How to burn in images for i.MX 8QuadXPlus MEK and boot it ?
tangl
Looking forward to your help.
Rita_Wang
Are you using linux or android BSP?Here you can use the uuu tool to download. If you are first use you can see Get Started with the MCIMX8QXP-CPU | NXP  to boot up the board. Or you can see the user guide documents you can download here i.MX 8QuadXPlus Multisensory Enablement Kit | NXP
tangl
It happens a issue that shows "LIBUSB_ERROR_IO", How should l do with it?QQ图片20200323140639.png
Rita_Wang
Does the usb diver install on your PC?
tangl
l got a new board and its cpu is imx8qxp, which is different from the imx8qxp-mek and based on 2G LPDDR4 and 16G eMMC. Can l burn the same bootloader as the  imx8qxp-mek in the new board?
Rita_Wang
Do you know the difference between these two boards? The prebuild images in our website is for nxp reference board. If your board is not the one, you can not directly use. Here if you bought the board from third company you can contact them. Or if you design the board yourself you need to do porting the BSP towards its hardware.
tangl
I would like to get more details on porting the BSP, plz.
Rita_Wang
I do not know which version of BSP are you uising, you can see our porting guide. You can download documents here Embedded Linux for i.MX Applications Processors | NXP
