How to change DDR voltage setting before DDR calibration
george
Senior Contributor II
Dear all,
Our product uses i.MX6UL and PF3000.
For some special reason, we need to change the DDR voltage setting before performing the DDR calibration.
I think that is possible by using Plugin instead of DCD.
Is there any helpful information on how to access the PMIC using assembler?
BR,
George
Tags (3)
Hi George
unfortunately I am not aware of assembler examples, in general
one can look at baremetal sdk PF0100 (similar to PF3000) example
https://github.com/RT-Thread/rt-thread/blob/master/bsp/imx6sx/iMX6_Platform_SDK/sdk/common/pmic/pfus...
Hi George
george
Dear @igorpadykov
Thank you very much for your reply.
I see, I will try coding with reference to the SDK.
*Please let me know if you find any other better way.
BR,
George.
