How to build an Android image for the SD card on the SABRE-SD
Harris
Dears,
According to the Android_User's_Guide, I have build the android_N7.1.2_2.0.0 image successful. Now I want to build an Android image for the SD card on the SABRE-SD.
I executed following commands according to the 3.3.3 chapter in  Android_User's_Guide.
1. Remove /out/target/product/sabresd_6dq/root directory and boot*.img.
2. Remove /out/target/product/sabresd_6dq/recovery directory and recovery*.img.
make bootimage BUILD_TARGET_DEVICE=sd
The system tips that make: *** No rule to make target. Stop.
I followed the Android_User's_Guide step by step. Would you please explain this problem and help to fix it.
Thanks.
Harris li
weidong_sun
Hi Harris,
   Before running "make bootimage BUILD_TARGET_DEVICE=sd", run below commands, please!
$ cd ~/myandroid
$ source build/envsetup.sh
$ lunch sabresd_6dq-user
Have a nice day!
BR,
Weidong Sun
