 1 00:00 wakeup_sources
UTP: sending Success to kernel for command $ ls -al /sys/kernel/debug.
UTP: received command '$ ls -al /dev/mtd*'
UTP: executing "ls -al /dev/mtd*"
crw------- 1 root root 90, 0 Jan 1 1970 /dev/mtd0
crw------- 1 root root 90, 1 Jan 1 1970 /dev/mtd0ro
crw------- 1 root root 90, 2 Jan 1 1970 /dev/mtd1
crw------- 1 root root 90, 3 Jan 1 1970 /dev/mtd1ro
crw------- 1 root root 90, 4 Jan 1 1970 /dev/mtd2
crw------- 1 root root 90, 5 Jan 1 1970 /dev/mtd2ro
crw------- 1 root root 90, 6 Jan 1 1970 /dev/mtd3
crw------- 1 root root 90, 7 Jan 1 1970 /dev/mtd3ro
brw------- 1 root root 31, 0 Jan 1 1970 /dev/mtdblock0
brw------- 1 root root 31, 1 Jan 1 1970 /dev/mtdblock1
brw------- 1 root root 31, 2 Jan 1 1970 /dev/mtdblock2
brw------- 1 root root 31, 3 Jan 1 1970 /dev/mtdblock3
UTP: sending Success to kernel for command $ ls -al /dev/mtd*.
UTP: received command '$ flash_erase /dev/mtd0 0 0'
UTP: executing "flash_erase /dev/mtd0 0 0"
Erasing 128 Kibyte @ 3d20000 -- 95 % utp_poll: pass returned.
Erasing 128 Kibyte @ 3fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd0 0 0.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE'
UTP: executing "kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE"
MTD CONFIG:
chip_0_device_path = "/dev/mtd0"
chip_1_device_path = "(null)"
search_exponent = 2
data_setup_time = 80
data_hold_time = 60
address_setup_time = 25
data_sample_time = 6
row_address_size = 3
column_address_size = 2
read_command_code1 = 0
read_command_code2 = 48
boot_stream_major_version = 1
boot_stream_minor_version = 0
boot_stream_sub_version = 0
ncb_version = 3
boot_stream_1_address = 0
boot_stream_2_address = 0
-- We add the 1k-padding to the uboot.
.tmp_kobs_ng: verifying using key '00000000000000000000000000000000'
.tmp_kobs_ng: is a valid bootstream for key '00000000000000000000000000000000'
mtd: use new bch layout raw access mode
mtd: opening: "/dev/mtd0"
NFC geometry :
ECC Strength : 4
Page Size in Bytes : 2084
Metadata size : 10
ECC Chunk Size in byte : 512
ECC Chunk count : 4
Block Mark Byte Offset : 2018
Block Mark Bit Offset : 4
mtd: opened '/dev/mtd0' - '(null)'
mtd: max_boot_stream_size_in_bytes = 33030144
mtd: boot_stream_size_in_bytes = 475136
mtd: boot_stream_size_in_pages = 232
mtd: #1 0x00100000 - 0x02080000 (0x00174000)
mtd: #2 0x02080000 - 0x04000000 (0x020f4000)
FCB
m_u32Checksum = 0x00000000
m_u32FingerPrint = 0x20424346
m_u32Version = 0x01000000
m_NANDTiming.m_u8DataSetup = 80
m_NANDTiming.m_u8DataHold = 60
m_NANDTiming.m_u8AddressSetup = 25
m_NANDTiming.m_u8DSAMPLE_TIME = 6
m_u32PageDataSize = 2048
m_u32TotalPageSize = 2112
m_u32SectorsPerBlock = 64
m_u32NumberOfNANDs = 0
m_u32TotalInternalDie = 0
m_u32CellType = 0
m_u32EccBlockNEccType = 2
m_u32EccBlock0Size = 512
m_u32EccBlockNSize = 512
m_u32EccBlock0EccType = 2
m_u32MetadataBytes = 10
m_u32NumEccBlocksPerPage = 3
m_u32EccBlockNEccLevelSDK = 0
m_u32EccBlock0SizeSDK = 0
m_u32EccBlockNSizeSDK = 0
m_u32EccBlock0EccLevelSDK = 0
m_u32NumEccBlocksPerPageSDK = 0
m_u32MetadataBytesSDK = 0
m_u32EraseThreshold = 0
m_u32Firmware1_startingPage = 512
m_u32Firmware2_startingPage = 16640
m_u32PagesInFirmware1 = 232
m_u32PagesInFirmware2 = 232
m_u32DBBTSearchAreaStartAddress = 256
m_u32BadBlockMarkerByte = 2018
m_u32BadBlockMarkerStartBit = 4
m_u32BBMarkerPhysicalOffset = 2048
m_u32BCHType = 0
m_NANDTMTiming.m_u32TMTiming2_ReadLatency = 0
m_NANDTMTiming.m_u32TMTiming2_PreambleDelay = 0
m_NANDTMTiming.m_u32TMTiming2_CEDelay = 0
m_NANDTMTiming.m_u32TMTiming2_PostambleDelay = 0
m_NANDTMTiming.m_u32TMTiming2_CmdAddPause = 0
m_NANDTMTiming.m_u32TMTiming2_DataPause = 0
m_NANDTMTiming.m_u32TMSpeed = 0
m_NANDTMTiming.m_u32TMTiming1_BusyTimeout = 0
m_u32DISBBM = 0
m_u32BBMarkerPhysicalOffsetInSpareData = 0
m_u32OnfiSyncEnable = 0
m_NANDONFITiming.m_u32ONFISpeed = 0
m_NANDONFITiming.m_u32ONFITiming_ReadLatency = 0
m_NANDONFITiming.m_u32ONFITiming_CEDelay = 0
m_NANDONFITiming.m_u32ONFITiming_PreambleDelay = 0
m_NANDONFITiming.m_u32ONFITiming_PostambleDelay = 0
m_NANDONFITiming.m_u32ONFITiming_CmdAddPause = 0
m_NANDONFITiming.m_u32ONFITiming_DataPause = 0
m_NANDONFITiming.m_u32ONFITiming_BusyTimeout = 0
m_u32DISBBSearch = 0
m_u32RandomizerEnable = 0
m_u32ReadRetryEnable = 0
m_u32ReadRetrySeqLength = 0
DBBT
m_u32FingerPrint = 0x54424244
m_u32DBBTNumOfPages = 0
Firmware: image #0 @ 0x100000 size 0x74000 - available 0x1f80000
Firmware: image #1 @ 0x2080000 size 0x74000 - available 0x1f80000
-------------- Start to write the [ FCB ] -----
mtd: erasing @0:0x0-0x20000
mtd: Writing FCB0 [ @0:0x0 ] (840) *
mtd: erasing @0:0x20000-0x40000
mtd: Writing FCB1 [ @0:0x20000 ] (840) *
mtd: erasing @0:0x40000-0x60000
mtd: Writing FCB2 [ @0:0x40000 ] (840) *
mtd: erasing @0:0x60000-0x80000
mtd: Writing FCB3 [ @0:0x60000 ] (840) *
mtd_commit_bcb(FCB): status 0
-------------- Start to write the [ DBBT ] -----
mtd: erasing @0:0x80000-0xa0000
mtd: Writing DBBT0 [ @0:0x80000 ] (800) *
mtd: erasing @0:0xa0000-0xc0000
mtd: Writing DBBT1 [ @0:0xa0000 ] (800) *
mtd: erasing @0:0xc0000-0xe0000
mtd: Writing DBBT2 [ @0:0xc0000 ] (800) *
mtd: erasing @0:0xe0000-0x100000
mtd: Writing DBBT3 [ @0:0xe0000 ] (800) *
mtd_commit_bcb(DBBT): status 0
---------- Start to write the [ .tmp_kobs_ng ]----
mtd: Writting .tmp_kobs_ng: #0 @0: 0x00100000 - 0x00174000
mtd: erasing @0:0x100000-0x120000
mtd: erasing @0:0x120000-0x140000
mtd: erasing @0:0x140000-0x160000
mtd: erasing @0:0x160000-0x180000
mtd: We write one page for save guard. *
mtd: Writting .tmp_kobs_ng: #1 @0: 0x02080000 - 0x020f4000
mtd: erasing @0:0x2080000-0x20a0000
mtd: erasing @0:0x20a0000-0x20c0000
random: nonblocking pool is initialized
mtd: erasing @0:0x20c0000-0x20e0000
mtd: erasing @0:0x20e0000-0x2100000
UTP: sending Success to kernel for command $ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE.
UTP: received command '$ flash_erase /dev/mtd1 0 0'
UTP: executing "flash_erase /dev/mtd1 0 0"
Erasing 128 Kiutp_poll: pass returned.mplete
Erasing 128 Kibyte @ fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd1 0 0.
UTP: received command '$ nandwrite -p /dev/mtd1 -p $FILE'
UTP: executing "nandwrite -p /dev/mtd1 -p $FILE"
Writing data to block 0 at offset 0x0
Writing data to block 1 at offset 0x20000
Writing data to block 2 at offset 0x40000
Writing data to block 3 at offset 0x60000
Writing data to block 4 at offset 0x80000
Writing data to block 5 at offset 0xa0000
Writing data to block 6 at offset 0xc0000
Writing data to block 7 at offset 0xe0000
Writing data to block 8 at offset 0x100000
Writing data to block 9 at offset 0x120000
Writing data to block 10 at offset 0x140000
Writing data to block 11 at offset 0x160000
Writing data to block 12 at offset 0x180000
Writing data to block 13 at offset 0x1a0000
Writing data to block 14 at offset 0x1c0000
Writing data to block 15 at offset 0x1e0000
Writing data to block 16 at offset 0x200000
Writing data to block 17 at offset 0x220000
Writing data to block 18 at offset 0x240000
Writing data to block 19 at offset 0x260000
Writing data to block 20 at offset 0x280000
Writing data to block 21 at offset 0x2a0000
Writing data to block 22 at offset 0x2c0000
Writing data to block 23 at offset 0x2e0000
Writing data to block 24 at offset 0x300000
Writing data to block 25 at offset 0x320000
Writing data to block 26 at offset 0x340000
Writing data to block 27 at offset 0x360000
Writing data to block 28 at offset 0x380000
Writing data to block 29 at offset 0x3a0000
Writing data to block 30 at offset 0x3c0000
Writing data to block 31 at offset 0x3e0000
Writing data to block 32 at offset 0x400000
Writing data to block 33 at offset 0x420000
Writing data to block 34 at offset 0x440000
Writing data to block 35 at offset 0x460000
Writing data to block 36 at offset 0x480000
Writing data to block 37 at offset 0x4a0000
Writing data to block 38 at offset 0x4c0000
Writing data to block 39 at offset 0x4e0000
Writing data to block 40 at offset 0x500000
Writing data to block 41 at offset 0x520000
Writing data to block 42 at offset 0x540000
Writing data to block 43 at offset 0x560000
Writing data to block 44 at offset 0x580000
Writing data to block 45 at offset 0x5a0000
Writing data to block 46 at offset 0x5c0000
Writing data to block 47 at offset 0x5e0000
Writing data to block 48 at offset 0x600000
Writing data to block 49 at offset 0x620000
Writing data to block 50 at offset 0x640000
UTP: sending Success to kernel for command $ nandwrite -p /dev/mtd1 -p $FILE.
UTP: received command '$ flash_erase /dev/mtd2 0 0'
UTP: executing "flash_erase /dev/mtd2 0 0"
UTP: sending Success to kernel for command $ flash_erase /dev/mtd2 0 0.
UTP: received command '$ nandwrite -p /dev/mtd2 -p $FILE'
UTP: executing "nandwrite -p /dev/mtd2 -p $FILE"
UTP: sending Success to kernel for command $ nandwrite -p /dev/mtd2 -p $FILE.
UTP: received command '$ flash_erase /dev/mtd3 0 0'
UTP: executing "flash_erase /dev/mtd3 0 0"
utp_poll: pass returned.0000 -- 94 % complete
Erasing 128 Kibyte @ 1f60000 -- 98 % complete flash_erase: Skipping bad block at 01f80000
flash_erase: Skipping bad block at 01fa0000
flash_erase: Skipping bad block at 01fc0000
flash_erase: Skipping bad block at 01fe0000
Erasing 128 Kibyte @ 1fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd3 0 0.
UTP: received command '$ ubiformat /dev/mtd3'
UTP: executing "ubiformat /dev/mtd3"
ubiformat: mtd3 (nand), size 33554432 bytes (32.0 MiB), 256 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 255 -- 100 % complete
ubiformat: 252 eraseblocks are supposedly empty
ubiformat: 4 bad eraseblocks found, numbers: 252, 253, 254, 255
ubiformat: formatting eraseblock 255 -- 100 % complete
UTP: sending Success to kernel for command $ ubiformat /dev/mtd3.
UTP: received command '$ ubiattach /dev/ubi_ctrl -m 3'
UTP: executing "ubiattach /dev/ubi_ctrl -m 3"
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "rootfs", size 32 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 252, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 1614893800
ubi0: available PEBs: 232, total reserved PEBs: 20, PEBs reserved for bad PEB handling: 16
ubi0: background thread "ubi_bgt0d" started, PID 67
UBI device number 0, total 252 LEBs (31997952 bytes, 30.5 MiB), available 232 LEBs (29458432 bytes, 28.1 MiB), LEB size 126976 bytes (124.0 KiB)
UTP: sending Success to kernel for command $ ubiattach /dev/ubi_ctrl -m 3.
UTP: received command '$ ubimkvol /dev/ubi0 -Nrootfs -m'
UTP: executing "ubimkvol /dev/ubi0 -Nrootfs -m"
Set volume size to 29458432
Volume ID 0, size 232 LEBs (29458432 bytes, 28.1 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "rootfs", alignment 1
UTP: sending Success to kernel for command $ ubimkvol /dev/ubi0 -Nrootfs -m.
UTP: received command '$ mkdir -p /mnt/mtd3'
UTP: executing "mkdir -p /mnt/mtd3"
UTP: sending Success to kernel for command $ mkdir -p /mnt/mtd3.
UTP: received command '$ mount -t ubifs ubi0:rootfs /mnt/mtd3'
UTP: executing "mount -t ubifs ubi0:rootfs /mnt/mtd3"
UBIFS (ubi0:0): default file-system created
UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 71
UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi0:0): FS size: 28188672 bytes (26 MiB, 222 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
UBIFS (ubi0:0): reserved for root: 1331420 bytes (1300 KiB)
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 248DCFDA-C1D7-4A9B-B97A-BFE5F8895F70, small LPT model
UTP: sending Success to kernel for command $ mount -t ubifs ubi0:rootfs /mnt/mtd3.
UTP: received command 'pipe tar -jxv -C /mnt/mtd3'
pid is 72, UTP: executing "tar -jxv -C /mnt/mtd3"
./sys/
./run/
./dev/
./mnt/
./mnt/.psplash/
./home/
./home/root/
./bin/
./bin/netstat
./bin/more
./bin/zcat
./bin/ps
./bin/egrep
./bin/umount
./bin/cp
./bin/stty
./bin/run-parts
./bin/fgrep
./bin/cpio
./bin/mv
./bin/tar
./bin/false
./bin/grep
./bin/mountpoint.sysvinit
./bin/pidof
./bin/usleep
./bin/df
./bin/echo
./bin/pidof.sysvinit
./bin/busybox.nosuid
./bin/mount
./bin/dmesg
./bin/cat
./bin/sync
./bin/dnsdomainname
./bin/dd
./bin/login.shadow
./bin/ls
./bin/date
./bin/ash
./bin/stat
./bin/dumpkmap
./bin/sleep
./bin/su
./bin/ping6
./bin/chattr
./bin/sed
./bin/rm
./bin/chmod
./bin/busybox.suid
./bin/vi
./bin/pwd
./bin/kill
./bin/lsmod
./bin/mknod
./bin/watch
./bin/mktemp
./bin/chgrp
./bin/start_getty
./bin/kmod
./bin/sh
./bin/mkdir
./bin/ln
./bin/uname
./bin/hostname
./bin/login
./bin/mountpoint
./bin/gunzip
./bin/bash
./bin/ping
./bin/getopt
./bin/chown
./bin/lsmod.kmod
./bin/rmdir
./bin/touch
./bin/su.shadow
./bin/true
./bin/busybox
./bin/gzip
./lib/
./lib/libtinfo.so.5.9
./lib/modules/
./lib/modules/4.1.15-2.0.1+gb63f3f5/
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.dep
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/libcrc32c.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc7.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc-itu-t.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc-ccitt.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/binfmt_misc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/configfs/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/configfs/configfs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/isofs/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/isofs/isofs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/udf/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/udf/udf.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/nls/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/nls/nls_iso8859-15.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/fat/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/fat/msdos.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/crypto/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/crypto/tcrypt.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/snd-usbmidi-lib.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/snd-usb-audio.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/snd-hwdep.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/snd-rawmidi.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/libcomposite.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_serial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ncm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_eem.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_acm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_fs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/u_ether.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_obex.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/u_serial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/g_serial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/g_zero.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/g_mass_storage.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/gadgetfs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/g_ncm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/legacy/g_ether.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/class/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/class/cdc-acm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/serial/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/serial/option.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/serial/usb_wwan.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/serial/usbserial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/serial/ftdi_sio.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/mouse/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/mouse/psmouse.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/evbug.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/serio/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/input/serio/serport.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/i2c/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/i2c/algos/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/i2c/algos/i2c-algo-pca.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/i2c/algos/i2c-algo-pcf.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/dma/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/dma/dmatest.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/video/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/video/fbdev/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/video/fbdev/mxc/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/video/fbdev/mxc/mxc_dcic.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/usbnet.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/asix.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/net1080.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/rtl8150.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/r8152.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/zaurus.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/cdc_ncm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/ax88179_178a.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/cdc_subset.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/cdc_ether.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/cdc_eem.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/net/usb/pegasus.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/ov5640_camera.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/ov5647_camera_mipi.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/mxc_mipi_csi.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/ov5640_camera_mipi.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/mxc_vadc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/subdev/mx6s_capture.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ov5640_camera_int.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ov5642_camera.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ipu_csi_enc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ipu_bg_overlay_sdc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/mxc_v4l2_capture.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/adv7180_tvin.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/v4l2-int-device.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ipu_prp_enc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ipu_still.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ipu_fg_overlay_sdc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/platform/mxc/capture/ov5640_camera_mipi_int.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/usb/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/usb/gspca/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/usb/gspca/gspca_main.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/usb/uvc/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/media/usb/uvc/uvcvideo.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/rpmsg/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/rpmsg/imx_rpmsg_tty.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/rpmsg/imx_rpmsg_pingpong.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.alias.bin
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.builtin
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.builtin.bin
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.devname
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.symbols.bin
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.order
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.dep.bin
./lib/modules/4.1.15-2.0.1+gb63f3f5/modules.softdep
./lib/libz.so.1.2.8
./lib/libc-2.23.so
./lib/libBrokenLocale.so.1
./lib/libudev.so.1.6.3
./lib/libuuid.so.1.3.0
./lib/libnss_mdns.so.2
./lib/libnss_dns-2.23.so
./lib/libcrypt.so.1
./lib/libBrokenLocale-2.23.so
./lib/libgcc_s.so.1
./lib/libnss_files-2.23.so
./lib/libnss_mdns6.so.2
./lib/udev/
./lib/udev/mtd_probe
./lib/udev/rules.d/
./lib/udev/rules.d/50-udev-default.rules
./lib/udev/rules.d/60-block.rules
./lib/udev/rules.d/60-serial.rules
./lib/udev/rules.d/60-persistent-storage.rules
./lib/udev/rules.d/90-alsa-restore.rules
./lib/udev/rules.d/97-hid2hci.rules
./lib/udev/rules.d/70-mouse.rules
./lib/udev/rules.d/60-persistent-alsa.rules
./lib/udev/rules.d/50-firmware.rules
./lib/udev/rules.d/75-probe_mtd.rules
./lib/udev/rules.d/80-drivers.rules
./lib/udev/rules.d/64-btrfs.rules
./lib/udev/rules.d/78-sound-card.rules
./lib/udev/rules.d/60-persistent-v4l.rules
./lib/udev/rules.d/60-persistent-input.rules
./lib/udev/rules.d/60-persistent-storage-tape.rules
./lib/udev/rules.d/60-evdev.rules
./lib/udev/rules.d/75-net-description.rules
./lib/udev/rules.d/80-net-name-slot.rules
./lib/udev/rules.d/60-drm.rules
./lib/udev/rules.d/60-cdrom_id.rules
./lib/udev/v4l_id
./lib/udev/ata_id
./lib/udev/cdrom_id
./lib/udev/collect
./lib/udev/scsi_id
./lib/udev/hid2hci
./lib/libnsl-2.23.so
./lib/libutil.so.1
./lib/libuuid.so.1
./lib/libm-2.23.so
./lib/libnss_mdns_minimal.so.2
./lib/librt.so.1
./lib/libdl-2.23.so
./lib/libsysfs.so.2
./lib/libanl.so.1
./lib/libresolv.so.2
./lib/libnss_compat-2.23.so
./lib/libm.so.6
./lib/libnss_mdns6_minimal.so.2
./lib/libnss_dns.so.2
./lib/libpthread-2.23.so
./lib/libnss_mdns4.so.2
./lib/libblkid.so.1
./lib/libnss_files.so.2
./lib/libz.so.1
./lib/libusb-1.0.so.0
./lib/libcap.so.2.24
./lib/firmware/
./lib/firmware/bcm/
./lib/firmware/bcm/ZP_BCM4339/
./lib/firmware/bcm/ZP_BCM4339/bcmdhd.ZP.SDIO.cal
./lib/firmware/bcm/ZP_BCM4339/bcmdhd.ZP.OOB.cal
./lib/firmware/bcm/ZP_BCM4339/fw_bcmdhd.bin
./lib/firmware/bcm/ZP_BCM4339/fw_bcmdhd_apsta.bin
./lib/firmware/bcm/SN8000_BCM43362/
./lib/firmware/bcm/SN8000_BCM43362/bcmdhd.SN8000.OOB.cal
./lib/firmware/bcm/SN8000_BCM43362/fw_bcmdhd.bin
./lib/firmware/bcm/SN8000_BCM43362/fw_bcmdhd_apsta.bin
./lib/firmware/bcm/SN8000_BCM43362/bcmdhd.SN8000.SDIO.cal
./lib/firmware/bcm/1DX_BCM4343W/
./lib/firmware/bcm/1DX_BCM4343W/fw_bcmdhd.bin
./lib/firmware/bcm/1DX_BCM4343W/bcmdhd.1DX.SDIO.cal
./lib/firmware/bcm/1DX_BCM4343W/bcmdhd.1DX.OOB.cal
./lib/firmware/bcm/1BW_BCM43340/
./lib/firmware/bcm/1BW_BCM43340/fw_bcmdhd.bin
./lib/firmware/bcm/1BW_BCM43340/bcmdhd.1BW.SDIO.cal
./lib/firmware/bcm/1BW_BCM43340/bcmdhd.1BW.OOB.cal
./lib/firmware/imx/
./lib/firmware/imx/epdc/
./lib/firmware/imx/epdc/epdc_E97_V110.fw
./lib/firmware/imx/epdc/epdc_E60_V110.fw
./lib/firmware/imx/epdc/epdc_ED060XH2C1.fw
./lib/firmware/imx/epdc/epdc_E060SCM.fw
./lib/firmware/imx/epdc/epdc_E60_V220.fw
./lib/ld-2.23.so
./lib/libcap.so.2
./lib/libc.so.6
./lib/libnsl.so.1
./lib/libcrypt-2.23.so
./lib/libncursesw.so.5
./lib/libnss_compat.so.2
./lib/libsysfs.so.2.0.1
./lib/libusb-1.0.so.0.1.0
./lib/libncursesw.so.5.9
./lib/libutil-2.23.so
./lib/libtinfo.so.5
./lib/librt-2.23.so
./lib/modprobe.d/
./lib/ld-linux-armhf.so.3
./lib/depmod.d/
./lib/depmod.d/search.conf
./lib/libdl.so.2
./lib/libresolv-2.23.so
./lib/libpthread.so.0
./lib/libudev.so.1
./lib/libnss_mdns4_minimal.so.2
./lib/libblkid.so.1.1.0
./lib/libanl-2.23.so
./etc/
./etc/avahi/
./etc/avahi/avahi-daemon.conf
./etc/avahi/hosts
./etc/avahi/services/
./etc/avahi/services/ssh.service
./etc/avahi/services/sftp-ssh.service
./etc/syslog.conf
./etc/default/
./etc/default/devpts
./etc/default/volatiles/
./etc/default/volatiles/01_bootlogd
./etc/default/volatiles/99_wpa_supplicant
./etc/default/volatiles/99_dbus
./etc/default/volatiles/00_core
./etc/default/apmd
./etc/default/usbd
./etc/default/useradd
./etc/default/postinst
./etc/default/udev-cache
./etc/default/rcS
./etc/skel/
./etc/skel/.profile
./etc/skel/.bashrc
./etc/ld.so.conf
./etc/rcS.d/
./etc/rcS.d/S39hostname.sh
./etc/rcS.d/S06alignment.sh
./etc/rcS.d/S05modutils.sh
./etc/rcS.d/S38dmesg.sh
./etc/rcS.d/S00psplash.sh
./etc/rcS.d/S38urandom
./etc/rcS.d/S37populate-volatile.sh
./etc/rcS.d/S36udev-cache
./etc/rcS.d/S04udev
./etc/rcS.d/S55bootmisc.sh
./etc/rcS.d/S02banner.sh
./etc/rcS.d/S02sysfs.sh
./etc/rcS.d/S38devpts.sh
./etc/rcS.d/S06checkroot.sh
./etc/rcS.d/S07bootlogd
./etc/rcS.d/S29read-only-rootfs-hook.sh
./etc/rcS.d/S39alsa-state
./etc/rcS.d/S03mountall.sh
./etc/inittab
./etc/ld.so.cache
./etc/init.d/
./etc/init.d/alsa-state
./etc/init.d/dmesg.sh
./etc/init.d/bootmisc.sh
./etc/init.d/mountall.sh
./etc/init.d/ofono
./etc/init.d/udev
./etc/init.d/psplash.sh
./etc/init.d/banner.sh
./etc/init.d/reboot
./etc/init.d/read-only-rootfs-hook.sh
./etc/init.d/checkroot.sh
./etc/init.d/rpcbind
./etc/init.d/syslog.busybox
./etc/init.d/run-postinsts
./etc/init.d/rmnologin.sh
./etc/init.d/halt
./etc/init.d/neard
./etc/init.d/umountfs
./etc/init.d/modutils.sh
./etc/init.d/umountnfs.sh
./etc/init.d/urandom
./etc/init.d/single
./etc/init.d/bluetooth
./etc/init.d/apmd
./etc/init.d/dbus-1
./etc/init.d/udev-cache
./etc/init.d/hostname.sh
./etc/init.d/functions.initscripts
./etc/init.d/networking
./etc/init.d/syslog
./etc/init.d/hwclock.sh
./etc/init.d/stop-bootlogd
./etc/init.d/alignment.sh
./etc/init.d/rcS
./etc/init.d/mountnfs.sh
./etc/init.d/sendsigs
./etc/init.d/devpts.sh
./etc/init.d/populate-volatile.sh
./etc/init.d/bootlogd
./etc/init.d/save-rtc.sh
./etc/init.d/avahi-daemon
./etc/init.d/sysfs.sh
./etc/init.d/rc
./etc/rc6.d/
./etc/rc6.d/K22ofono
./etc/rc6.d/S31umountnfs.sh
./etc/rc6.d/S90reboot
./etc/rc6.d/K80networking
./etc/rc6.d/K20apmd
./etc/rc6.d/K20psplash.sh
./etc/rc6.d/S20sendsigs
./etc/rc6.d/K19avahi-daemon
./etc/rc6.d/K20syslog
./etc/rc6.d/S38urandom
./etc/rc6.d/S25save-rtc.sh
./etc/rc6.d/K20hwclock.sh
./etc/rc6.d/K60rpcbind
./etc/rc6.d/K31alsa-state
./etc/rc6.d/S40umountfs
./etc/rc6.d/K20dbus-1
./etc/rc6.d/K20bluetooth
./etc/rc6.d/K64neard
./etc/ofono/
./etc/ofono/phonesim.conf
./etc/rc4.d/
./etc/rc4.d/S22ofono
./etc/rc4.d/S20apmd
./etc/rc4.d/S99stop-bootlogd
./etc/rc4.d/S12rpcbind
./etc/rc4.d/S15mountnfs.sh
./etc/rc4.d/S20syslog
./etc/rc4.d/S64neard
./etc/rc4.d/S01networking
./etc/rc4.d/S99rmnologin.sh
./etc/rc4.d/S20hwclock.sh
./etc/rc4.d/S21avahi-daemon
./etc/terminfo/
./etc/terminfo/r/
./etc/terminfo/r/rxvt
./etc/terminfo/x/
./etc/terminfo/x/xterm-color
./etc/terminfo/x/xterm-xfree86
./etc/terminfo/x/xterm-256color
./etc/terminfo/s/
./etc/terminfo/s/screen
./etc/terminfo/s/screen-256color
./etc/terminfo/s/sun
./etc/terminfo/l/
./etc/terminfo/l/linux
./etc/terminfo/d/
./etc/terminfo/d/dumb
./etc/terminfo/v/
./etc/terminfo/v/vt100
./etc/terminfo/v/vt52
./etc/terminfo/v/vt200
./etc/terminfo/v/vt220
./etc/terminfo/v/vt102
./etc/terminfo/a/
./etc/terminfo/a/ansi
./etc/udev/
./etc/udev/rules.d/
./etc/udev/rules.d/local.rules
./etc/udev/rules.d/10-imx.rules
./etc/udev/rules.d/50-firmware.rules
./etc/udev/rules.d/80-net-name-slot.rules
./etc/udev/cache.data
./etc/udev/udev.conf
./etc/rpcbind.conf
./etc/shadow-
./etc/securetty
./etc/logrotate-dmesg.conf
./etc/rc2.d/
./etc/rc2.d/S22ofono
./etc/rc2.d/S20apmd
./etc/rc2.d/S99stop-bootlogd
./etc/rc2.d/S12rpcbind
./etc/rc2.d/S15mountnfs.sh
./etc/rc2.d/S20syslog
./etc/rc2.d/S02dbus-1
./etc/rc2.d/S64neard
./etc/rc2.d/S01networking
./etc/rc2.d/S99rmnologin.sh
./etc/rc2.d/S20hwclock.sh
./etc/rc2.d/S21avahi-daemon
./etc/shells
./etc/issue.net
./etc/network/
./etc/network/if-post-down.d/
./etc/network/if-post-down.d/wpa-supplicant
./etc/network/if-up.d/
./etc/network/interfaces
./etc/network/if-pre-up.d/
./etc/network/if-pre-up.d/nfsroot
./etc/network/if-pre-up.d/wpa-supplicant
./etc/network/if-down.d/
./etc/rpm/
./etc/rpm/platform
./etc/rpm/sysinfo/
./etc/rpm/sysinfo/Dirnames
./etc/shadow
./etc/apm/
./etc/apm/resume.d/
./etc/apm/scripts.d/
./etc/apm/suspend.d/
./etc/apm/apmd_proxy
./etc/apm/other.d/
./etc/apm/event.d/
./etc/syslog-startup.conf
./etc/issue
./etc/busybox.links.suid
./etc/protocols
./etc/group-
./etc/rc3.d/
./etc/rc3.d/S22ofono
./etc/rc3.d/S20apmd
./etc/rc3.d/S99stop-bootlogd
./etc/rc3.d/S12rpcbind
./etc/rc3.d/S15mountnfs.sh
./etc/rc3.d/S20syslog
./etc/rc3.d/S02dbus-1
./etc/rc3.d/S64neard
./etc/rc3.d/S01networking
./etc/rc3.d/S99rmnologin.sh
./etc/rc3.d/S20hwclock.sh
./etc/rc3.d/S21avahi-daemon
./etc/limits
./etc/rc5.d/
./etc/rc5.d/S22ofono
./etc/rc5.d/S20apmd
./etc/rc5.d/S99stop-bootlogd
./etc/rc5.d/S12rpcbind
./etc/rc5.d/S15mountnfs.sh
./etc/rc5.d/S20syslog
./etc/rc5.d/S02dbus-1
./etc/rc5.d/S64neard
./etc/rc5.d/S01networking
./etc/rc5.d/S99rmnologin.sh
./etc/rc5.d/S20hwclock.sh
./etc/rc5.d/S21avahi-daemon
./etc/bluetooth/
./etc/bluetooth/input.conf
./etc/bluetooth/network.conf
./etc/netconfig
./etc/firmware/
./etc/firmware/BCM43341B0.1BW.hcd
./etc/firmware/BCM4335C0.ZP.hcd
./etc/firmware/BCM43430A1.1DX.hcd
./etc/dbus-1/
./etc/dbus-1/system.d/
./etc/dbus-1/system.d/ofono.conf
./etc/dbus-1/system.d/dbus-wpa_supplicant.conf
./etc/dbus-1/system.d/bluetooth.conf
./etc/dbus-1/system.d/org.neard.conf
./etc/dbus-1/system.d/avahi-dbus.conf
./etc/dbus-1/session.conf
./etc/dbus-1/system.conf
./etc/syslog.conf.busybox
./etc/rc0.d/
./etc/rc0.d/K22ofono
./etc/rc0.d/S31umountnfs.sh
./etc/rc0.d/K80networking
./etc/rc0.d/K20apmd
./etc/rc0.d/K20psplash.sh
./etc/rc0.d/S20sendsigs
./etc/rc0.d/K19avahi-daemon
./etc/rc0.d/K20syslog
./etc/rc0.d/S38urandom
./etc/rc0.d/S25save-rtc.sh
./etc/rc0.d/K20hwclock.sh
./etc/rc0.d/K60rpcbind
./etc/rc0.d/K31alsa-state
./etc/rc0.d/S40umountfs
./etc/rc0.d/K20dbus-1
./etc/rc0.d/K20bluetooth
./etc/rc0.d/S90halt
./etc/rc0.d/K64neard
./etc/version
./etc/hosts
./etc/inputrc
./etc/libnl/
./etc/libnl/pktloc
./etc/libnl/classid
./etc/login.defs
./etc/wpa_supplicant.conf
./etc/gshadow
./etc/rpc
./etc/asound.conf
./etc/group
./etc/nsswitch.conf
./etc/gshadow-
./etc/motd
./etc/busybox.links.nosuid
./etc/hostname
./etc/syslog-startup.conf.busybox
./etc/services
./etc/host.conf
./etc/modprobe.d/
./etc/passwd-
./etc/passwd
./etc/depmod.d/
./etc/filesystems
./etc/mtab
./etc/login.access
./etc/fstab
./etc/udhcpc.d/
./etc/udhcpc.d/50default
./etc/profile
./etc/rc1.d/
./etc/rc1.d/K22ofono
./etc/rc1.d/S31umountnfs.sh
./etc/rc1.d/K80networking
./etc/rc1.d/K20apmd
./etc/rc1.d/K20psplash.sh
./etc/rc1.d/K19avahi-daemon
./etc/rc1.d/K20syslog
./etc/rc1.d/K20hwclock.sh
./etc/rc1.d/K60rpcbind
./etc/rc1.d/K20dbus-1
./etc/rc1.d/K20bluetooth
./etc/rc1.d/K64neard
./etc/timestamp
./sbin/
./sbin/sulogin.util-linux
./sbin/blkid
./sbin/runlevel.sysvinit
./sbin/shutdown.sysvinit
./sbin/depmod.kmod
./sbin/swapon
./sbin/ldconfig
./sbin/vigr.shadow
./sbin/depmod
./sbin/hwclock
./sbin/sulogin
./sbin/start-stop-daemon
./sbin/vigr
./sbin/getty
./sbin/mkswap
./sbin/init.sysvinit
./sbin/poweroff
./sbin/shutdown
./sbin/reboot
./sbin/ip
./sbin/losetup
./sbin/udevd
./sbin/modinfo
./sbin/insmod
./sbin/init
./sbin/halt
./sbin/rmmod
./sbin/reboot.sysvinit
./sbin/fsck
./sbin/rmmod.kmod
./sbin/loadkmap
./sbin/sysctl
./sbin/modprobe.kmod
./sbin/halt.sysvinit
./sbin/pivot_root
./sbin/ifup
./sbin/modprobe
./sbin/poweroff.sysvinit
./sbin/ifconfig
./sbin/runlevel
./sbin/iwlist
./sbin/iwconfig
./sbin/ifdown
./sbin/setconsole
./sbin/iwgetid
./sbin/insmod.kmod
./sbin/swapoff
./sbin/killall5
./sbin/logread
./sbin/lsmod
./sbin/fstab-decode
./sbin/telinit
./sbin/iwspy
./sbin/nologin
./sbin/switch_root
./sbin/udevadm
./sbin/klogd
./sbin/vipw.shadow
./sbin/syslogd
./sbin/vipw
./sbin/fstrim
./sbin/modinfo.kmod
./sbin/iwpriv
./sbin/bootlogd
./sbin/route
./sbin/udhcpc
./sbin/fdisk
./proc/
./boot/
./boot/zImage-4.1.15-2.0.1+gb63f3f5
./boot/zImage
./tmp/
./var/
./var/local/
./var/spool/
./var/spool/mail/
./var/run
./var/lock
./var/volatile/
./var/lib/
./var/lib/urandom/
./var/lib/misc/
./var/lib/alsa/
./var/lib/alsa/asound.state
./var/lib/dbus/
./var/backups/
./var/log
./var/tmp
./usr/
./usr/src/
./usr/games/
./usr/bin/
./usr/bin/fuser
./usr/bin/hciconfig
./usr/bin/cut
./usr/bin/g-ir-compiler-wrapper
./usr/bin/users
./usr/bin/tftp
./usr/bin/resize
./usr/bin/time
./usr/bin/shuf
./usr/bin/expiry
./usr/bin/hciattach
./usr/bin/lsusb
./usr/bin/dbus-run-session
./usr/bin/md5sum
./usr/bin/wc
./usr/bin/alsamixer
./usr/bin/g-ir-scanner-qemuwrapper
./usr/bin/passwd.shadow
./usr/bin/less
./usr/bin/systool
./usr/bin/nettle-hash
./usr/bin/awk
./usr/bin/dbus-cleanup-sockets
./usr/bin/patch
./usr/bin/free
./usr/bin/last
./usr/bin/basename
./usr/bin/dbus-daemon
./usr/bin/lsusb.py
./usr/bin/gpasswd
./usr/bin/xargs
./usr/bin/easy_install-2.7
./usr/bin/nslookup
./usr/bin/last.sysvinit
./usr/bin/l2test
./usr/bin/nettle-lfib-stream
./usr/bin/id
./usr/bin/renice
./usr/bin/python2.7-config
./usr/bin/uptime
./usr/bin/readlink
./usr/bin/env
./usr/bin/hcidump
./usr/bin/printf
./usr/bin/seq
./usr/bin/od
./usr/bin/dirname
./usr/bin/[[
./usr/bin/bunzip2
./usr/bin/unlink
./usr/bin/whoami
./usr/bin/realpath
./usr/bin/dumpleases
./usr/bin/chage
./usr/bin/who
./usr/bin/newgrp
./usr/bin/groups
./usr/bin/sg
./usr/bin/expr
./usr/bin/l2ping
./usr/bin/nettle-pbkdf2
./usr/bin/mpris-proxy
./usr/bin/wall
./usr/bin/psplash-write
./usr/bin/dbus-update-activation-environment
./usr/bin/apm
./usr/bin/sha1sum
./usr/bin/faillog
./usr/bin/g-ir-annotation-tool
./usr/bin/psplash-default
./usr/bin/lastlog
./usr/bin/which
./usr/bin/sort
./usr/bin/python-config
./usr/bin/reset
./usr/bin/bashbug
./usr/bin/sha256sum
./usr/bin/update-alternatives
./usr/bin/python2
./usr/bin/tr
./usr/bin/strings
./usr/bin/g-ir-scanner-lddwrapper
./usr/bin/lastb.sysvinit
./usr/bin/hexdump
./usr/bin/mkfifo
./usr/bin/utmpdump.sysvinit
./usr/bin/get_driver
./usr/bin/chsh
./usr/bin/newgrp.shadow
./usr/bin/dbus-send
./usr/bin/du
./usr/bin/ftpget
./usr/bin/cmp
./usr/bin/test
./usr/bin/bzcat
./usr/bin/vlock
./usr/bin/tty
./usr/bin/dc
./usr/bin/get_device
./usr/bin/chfn.shadow
./usr/bin/traceroute
./usr/bin/dlist_test
./usr/bin/tail
./usr/bin/logger
./usr/bin/lastb
./usr/bin/g-ir-scanner-wrapper
./usr/bin/sexp-conv
./usr/bin/g-ir-generate
./usr/bin/logname
./usr/bin/mesg
./usr/bin/hcitool
./usr/bin/newuidmap
./usr/bin/bluemoon
./usr/bin/[
./usr/bin/killall
./usr/bin/rctest
./usr/bin/bluetoothctl
./usr/bin/nc
./usr/bin/dbus-monitor
./usr/bin/deallocvt
./usr/bin/dbus-launch
./usr/bin/uniq
./usr/bin/top
./usr/bin/python2.7
./usr/bin/chvt
./usr/bin/tee
./usr/bin/yes
./usr/bin/python
./usr/bin/unzip
./usr/bin/btmon
./usr/bin/pkcs1-conv
./usr/bin/flock
./usr/bin/udevadm
./usr/bin/diff
./usr/bin/groups.shadow
./usr/bin/wget
./usr/bin/openssl
./usr/bin/mpicalc
./usr/bin/head
./usr/bin/dbus-uuidgen
./usr/bin/get_module
./usr/bin/passwd
./usr/bin/clear
./usr/bin/sdptool
./usr/bin/rfcomm
./usr/bin/find
./usr/bin/wall.sysvinit
./usr/bin/usbhid-dump
./usr/bin/bccmd
./usr/bin/wpa_passphrase
./usr/bin/mesg.sysvinit
./usr/bin/python2-config
./usr/bin/ciptool
./usr/bin/usb-devices
./usr/bin/utmpdump
./usr/bin/openvt
./usr/bin/chsh.shadow
./usr/bin/newgidmap
./usr/bin/nfctool
./usr/bin/nohup
./usr/bin/hex2hcd
./usr/bin/chfn
./usr/bin/telnet
./usr/bin/psplash
./usr/bin/microcom
./usr/libexec/
./usr/libexec/nfc/
./usr/libexec/nfc/neard
./usr/libexec/dbus-daemon-launch-helper
./usr/libexec/gio-querymodules
./usr/libexec/bluetooth/
./usr/libexec/bluetooth/bluetoothd
./usr/lib/
./usr/lib/libreadline.so.6
./usr/lib/libavahi-common.so.3
./usr/lib/libformw.so.5
./usr/lib/libgthread-2.0.so.0
./usr/lib/libexpat.so.1.6.0
./usr/lib/libnl-genl-3.so.200
./usr/lib/libgpg-error.so.0
./usr/lib/libapm.so.1
./usr/lib/libasound.so.2
./usr/lib/libgirepository-1.0.so.1
./usr/lib/libgnutls.so.30.6.1
./usr/lib/locale/
./usr/lib/locale/en_US/
./usr/lib/locale/en_US/LC_NUMERIC
./usr/lib/locale/en_US/LC_CTYPE
./usr/lib/locale/en_US/LC_TIME
./usr/lib/locale/en_US/LC_MEASUREMENT
./usr/lib/locale/en_US/LC_ADDRESS
./usr/lib/locale/en_US/LC_NAME
./usr/lib/locale/en_US/LC_COLLATE
./usr/lib/locale/en_US/LC_PAPER
./usr/lib/locale/en_US/LC_MESSAGES/
./usr/lib/locale/en_US/LC_MESSAGES/SYS_LC_MESSAGES
./usr/lib/locale/en_US/LC_IDENTIFICATION
./usr/lib/locale/en_US/LC_TELEPHONE
./usr/lib/locale/en_US/LC_MONETARY
./usr/lib/locale/en_GB/
./usr/lib/locale/en_GB/LC_NUMERIC
./usr/lib/locale/en_GB/LC_CTYPE
./usr/lib/locale/en_GB/LC_TIME
./usr/lib/locale/en_GB/LC_MEASUREMENT
./usr/lib/locale/en_GB/LC_ADDRESS
./usr/lib/locale/en_GB/LC_NAME
./usr/lib/locale/en_GB/LC_COLLATE
./usr/lib/locale/en_GB/LC_PAPER
./usr/lib/locale/en_GB/LC_MESSAGES/
./usr/lib/locale/en_GB/LC_MESSAGES/SYS_LC_MESSAGES
./usr/lib/locale/en_GB/LC_IDENTIFICATION
./usr/lib/locale/en_GB/LC_TELEPHONE
./usr/lib/locale/en_GB/LC_MONETARY
./usr/lib/libnettle.so.6
./usr/lib/libglib-2.0.so.0
./usr/lib/libavahi-core.so.7.0.2
./usr/lib/libnl-route-3.so.200
./usr/lib/libgpg-error.so.0.17.0
./usr/lib/libgio-2.0.so.0
./usr/lib/libpcre.so.1.2.6
./usr/lib/libdbus-1.so.3
./usr/lib/libdbus-1.so.3.14.6
./usr/lib/libbluetooth.so.3.18.10
./usr/lib/libreadline.so.6.3
./usr/lib/libX11.so.6
./usr/lib/libbz2.so.1.0.6
./usr/lib/libidn.so.11.6.15
./usr/lib/gobject-introspection/
./usr/lib/gobject-introspection/giscanner/
./usr/lib/gobject-introspection/giscanner/annotationparser.pyc
./usr/lib/gobject-introspection/giscanner/transformer.pyo
./usr/lib/gobject-introspection/giscanner/libtoolimporter.pyc
./usr/lib/gobject-introspection/giscanner/shlibs.pyc
./usr/lib/gobject-introspection/giscanner/msvccompiler.pyo
./usr/lib/gobject-introspection/giscanner/codegen.py
./usr/lib/gobject-introspection/giscanner/girparser.pyo
./usr/lib/gobject-introspection/giscanner/__init__.py
./usr/lib/gobject-introspection/giscanner/girwriter.pyc
./usr/lib/gobject-introspection/giscanner/cachestore.py
./usr/lib/gobject-introspection/giscanner/xmlwriter.pyc
./usr/lib/gobject-introspection/giscanner/collections/
./usr/lib/gobject-introspection/giscanner/collections/__init__.py
./usr/lib/gobject-introspection/giscanner/collections/ordereddict.py
./usr/lib/gobject-introspection/giscanner/collections/__init__.pyo
./usr/lib/gobject-introspection/giscanner/collections/ordereddict.pyc
./usr/lib/gobject-introspection/giscanner/collections/counter.py
./usr/lib/gobject-introspection/giscanner/collections/ordereddict.pyo
./usr/lib/gobject-introspection/giscanner/collections/counter.pyc
./usr/lib/gobject-introspection/giscanner/collections/__init__.pyc
./usr/lib/gobject-introspection/giscanner/collections/counter.pyo
./usr/lib/gobject-introspection/giscanner/docmain.pyc
./usr/lib/gobject-introspection/giscanner/testcodegen.py
./usr/lib/gobject-introspection/giscanner/docwriter.pyc
./usr/lib/gobject-introspection/giscanner/gdumpparser.pyc
./usr/lib/gobject-introspection/giscanner/annotationparser.pyo
./usr/lib/gobject-introspection/giscanner/utils.pyc
./usr/lib/gobject-introspection/giscanner/ccompiler.pyo
./usr/lib/gobject-introspection/giscanner/__init__.pyo
./usr/lib/gobject-introspection/giscanner/msvccompiler.pyc
./usr/lib/gobject-introspection/giscanner/sourcescanner.py
./usr/lib/gobject-introspection/giscanner/dumper.pyo
./usr/lib/gobject-introspection/giscanner/_giscanner.la
./usr/lib/gobject-introspection/giscanner/utils.pyo
./usr/lib/gobject-introspection/giscanner/ast.pyo
./usr/lib/gobject-introspection/giscanner/girparser.pyc
./usr/lib/gobject-introspection/giscanner/annotationmain.pyo
./usr/lib/gobject-introspection/giscanner/sectionparser.pyc
./usr/lib/gobject-introspection/giscanner/docmain.pyo
./usr/lib/gobject-introspection/giscanner/sectionparser.pyo
./usr/lib/gobject-introspection/giscanner/gdumpparser.pyo
./usr/lib/gobject-introspection/giscanner/codegen.pyc
./usr/lib/gobject-introspection/giscanner/sourcescanner.pyc
./usr/lib/gobject-introspection/giscanner/maintransformer.pyc
./usr/lib/gobject-introspection/giscanner/introspectablepass.py
./usr/lib/gobject-introspection/giscanner/introspectablepass.pyc
./usr/lib/gobject-introspection/giscanner/transformer.pyc
./usr/lib/gobject-introspection/giscanner/testcodegen.pyc
./usr/lib/gobject-introspection/giscanner/_giscanner.so
./usr/lib/gobject-introspection/giscanner/message.pyc
./usr/lib/gobject-introspection/giscanner/annotationmain.pyc
./usr/lib/gobject-introspection/giscanner/shlibs.pyo
./usr/lib/gobject-introspection/giscanner/scannermain.pyo
./usr/lib/gobject-introspection/giscanner/codegen.pyo
./usr/lib/gobject-introspection/giscanner/message.pyo
./usr/lib/gobject-introspection/giscanner/dumper.pyc
./usr/lib/gobject-introspection/giscanner/doctemplates/
./usr/lib/gobject-introspection/giscanner/doctemplates/C/
./usr/lib/gobject-introspection/giscanner/doctemplates/C/enum.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/function.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/namespace.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/class.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/field.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/vfunc.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/default.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/interface.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/method.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/constructor.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/signal.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/property.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/record.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/C/callback.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/base.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/namespace.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/class.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/enum.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/function.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/namespace.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/class.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/field.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/vfunc.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/default.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/interface.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/method.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/constructor.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/signal.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/property.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/record.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Gjs/callback.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/enum.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/function.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/namespace.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/class.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/field.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/vfunc.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/default.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/interface.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/method.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/constructor.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/signal.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/property.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/record.tmpl
./usr/lib/gobject-introspection/giscanner/doctemplates/Python/callback.tmpl
./usr/lib/gobject-introspection/giscanner/girwriter.pyo
./usr/lib/gobject-introspection/giscanner/ccompiler.pyc
./usr/lib/gobject-introspection/giscanner/testcodegen.pyo
./usr/lib/gobject-introspection/giscanner/scannermain.pyc
./usr/lib/gobject-introspection/giscanner/xmlwriter.pyo
./usr/lib/gobject-introspection/giscanner/cachestore.pyc
./usr/lib/gobject-introspection/giscanner/libtoolimporter.pyo
./usr/lib/gobject-introspection/giscanner/ast.pyc
./usr/lib/gobject-introspection/giscanner/cachestore.pyo
./usr/lib/gobject-introspection/giscanner/sourcescanner.pyo
./usr/lib/gobject-introspection/giscanner/introspectablepass.pyo
./usr/lib/gobject-introspection/giscanner/__init__.pyc
./usr/lib/gobject-introspection/giscanner/docwriter.pyo
./usr/lib/gobject-introspection/giscanner/maintransformer.pyo
./usr/lib/libkmod.so.2
./usr/lib/libnettle.so.6.2
./usr/lib/libffi.so.6
./usr/lib/libnl-cli-3.so.200
./usr/lib/libxcb.so.1.1.0
./usr/lib/libgio-2.0.so.0.4600.2
./usr/lib/libmenuw.so.5.9
./usr/lib/libnl-route-3.so.200.20.0
./usr/lib/alsa-lib/
./usr/lib/alsa-lib/libasound_module_rate_asrcrate.so
./usr/lib/alsa-lib/libasound_module_rate_asrcrate_fast.so
./usr/lib/libpanelw.so.5.9
./usr/lib/neard/
./usr/lib/neard/test-device
./usr/lib/neard/phdc-simple-manager
./usr/lib/neard/test-adapter
./usr/lib/neard/neardutils.py
./usr/lib/neard/monitor-near
./usr/lib/neard/handover-agent
./usr/lib/neard/test-tag
./usr/lib/neard/bt-handover
./usr/lib/neard/nfctool
./usr/lib/libgirepository-1.0.so.1.0.0
./usr/lib/libgcrypt.so.20
./usr/lib/libffi.so.6.0.4
./usr/lib/libcrypto.so.1.0.0
./usr/lib/libdaemon.so.0.5.0
./usr/lib/libkmod.so.2.3.0
./usr/lib/libXdmcp.so.6
./usr/lib/libasound.so.2.0.0
tar: write error: No space left on device
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00008d00
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00008d00
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Sep 16 2016 - 18:51:19 -0500)
CPU: Freescale i.MX6ULL rev1.0 at 396MHz
CPU: Commercial temperature grade (0C to 95C) at 51C
Reset cause: POR
Board: MX6ULL 14x14 EVK
I2C: ready
DRAM: 512 MiB
NAND: 128 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
Display: TFT43AB (480x272)
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
Hit any key to stop autoboot: 0
Kernel image @ 0x80800000 [ 0x000000 - 0x554130 ]
## Loading init Ramdisk from Legacy Image at 83800000 ...
Image Name: fsl-image-mfgtool-initramfs-imx6
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 8591032 Bytes = 8.2 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 83000000, end 8300be76
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.1.15+ (bamboo@yb6) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Fri Sep 16 18:10:49 CDT 2016
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 ULL 14x14 EVK Board
Reserved memory: created CMA memory pool at 0x8c000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
Memory policy: Data cache writealloc
PERCPU: Embedded 12 pages/cpu @8bb32000 s16716 r8192 d24244 u49152
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber= mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs) clk_ignore_unused
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 172392K/524288K available (6903K kernel code, 320K rwdata, 2416K rodata, 384K init, 423K bss, 24216K reserved, 327680K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80921fd8 (9320 kB)
.init : 0x80922000 - 0x80982000 ( 384 kB)
.data : 0x80982000 - 0x809d2080 ( 321 kB)
.bss : 0x809d5000 - 0x80a3ee54 ( 424 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
Additional per-CPU info printed with stalls.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS:16 nr_irqs:16 16
mxc_clocksource_init 24000000
Switching to timer-based delay loop, resolution 41ns
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
/cpus/cpu@0 missing clock-frequency property
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80008280 - 0x800082f0
Brought up 1 CPUs
SMP: Total of 1 processors activated (48.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
mxs-dma 1804000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 8392K (83800000 - 84032000)
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) 穢 2001-2006 Red Hat, Inc.
fuse init (API version 7.23)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
21c8000.lcdif supply lcd not found, using dummy regulator
mxsfb 21c8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 60x34
mxsfb 21c8000.lcdif: initialized
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.3
imx-sdma 20ec000.sdma: initialized
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 19, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 234, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xf1
nand: Micron MT29F1G08ABAEAWP
nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
4 cmdlinepart partitions found on MTD device gpmi-nand
Creating 4 MTD partitions on "gpmi-nand":
0x000000000000-0x000004000000 : "boot"
0x000004000000-0x000005000000 : "kernel"
0x000005000000-0x000006000000 : "dtb"
0x000006000000-0x000008000000 : "rootfs"
gpmi-nand 1806000.gpmi-nand: driver registered.
20b4000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 20b4000.ethernet eth0: registered PHC device 0
2188000.ethernet supply phy not found, using dummy regulator
pps pps1: new PPS source ptp1
fec 2188000.ethernet eth1: registered PHC device 1
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
2184000.usb supply vbus not found, using dummy regulator
2184200.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Mass Storage Function, version: 2009/09/11
LUN: removable file: (no medium)
LUN: removable read only file: /fat
Number of LUNs=1
Number of LUNs=1
g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
g_mass_storage gadget: g_mass_storage ready
mousedev: PS/2 mouse device common for all mice
input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
input: iMX6UL TouchScreen Controller as /devices/platform/soc/2000000.aips-bus/2040000.tsc/input/input1
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
pxp-v4l2 pxp_v4l2: initialized
imx2-wdt 20bc000.wdog: use WDOG_B to reboot.
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Key type dns_resolver registered
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
Registering SWP/SWPB emulation handler
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
VSD_3V3: disabling
can-3v3: disabling
clk: Not disabling unused clocks
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 384K (80922000 - 80982000)
Starting UTP
uuc 0.5 [built Sep 16 2016 02:36:28]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
UTP: received command '$ mount -t debugfs debugfs /sys/kernel/debug'
UTP: executing "mount -t debugfs debugfs /sys/kernel/debug"
UTP: sending Success to kernel for command $ mount -t debugfs debugfs /sys/kernel/debug.
UTP: received command '$ ls -al /sys/kernel/debug'
UTP: executing "ls -al /sys/kernel/debug"
total 0
drwx------ 22 root root 0 Jan 1 00:00 .
drwxr-xr-x 7 root root 0 Jan 1 00:00 ..
drwxr-xr-x 2 root root 0 Jan 1 1970 asoc
drwxr-xr-x 31 root root 0 Jan 1 00:00 bdi
drwxr-xr-x 2 root root 0 Jan 1 1970 ci_hdrc.0
drwxr-xr-x 2 root root 0 Jan 1 1970 ci_hdrc.1
drwxr-xr-x 223 root root 0 Jan 1 00:00 clk
drwxr-xr-x 2 root root 0 Jan 1 00:00 dma_buf
drwxr-xr-x 3 root root 0 Jan 1 1970 dri
drwxr-xr-x 2 root root 0 Jan 1 1970 extfrag
-rw-r--r-- 1 root root 0 Jan 1 1970 fault_around_bytes
-r--r--r-- 1 root root 0 Jan 1 00:00 gpio
drwxr-xr-x 2 root root 0 Jan 1 1970 gpmi-nand
drwxr-xr-x 2 root root 0 Jan 1 1970 hid
drwxr-xr-x 2 root root 0 Jan 1 00:00 ieee80211
drwxr-xr-x 2 root root 0 Jan 1 1970 memblock
drwxr-xr-x 2 root root 0 Jan 1 1970 mmc0
drwxr-xr-x 4 root root 0 Jan 1 00:00 pinctrl
drwxr-xr-x 2 root root 0 Jan 1 1970 pm_qos
-r--r--r-- 1 root root 0 Jan 1 00:00 pwm
drwxr-xr-x 3 root root 0 Jan 1 00:00 regmap
drwxr-xr-x 8 root root 0 Jan 1 00:00 regulator
-r--r--r-- 1 root root 0 Jan 1 1970 sleep_time
-r--r--r-- 1 root root 0 Jan 1 1970 suspend_stats
drwxr-xr-x 2 root root 0 Jan 1 1970 ubi
drwxr-xr-x 2 root root 0 Jan 1 1970 ubifs
drwxr-xr-x 2 root root 0 Jan 1 00:00 usb
-r--r--r-- 1 root root 0 Jan 1 00:00 wakeup_sources
UTP: sending Success to kernel for command $ ls -al /sys/kernel/debug.
UTP: received command '$ ls -al /dev/mtd*'
UTP: executing "ls -al /dev/mtd*"
crw------- 1 root root 90, 0 Jan 1 1970 /dev/mtd0
crw------- 1 root root 90, 1 Jan 1 1970 /dev/mtd0ro
crw------- 1 root root 90, 2 Jan 1 1970 /dev/mtd1
crw------- 1 root root 90, 3 Jan 1 1970 /dev/mtd1ro
crw------- 1 root root 90, 4 Jan 1 1970 /dev/mtd2
crw------- 1 root root 90, 5 Jan 1 1970 /dev/mtd2ro
crw------- 1 root root 90, 6 Jan 1 1970 /dev/mtd3
crw------- 1 root root 90, 7 Jan 1 1970 /dev/mtd3ro
brw------- 1 root root 31, 0 Jan 1 1970 /dev/mtdblock0
brw------- 1 root root 31, 1 Jan 1 1970 /dev/mtdblock1
brw------- 1 root root 31, 2 Jan 1 1970 /dev/mtdblock2
brw------- 1 root root 31, 3 Jan 1 1970 /dev/mtdblock3
UTP: sending Success to kernel for command $ ls -al /dev/mtd*.
UTP: received command '$ flash_erase /dev/mtd0 0 0'
UTP: executing "flash_erase /dev/mtd0 0 0"
Erasing 128 Kibyte @ 3d20000 -- 95 % utp_poll: pass returned.
Erasing 128 Kibyte @ 3fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd0 0 0.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE'
UTP: executing "kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE"
MTD CONFIG:
chip_0_device_path = "/dev/mtd0"
chip_1_device_path = "(null)"
search_exponent = 2
data_setup_time = 80
data_hold_time = 60
address_setup_time = 25
data_sample_time = 6
row_address_size = 3
column_address_size = 2
read_command_code1 = 0
read_command_code2 = 48
boot_stream_major_version = 1
boot_stream_minor_version = 0
boot_stream_sub_version = 0
ncb_version = 3
boot_stream_1_address = 0
boot_stream_2_address = 0
-- We add the 1k-padding to the uboot.
.tmp_kobs_ng: verifying using key '00000000000000000000000000000000'
.tmp_kobs_ng: is a valid bootstream for key '00000000000000000000000000000000'
mtd: use new bch layout raw access mode
mtd: opening: "/dev/mtd0"
NFC geometry :
ECC Strength : 4
Page Size in Bytes : 2084
Metadata size : 10
ECC Chunk Size in byte : 512
ECC Chunk count : 4
Block Mark Byte Offset : 2018
Block Mark Bit Offset : 4
mtd: opened '/dev/mtd0' - '(null)'
mtd: max_boot_stream_size_in_bytes = 33030144
mtd: boot_stream_size_in_bytes = 475136
mtd: boot_stream_size_in_pages = 232
mtd: #1 0x00100000 - 0x02080000 (0x00174000)
mtd: #2 0x02080000 - 0x04000000 (0x020f4000)
FCB
m_u32Checksum = 0x00000000
m_u32FingerPrint = 0x20424346
m_u32Version = 0x01000000
m_NANDTiming.m_u8DataSetup = 80
m_NANDTiming.m_u8DataHold = 60
m_NANDTiming.m_u8AddressSetup = 25
m_NANDTiming.m_u8DSAMPLE_TIME = 6
m_u32PageDataSize = 2048
m_u32TotalPageSize = 2112
m_u32SectorsPerBlock = 64
m_u32NumberOfNANDs = 0
m_u32TotalInternalDie = 0
m_u32CellType = 0
m_u32EccBlockNEccType = 2
m_u32EccBlock0Size = 512
m_u32EccBlockNSize = 512
m_u32EccBlock0EccType = 2
m_u32MetadataBytes = 10
m_u32NumEccBlocksPerPage = 3
m_u32EccBlockNEccLevelSDK = 0
m_u32EccBlock0SizeSDK = 0
m_u32EccBlockNSizeSDK = 0
m_u32EccBlock0EccLevelSDK = 0
m_u32NumEccBlocksPerPageSDK = 0
m_u32MetadataBytesSDK = 0
m_u32EraseThreshold = 0
m_u32Firmware1_startingPage = 512
m_u32Firmware2_startingPage = 16640
m_u32PagesInFirmware1 = 232
m_u32PagesInFirmware2 = 232
m_u32DBBTSearchAreaStartAddress = 256
m_u32BadBlockMarkerByte = 2018
m_u32BadBlockMarkerStartBit = 4
m_u32BBMarkerPhysicalOffset = 2048
m_u32BCHType = 0
m_NANDTMTiming.m_u32TMTiming2_ReadLatency = 0
m_NANDTMTiming.m_u32TMTiming2_PreambleDelay = 0
m_NANDTMTiming.m_u32TMTiming2_CEDelay = 0
m_NANDTMTiming.m_u32TMTiming2_PostambleDelay = 0
m_NANDTMTiming.m_u32TMTiming2_CmdAddPause = 0
m_NANDTMTiming.m_u32TMTiming2_DataPause = 0
m_NANDTMTiming.m_u32TMSpeed = 0
m_NANDTMTiming.m_u32TMTiming1_BusyTimeout = 0
m_u32DISBBM = 0
m_u32BBMarkerPhysicalOffsetInSpareData = 0
m_u32OnfiSyncEnable = 0
m_NANDONFITiming.m_u32ONFISpeed = 0
m_NANDONFITiming.m_u32ONFITiming_ReadLatency = 0
m_NANDONFITiming.m_u32ONFITiming_CEDelay = 0
m_NANDONFITiming.m_u32ONFITiming_PreambleDelay = 0
m_NANDONFITiming.m_u32ONFITiming_PostambleDelay = 0
m_NANDONFITiming.m_u32ONFITiming_CmdAddPause = 0
m_NANDONFITiming.m_u32ONFITiming_DataPause = 0
m_NANDONFITiming.m_u32ONFITiming_BusyTimeout = 0
m_u32DISBBSearch = 0
m_u32RandomizerEnable = 0
m_u32ReadRetryEnable = 0
m_u32ReadRetrySeqLength = 0
DBBT
m_u32FingerPrint = 0x54424244
m_u32DBBTNumOfPages = 0
Firmware: image #0 @ 0x100000 size 0x74000 - available 0x1f80000
Firmware: image #1 @ 0x2080000 size 0x74000 - available 0x1f80000
-------------- Start to write the [ FCB ] -----
mtd: erasing @0:0x0-0x20000
mtd: Writing FCB0 [ @0:0x0 ] (840) *
mtd: erasing @0:0x20000-0x40000
mtd: Writing FCB1 [ @0:0x20000 ] (840) *
mtd: erasing @0:0x40000-0x60000
mtd: Writing FCB2 [ @0:0x40000 ] (840) *
mtd: erasing @0:0x60000-0x80000
mtd: Writing FCB3 [ @0:0x60000 ] (840) *
mtd_commit_bcb(FCB): status 0
-------------- Start to write the [ DBBT ] -----
mtd: erasing @0:0x80000-0xa0000
mtd: Writing DBBT0 [ @0:0x80000 ] (800) *
mtd: erasing @0:0xa0000-0xc0000
mtd: Writing DBBT1 [ @0:0xa0000 ] (800) *
mtd: erasing @0:0xc0000-0xe0000
mtd: Writing DBBT2 [ @0:0xc0000 ] (800) *
mtd: erasing @0:0xe0000-0x100000
mtd: Writing DBBT3 [ @0:0xe0000 ] (800) *
mtd_commit_bcb(DBBT): status 0
---------- Start to write the [ .tmp_kobs_ng ]----
mtd: Writting .tmp_kobs_ng: #0 @0: 0x00100000 - 0x00174000
mtd: erasing @0:0x100000-0x120000
mtd: erasing @0:0x120000-0x140000
mtd: erasing @0:0x140000-0x160000
mtd: erasing @0:0x160000-0x180000
mtd: We write one page for save guard. *
mtd: Writting .tmp_kobs_ng: #1 @0: 0x02080000 - 0x020f4000
mtd: erasing @0:0x2080000-0x20a0000
mtd: erasing @0:0x20a0000-0x20c0000
random: nonblocking pool is initialized
mtd: erasing @0:0x20c0000-0x20e0000
mtd: erasing @0:0x20e0000-0x2100000
UTP: sending Success to kernel for command $ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE.
UTP: received command '$ flash_erase /dev/mtd1 0 0'
UTP: executing "flash_erase /dev/mtd1 0 0"
Erasing 128 Kiutp_poll: pass returned.mplete
Erasing 128 Kibyte @ fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd1 0 0.
UTP: received command '$ nandwrite -p /dev/mtd1 -p $FILE'
UTP: executing "nandwrite -p /dev/mtd1 -p $FILE"
Writing data to block 0 at offset 0x0
Writing data to block 1 at offset 0x20000
Writing data to block 2 at offset 0x40000
Writing data to block 3 at offset 0x60000
Writing data to block 4 at offset 0x80000
Writing data to block 5 at offset 0xa0000
Writing data to block 6 at offset 0xc0000
Writing data to block 7 at offset 0xe0000
Writing data to block 8 at offset 0x100000
Writing data to block 9 at offset 0x120000
Writing data to block 10 at offset 0x140000
Writing data to block 11 at offset 0x160000
Writing data to block 12 at offset 0x180000
Writing data to block 13 at offset 0x1a0000
Writing data to block 14 at offset 0x1c0000
Writing data to block 15 at offset 0x1e0000
Writing data to block 16 at offset 0x200000
Writing data to block 17 at offset 0x220000
Writing data to block 18 at offset 0x240000
Writing data to block 19 at offset 0x260000
Writing data to block 20 at offset 0x280000
Writing data to block 21 at offset 0x2a0000
Writing data to block 22 at offset 0x2c0000
Writing data to block 23 at offset 0x2e0000
Writing data to block 24 at offset 0x300000
Writing data to block 25 at offset 0x320000
Writing data to block 26 at offset 0x340000
Writing data to block 27 at offset 0x360000
Writing data to block 28 at offset 0x380000
Writing data to block 29 at offset 0x3a0000
Writing data to block 30 at offset 0x3c0000
Writing data to block 31 at offset 0x3e0000
Writing data to block 32 at offset 0x400000
Writing data to block 33 at offset 0x420000
Writing data to block 34 at offset 0x440000
Writing data to block 35 at offset 0x460000
Writing data to block 36 at offset 0x480000
Writing data to block 37 at offset 0x4a0000
Writing data to block 38 at offset 0x4c0000
Writing data to block 39 at offset 0x4e0000
Writing data to block 40 at offset 0x500000
Writing data to block 41 at offset 0x520000
Writing data to block 42 at offset 0x540000
Writing data to block 43 at offset 0x560000
Writing data to block 44 at offset 0x580000
Writing data to block 45 at offset 0x5a0000
Writing data to block 46 at offset 0x5c0000
Writing data to block 47 at offset 0x5e0000
Writing data to block 48 at offset 0x600000
Writing data to block 49 at offset 0x620000
Writing data to block 50 at offset 0x640000
UTP: sending Success to kernel for command $ nandwrite -p /dev/mtd1 -p $FILE.
UTP: received command '$ flash_erase /dev/mtd2 0 0'
UTP: executing "flash_erase /dev/mtd2 0 0"
UTP: sending Success to kernel for command $ flash_erase /dev/mtd2 0 0.
UTP: received command '$ nandwrite -p /dev/mtd2 -p $FILE'
UTP: executing "nandwrite -p /dev/mtd2 -p $FILE"
UTP: sending Success to kernel for command $ nandwrite -p /dev/mtd2 -p $FILE.
UTP: received command '$ flash_erase /dev/mtd3 0 0'
UTP: executing "flash_erase /dev/mtd3 0 0"
utp_poll: pass returned.0000 -- 94 % complete
Erasing 128 Kibyte @ 1f60000 -- 98 % complete flash_erase: Skipping bad block at 01f80000
flash_erase: Skipping bad block at 01fa0000
flash_erase: Skipping bad block at 01fc0000
flash_erase: Skipping bad block at 01fe0000
Erasing 128 Kibyte @ 1fe0000 -- 100 % complete
UTP: sending Success to kernel for command $ flash_erase /dev/mtd3 0 0.
UTP: received command '$ ubiformat /dev/mtd3'
UTP: executing "ubiformat /dev/mtd3"
ubiformat: mtd3 (nand), size 33554432 bytes (32.0 MiB), 256 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 255 -- 100 % complete
ubiformat: 252 eraseblocks are supposedly empty
ubiformat: 4 bad eraseblocks found, numbers: 252, 253, 254, 255
ubiformat: formatting eraseblock 255 -- 100 % complete
UTP: sending Success to kernel for command $ ubiformat /dev/mtd3.
UTP: received command '$ ubiattach /dev/ubi_ctrl -m 3'
UTP: executing "ubiattach /dev/ubi_ctrl -m 3"
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "rootfs", size 32 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 252, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 1614893800
ubi0: available PEBs: 232, total reserved PEBs: 20, PEBs reserved for bad PEB handling: 16
ubi0: background thread "ubi_bgt0d" started, PID 67
UBI device number 0, total 252 LEBs (31997952 bytes, 30.5 MiB), available 232 LEBs (29458432 bytes, 28.1 MiB), LEB size 126976 bytes (124.0 KiB)
UTP: sending Success to kernel for command $ ubiattach /dev/ubi_ctrl -m 3.
UTP: received command '$ ubimkvol /dev/ubi0 -Nrootfs -m'
UTP: executing "ubimkvol /dev/ubi0 -Nrootfs -m"
Set volume size to 29458432
Volume ID 0, size 232 LEBs (29458432 bytes, 28.1 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "rootfs", alignment 1
UTP: sending Success to kernel for command $ ubimkvol /dev/ubi0 -Nrootfs -m.
UTP: received command '$ mkdir -p /mnt/mtd3'
UTP: executing "mkdir -p /mnt/mtd3"
UTP: sending Success to kernel for command $ mkdir -p /mnt/mtd3.
UTP: received command '$ mount -t ubifs ubi0:rootfs /mnt/mtd3'
UTP: executing "mount -t ubifs ubi0:rootfs /mnt/mtd3"
UBIFS (ubi0:0): default file-system created
UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 71
UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi0:0): FS size: 28188672 bytes (26 MiB, 222 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
UBIFS (ubi0:0): reserved for root: 1331420 bytes (1300 KiB)
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 248DCFDA-C1D7-4A9B-B97A-BFE5F8895F70, small LPT model
UTP: sending Success to kernel for command $ mount -t ubifs ubi0:rootfs /mnt/mtd3.
UTP: received command 'pipe tar -jxv -C /mnt/mtd3'
pid is 72, UTP: executing "tar -jxv -C /mnt/mtd3"
UTP: sending Success to kernel for command pipe tar -jxv -C /mnt/mtd3.
./sys/
./run/
./dev/
./mnt/
./mnt/.psplash/
./home/
./home/root/
./bin/
./bin/netstat
./bin/more
./bin/zcat
./bin/ps
./bin/egrep
./bin/umount
./bin/cp
./bin/stty
./bin/run-parts
./bin/fgrep
./bin/cpio
./bin/mv
./bin/tar
./bin/false
./bin/grep
./bin/mountpoint.sysvinit
./bin/pidof
./bin/usleep
./bin/df
./bin/echo
./bin/pidof.sysvinit
./bin/busybox.nosuid
./bin/mount
./bin/dmesg
./bin/cat
./bin/sync
./bin/dnsdomainname
./bin/dd
./bin/login.shadow
./bin/ls
./bin/date
./bin/ash
./bin/stat
./bin/dumpkmap
./bin/sleep
./bin/su
./bin/ping6
./bin/chattr
./bin/sed
./bin/rm
./bin/chmod
./bin/busybox.suid
./bin/vi
./bin/pwd
./bin/kill
./bin/lsmod
./bin/mknod
./bin/watch
./bin/mktemp
./bin/chgrp
./bin/start_getty
./bin/kmod
./bin/sh
./bin/mkdir
./bin/ln
./bin/uname
./bin/hostname
./bin/login
./bin/mountpoint
./bin/gunzip
./bin/bash
./bin/ping
./bin/getopt
./bin/chown
./bin/lsmod.kmod
./bin/rmdir
./bin/touch
./bin/su.shadow
./bin/true
./bin/busybox
./bin/gzip
./lib/
./lib/libtinfo.so.5.9
./lib/modules/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/libcrc32c.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc7.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc-itu-t.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/lib/crc-ccitt.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/binfmt_misc.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/configfs/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/configfs/configfs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/isofs/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/isofs/isofs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/udf/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/udf/udf.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/nls/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/nls/nls_iso8859-15.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/fat/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/fs/fat/msdos.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/crypto/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/crypto/tcrypt.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/snd-usbmidi-lib.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/usb/snd-usb-audio.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/snd-hwdep.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/sound/core/snd-rawmidi.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/libcomposite.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_serial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ncm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_eem.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_acm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_fs.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/u_ether.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_obex.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/u_serial.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
./lib/modules/4.1.15-2.0.1+gb63f3f5/kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko
./lib/libz.so.1.2.8
./lib/libc-2.23.so
./lib/libcrypt.so.1
./lib/libgcc_s.so.1
./lib/udev/
./lib/udev/rules.d/
./lib/udev/v4l_id
./lib/udev/ata_id
./lib/udev/cdrom_id
./lib/udev/collect
./lib/udev/scsi_id
./lib/udev/hid2hci
./lib/libutil.so.1
./lib/libuuid.so.1
./lib/libm-2.23.so
./lib/librt.so.1
./lib/libdl-2.23.so
./lib/libsysfs.so.2
./lib/libanl.so.1
./lib/libm.so.6
./lib/libblkid.so.1
./lib/libz.so.1
./lib/firmware/
./lib/firmware/bcm/
./lib/firmware/imx/
./lib/ld-2.23.so
./lib/libcap.so.2
./lib/libc.so.6
./lib/libnsl.so.1
./lib/libtinfo.so.5
./lib/librt-2.23.so
./lib/modprobe.d/
./lib/depmod.d/
./lib/libdl.so.2
./lib/libudev.so.1
./etc/
./etc/avahi/
./etc/avahi/hosts
./etc/syslog.conf
./etc/default/
./etc/default/apmd
./etc/default/usbd
./etc/default/rcS
./etc/skel/
./etc/skel/.profile
./etc/skel/.bashrc
./etc/ld.so.conf
./etc/rcS.d/
./etc/rcS.d/S04udev
./etc/inittab
./etc/ld.so.cache
./etc/init.d/
./etc/init.d/ofono
./etc/init.d/udev
./etc/init.d/reboot
./etc/init.d/halt
./etc/init.d/neard
./etc/init.d/single
./etc/init.d/apmd
./etc/init.d/dbus-1
./etc/init.d/syslog
./etc/init.d/rcS
./etc/init.d/rc
./etc/rc6.d/
./etc/rc6.d/K20apmd
./etc/ofono/
./etc/rc4.d/
./etc/rc4.d/S20apmd
./etc/terminfo/
./etc/terminfo/r/
./etc/terminfo/x/
./etc/terminfo/s/
./etc/terminfo/l/
./etc/terminfo/d/
./etc/terminfo/v/
./etc/terminfo/a/
./etc/udev/
./etc/udev/rules.d/
./etc/rpcbind.conf
./etc/shadow-
./etc/securetty
./etc/rc2.d/
./etc/rc2.d/S20apmd
./etc/shells
./etc/issue.net
./etc/network/
./etc/rpm/
./etc/rpm/platform
./etc/rpm/sysinfo/
./etc/shadow
./etc/apm/
./etc/apm/resume.d/
./etc/apm/other.d/
./etc/apm/event.d/
./etc/issue
./etc/protocols
./etc/group-
./etc/rc3.d/
./etc/rc3.d/S20apmd
./etc/limits
./etc/rc5.d/
./etc/rc5.d/S20apmd
./etc/bluetooth/
./etc/netconfig
./etc/firmware/
./etc/dbus-1/
./etc/rc0.d/
./etc/rc0.d/K20apmd
./etc/rc0.d/S90halt
./etc/version
./etc/hosts
./etc/inputrc
./etc/libnl/
./etc/libnl/pktloc
./etc/libnl/classid
./etc/login.defs
./etc/gshadow
./etc/rpc
./etc/asound.conf
./etc/group
./etc/nsswitch.conf
./etc/gshadow-
./etc/motd
./etc/hostname
./etc/services
./etc/host.conf
./etc/modprobe.d/
./etc/passwd-
./etc/passwd
./etc/depmod.d/
./etc/filesystems
./etc/mtab
./etc/login.access
./etc/fstab
./etc/udhcpc.d/
./etc/profile
./etc/rc1.d/
./etc/rc1.d/K20apmd
./etc/timestamp
./sbin/
./sbin/blkid
./sbin/depmod.kmod
./sbin/swapon
./sbin/ldconfig
./sbin/vigr.shadow
./sbin/depmod
./sbin/hwclock
./sbin/sulogin
./sbin/vigr
./sbin/getty
./sbin/mkswap
./sbin/poweroff
./sbin/shutdown
./sbin/reboot
./sbin/ip
./sbin/losetup
./sbin/udevd
./sbin/modinfo
./sbin/insmod
./sbin/init
./sbin/halt
./sbin/rmmod
./sbin/fsck
./sbin/rmmod.kmod
./sbin/loadkmap
./sbin/sysctl
./sbin/pivot_root
./sbin/ifup
./sbin/modprobe
./sbin/ifconfig
./sbin/runlevel
./sbin/iwlist
./sbin/iwconfig
./sbin/ifdown
./sbin/setconsole
./sbin/iwgetid
./sbin/insmod.kmod
./sbin/swapoff
./sbin/killall5
./sbin/logread
./sbin/lsmod
./sbin/fstab-decode
./sbin/telinit
./sbin/iwspy
./sbin/nologin
./sbin/switch_root
./sbin/udevadm
./sbin/klogd
./sbin/vipw.shadow
./sbin/syslogd
./sbin/vipw
./sbin/fstrim
./sbin/modinfo.kmod
./sbin/iwpriv
./sbin/bootlogd
./sbin/route
./sbin/udhcpc
./sbin/fdisk
./proc/
./boot/
./boot/zImage
./tmp/
./var/
./var/local/
./var/spool/
./var/spool/mail/
./var/run
./var/lock
./var/volatile/
./var/lib/
./var/lib/urandom/
./var/lib/misc/
./var/lib/alsa/
./var/lib/dbus/
./var/backups/
./var/log
./var/tmp
./usr/
./usr/src/
./usr/games/
./usr/bin/
./usr/bin/fuser
./usr/bin/hciconfig
./usr/bin/cut
./usr/bin/users
./usr/bin/tftp
./usr/bin/resize
./usr/bin/time
./usr/bin/shuf
./usr/bin/expiry
./usr/bin/hciattach
./usr/bin/lsusb
./usr/bin/md5sum
./usr/bin/wc
./usr/bin/alsamixer
./usr/bin/less
./usr/bin/systool
./usr/bin/awk
./usr/bin/patch
./usr/bin/free
./usr/bin/last
./usr/bin/basename
./usr/bin/lsusb.py
./usr/bin/gpasswd
./usr/bin/xargs
./usr/bin/nslookup
./usr/bin/l2test
./usr/bin/id
./usr/bin/renice
./usr/bin/uptime
./usr/bin/readlink
./usr/bin/env
./usr/bin/hcidump
./usr/bin/printf
./usr/bin/seq
./usr/bin/od
./usr/bin/dirname
./usr/bin/[[
./usr/bin/bunzip2
./usr/bin/unlink
./usr/bin/whoami
./usr/bin/realpath
./usr/bin/chage
./usr/bin/who
./usr/bin/newgrp
./usr/bin/groups
./usr/bin/sg
./usr/bin/expr
./usr/bin/l2ping
./usr/bin/wall
./usr/bin/apm
./usr/bin/sha1sum
./usr/bin/faillog
./usr/bin/lastlog
./usr/bin/which
./usr/bin/sort
./usr/bin/reset
./usr/bin/bashbug
./usr/bin/sha256sum
./usr/bin/python2
./usr/bin/tr
./usr/bin/strings
./usr/bin/hexdump
./usr/bin/mkfifo
./usr/bin/chsh
./usr/bin/dbus-send
./usr/bin/du
./usr/bin/ftpget
./usr/bin/cmp
./usr/bin/test
./usr/bin/bzcat
./usr/bin/vlock
./usr/bin/tty
./usr/bin/dc
./usr/bin/tail
./usr/bin/logger
./usr/bin/lastb
./usr/bin/sexp-conv
./usr/bin/logname
./usr/bin/mesg
./usr/bin/hcitool
./usr/bin/newuidmap
./usr/bin/bluemoon
./usr/bin/[
./usr/bin/killall
./usr/bin/rctest
./usr/bin/nc
./usr/bin/deallocvt
./usr/bin/uniq
./usr/bin/top
./usr/bin/python2.7
./usr/bin/chvt
./usr/bin/tee
./usr/bin/yes
./usr/bin/python
./usr/bin/unzip
./usr/bin/btmon
./usr/bin/flock
./usr/bin/udevadm
./usr/bin/diff
./usr/bin/wget
./usr/bin/openssl
./usr/bin/mpicalc
./usr/bin/head
./usr/bin/passwd
./usr/bin/clear
./usr/bin/sdptool
./usr/bin/rfcomm
./usr/bin/find
./usr/bin/bccmd
./usr/bin/ciptool
./usr/bin/utmpdump
./usr/bin/openvt
./usr/bin/newgidmap
./usr/bin/nfctool
./usr/bin/nohup
./usr/bin/hex2hcd
./usr/bin/chfn
./usr/bin/telnet
./usr/bin/psplash
./usr/bin/microcom
./usr/libexec/
./usr/libexec/nfc/
./usr/lib/
./usr/lib/locale/
./usr/lib/alsa-lib/
./usr/lib/neard/
5,941件の閲覧回数
stevenyu
Hi igor,
This is the configuration of our bootcode, and it looks like the rest of flash should be used for rootfs.
bootargs=console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs)
However, when we use mfg_tool to burn the images, mfg_tool will re-write uboot, kernel, dtb, and file system. The mfg_tool seems not see this mtdparts parameters at that time. Do you know what's wrong with our procedure ?
Steven Yu
5,941件の閲覧回数
stevenyu
Any method to change mtd partition size before using mfg_tool to burn firmware to flash ?
Steven Yu
5,941件の閲覧回数
5,941件の閲覧回数
stevenyu
Hi igor,
We have checked ucl2.xml and found ubimkvol is already have maxavsize option when introducing ubimkvol command.
<CMD state="Updater" type="push" body="$ flash_erase /dev/mtd%part_rootfs% 0 0">Erasing rootfs partition</CMD>
<CMD state="Updater" type="push" body="$ ubiformat /dev/mtd%part_rootfs%"/>
<CMD state="Updater" type="push" body="$ ubiattach /dev/ubi_ctrl -m %part_rootfs%">Attaching UBI partition</CMD>
<CMD state="Updater" type="push" body="$ ubimkvol /dev/ubi0 -Nrootfs -m"/>
==> -m means make with maximum available size, the available size should be decided before flash-erase
According to your information, we google more and found ubimkvol can make UBI volume size as user want if space size is enough. We think when first line "flash_erase /dev/mtd%part_rootfs%, the maximum size of partition is already decided, and ubimkvol is base on this size to create ubifs with limit of mtd partition size.
Steven Yu
5,941件の閲覧回数
Hi Steven
primary place for information about MTD support in Linux is infradead.org
so one can post there.
