How to calculate real time consumption for gpu_memory(i.mx53 board)
1,429 次查看
zhangyinhua
     I have a problem encountered in the project.
     I doubt if there is enough space in my gpu memory,so I need to calculate the gpu memory (real-time).
     I want to  know how many gpu memory have been used in real-time
     Thanks.
标签 (3)
标记 (1)
1,269 次查看
maxmustermann
BIG FAT WARNING:
Do NOT use the proprietary kernel / kgsl stuff. It's full of horrible security bugs and broken by design.
It gives the userland *FULL PHYSICAL* bus access - there's *NO SECURITY* anymore !
[imx53] WARNING! Do NOT use the proprietary GPU drivers / KGSL stuff - MAJOR RISK!
1,269 次查看
Hi Zhang
one can look at gpu memory usage document
Re: imx53qsb amd-gpu(amd z430) minimum memory requirement.
though I doubt if it is possible to have gpu memory usage in real-time.
