Hi all,
We're trying to burn sd image which is implemented in MCIMX8M-EVKB by uuu on Windows 10.
We found some command to burn image to eMMC but can't find any info about burn sd card.
Could you tell us how to burn sd image by uuu on Windows 10 ?
Ko-hey
Solved! Go to Solution.
try to use the command like :
"uuu.exe -b sd_all imx-boot-imx8mqevk-sd.bin-flash_evk imx-image-full-imx8mqevk.sdcard"
this is just an example, you can replace the image name you need
