How to build imx-boot image file for i.MX8M Mini ECSPI?
4,705 次查看
m_c
Senior Contributor I
Since the image vector table offset is different of FlexSPI (QSPI) and ECSPI.
How to build imx-boot image for ECSPI like imx-boot-imx8mmevk-fspi.bin-flash_evk_flexspi for QSPI by Linux yocto BSP?
4,071 次查看
Hi m.c.
one can build in the same way as emmc (also 0x400 offset), use
sect.4.5.12 How to build U-Boot, sect.4.5.13 How to build imx-boot
attached Linux Guide. Other useful tutorial:
https://developer.solid-run.com/knowledge-base/i-mx8m-atf-u-boot-and-linux-kernel/
4,072 次查看
Hi m.c.
