Hi Support,
We have checked MFG_TOOL , and found the tool can write uboot into flash. Would you please let us know how to burn kernel and file system into flash ?
=== below are uci2.xml used to burn uboot into flash ===
<CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mtd0 bs=1k seek=4" ifdev="MX6SX MX6UL MX6ULL">write U-Boot to NOR flash</CMD>
<CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mtd0 bs=1k seek=1" ifdev="MX7D">write U-Boot to NOR flash</CMD>
<!--QSPI header-->
<CMD state="Updater" type="push" body="send" file="qspi-header.sh.tar">Sending qspi header shell</CMD>
<CMD state="Updater" type="push" body="$ tar xf $FILE "> Extracting...</CMD>
<CMD state="Updater" type="push" body="send" file="files/%norconfig%">Sending QSPI header config file</CMD>
<CMD state="Updater" type="push" body="$ sh qspi-header.sh $FILE"> Generating the ascii value header</CMD>
<!--hexdump to convert ascii value to hex file-->
<CMD state="Updater" type="push" body="$ busybox hexdump -R qspi-tmp > qspi-header">Converting ascii value to hex file</CMD>
<CMD state="Updater" type="push" body="$ dd if=qspi-header of=/dev/mtd0 bs=1k seek=1" ifdev="MX6SX MX6UL MX6ULL">Writing header to NOR flash</CMD>
<CMD state="Updater" type="push" body="$ dd if=qspi-header of=/dev/mtd0 bs=1k seek=0" ifdev="MX7D">Writing header to NOR flash</CMD>
<!--delete temporary files-->
<CMD state="Updater" type="push" body="$ rm qspi-tmp">Deleting temporary file</CMD>
<CMD state="Updater" type="push" body="$ rm qspi-header">Deleting temporary file</CMD>
<CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
Steven Yu
