How to build Yocto project image
21,882 次查看
petertseng
Hi i.MX Community,
I download  Freescale Yocto Project:
$ mkdir fsl-release-bsp
$ cd fsl-release-bsp
$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
$ repo sync
I need to build an image that does not used GUI or QT5.
But the document (Freescale_Yocto_Project_User's_Guide.pdf) only provides how to build X11 and QT5 image.
How to build a sample image?  (like core-image-minimal or core-image-base)
Hope for your help!
13,722 次查看
anjojohn
Hi Peter,
After "bitbake u-boot" command, Is the u-boot binary
(u-boot-imx6qsabresd.imx) present in build/tmp/deploy//images ?
And the emmc configuration for u-boot is it present ?
18 回复数
13,722 次查看
lilleli
Hi i.MX Community,
 I build yocto image ,below erro!
bitbake core-image-minimal
Loading cache: 100% |############################################| Time: 0:00:02
Loaded 3049 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.32.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-14.04"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "imx6ull14x14evk"
DISTRO = "fsl-imx-x11"
DISTRO_VERSION = "4.9.11-1.0.0"
TUNE_FEATURES = "arm armv7ve vfp thumb neon callconvention-hard cortexa7"
TARGET_FPU = "hard"
meta
meta-poky = "HEAD:78890ea22750804e3e9113e76f7ca3d7234c8342"
meta-oe
meta-multimedia = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e"
meta-freescale = "HEAD:a398b50b7fc084a9e68cc3000c218d5028522a25"
meta-freescale-3rdparty = "HEAD:68314612e236cab1da82d72a0da62635a3523f84"
meta-freescale-distro = "HEAD:cd5c7a2539f40004f74126e9fdf08254fd9a6390"
meta-bsp
meta-sdk = "HEAD:daba3340ecd8b358e0c6c415baeee0fcae95c525"
meta-browser = "HEAD:10f6e3778d823ee1be106c126216c6f941088fbf"
meta-gnome
meta-networking
meta-python
meta-filesystems = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e"
meta-qt5 = "HEAD:ff073f04109900fc07bf81e2f1df63c626caf342"
Initialising tasks: 100% |#######################################| Time: 0:00:04
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: util-linux-native-2.28.1-r0 do_compile: oe_runmake failed
ERROR: util-linux-native-2.28.1-r0 do_compile: Function failed: do_compile (log file is located at /home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/temp/log.do_compile.7660)
ERROR: Logfile of failure stored in: /home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/temp/log.do_compile.7660
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 1 ARCH=x86_64 CPU= CPUOPT= OPT=-isystem/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe
| ERROR: oe_runmake failed
| make all-recursive
| make[1]: Entering directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build'
| Making all in po
| make[2]: Entering directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build/po'
| make[2]: Nothing to be done for `all'.
| make[2]: Leaving directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build/po'
| make[2]: Entering directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build'
| gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I../util-linux-2.28.1 -include config.h -I../util-linux-2.28.1/include -DLOCALEDIR=\"/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/sysroots/x86_64-linux/usr/share/locale\" -D_PATH_LOCALSTATEDIR=\"/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/sysroots/x86_64-linux/var\" -isystem/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/sysroots/x86_64-linux/usr/include -fsigned-char -fno-common -Wall -Werror=sequence-point -Wextra -Wmissing-declarations -Wmissing-parameter-type -Wmissing-prototypes -Wno-missing-field-initializers -Wredundant-decls -Wsign-compare -Wtype-limits -Wuninitialized -Wunused-but-set-parameter -Wunused-but-set-variable -Wunused-parameter -Wunused-result -Wunused-variable -Wnested-externs -Wpointer-arith -Wstrict-prototypes -Wformat-security -Wimplicit-function-declaration -isystem/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -c -o schedutils/chrt.o ../util-linux-2.28.1/schedutils/chrt.c
| In file included from /usr/include/x86_64-linux-gnu/sys/syscall.h:31:0,
| from ../util-linux-2.28.1/schedutils/chrt.c:63:
| ../util-linux-2.28.1/schedutils/chrt.c: In function ‘sched_setattr’:
| ../util-linux-2.28.1/schedutils/chrt.c:88:17: error: ‘__NR_sched_setattr’ undeclared (first use in this function)
| return syscall(SYS_sched_setattr, pid, attr, flags);
| ../util-linux-2.28.1/schedutils/chrt.c:88:17: note: each undeclared identifier is reported only once for each function it appears in
| ../util-linux-2.28.1/schedutils/chrt.c: In function ‘sched_getattr’:
| ../util-linux-2.28.1/schedutils/chrt.c:93:17: error: ‘__NR_sched_getattr’ undeclared (first use in this function)
| return syscall(SYS_sched_getattr, pid, attr, size, flags);
| ../util-linux-2.28.1/schedutils/chrt.c:89:1: warning: control reaches end of non-void function [-Wreturn-type]
| ../util-linux-2.28.1/schedutils/chrt.c:94:1: warning: control reaches end of non-void function [-Wreturn-type]
| make[2]: *** [schedutils/chrt.o] Error 1
| make[2]: Leaving directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build'
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory `/home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/build'
| make: *** [all] Error 2
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/fsl/fsl-release-bsp/fsl-release-bsp/build-gateway/tmp/work/x86_64-linux/util-linux-native/2.28.1-r0/temp/log.do_compile.7660)
ERROR: Task (virtual:native:/home/fsl/fsl-release-bsp/fsl-release-bsp/sources/poky/meta/recipes-core/util-linux/util-linux_2.28.1.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 621 tasks of which 606 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
13,723 次查看
petertseng
Hi John,
I get the following error after execution.
$ source setup-environment build
$ bitbake core-image-minimal
WARNING: Unable to get checksum for linux-toradex SRC_URI entry defconfig: file could not be found00:00:00
Parsing recipes: 100% |###################################################################| Time: 00:00:58
Parsing of 1689 .bb files complete (0 cached, 1689 parsed). 2214 targets, 163 skipped, 0 masked, 0 errors.
BB_VERSION = "1.28.0"
MACHINE = "imx6qsabresd"
DISTRO = "poky"
DISTRO_VERSION = "2.0.1"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9"
TARGET_FPU = "vfp-neon"
meta
meta-yocto = "HEAD:dd0ba9ea4a11ab15348d4fe3574e4b28784db82f"
meta-oe
meta-multimedia = "HEAD:ad6133a2e95f4b83b6b3ea413598e2cd5fb3fd90"
meta-fsl-arm = "HEAD:35b8b9bd9863de208ab60e33b55f10ee43e2619b"
meta-fsl-arm-extra = "HEAD:e200df91b70da254461c59082ddd5db0a3c415a2"
meta-fsl-demos = "HEAD:2231e946e7a94d096394f2b2477e8184c9bbde7b"
NOTE: Preparing RunQueue
WARNING: Failed to fetch URL ftp://invisible-island.net/ncurses/current/ncurses-5.9-20150329.tgz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://zlib.net/pigz/pigz-2.3.3.tar.gz, attempting MIRRORS if available
ERROR: Error: The image creation script '/home/peter/workspace/fsl-release-bsp/build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/create_image.sdcard' returned 1:
0+0 records in
0+0 records out
0 bytes (0 B) copied, 6.3969e-05 s, 0.0 kB/s
Model: (file)
Disk /home/peter/workspace/fsl-release-bsp/build/tmp/deploy/images/imx6qsabresd/core-image-minimal-imx6qsabresd-20161102062918.rootfs.sdcard: 25.2MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 4194kB 12.6MB 8389kB primary lba
2 12.6MB 21.0MB 8389kB primary
dd: failed to open '/home/peter/workspace/fsl-release-bsp/build/tmp/deploy/images/imx6qsabresd/u-boot-imx6qsabresd.imx': No such file or directory
ERROR: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/peter/workspace/fsl-release-bsp/build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs.41335
ERROR: Task 7 (/home/peter/workspace/fsl-release-bsp/sources/poky/meta/recipes-core/images/core-image-minimal.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1882 tasks of which 9 didn't need to be rerun and 1 failed.
No currently running tasks (1882 of 1883)
Summary: There were 3 WARNING messages shown.
Peter Tseng
13,723 次查看
anjojohn
please check if the u-boot image has been build under the directory
Have you modified the core-image-minimal.bb file ? please list the modification if had done any
13,723 次查看
petertseng
Hi John,
The UBOOT is not in this directory (build/tmp/deploy/images/).
I have added in local.conf file:
UBOOT_CONFIG = "emmc"
13,723 次查看
anjojohn
Please build the u-boot, "bitbake u-boot".
has the "emmc" configuration for uboot is present ?
13,723 次查看
petertseng
Hi John,
There are still some errors.
$ bitbake u-boot
Loading cache: 100% |#####################################################################| ETA: 00:00:00
Loaded 2215 entries from dependency cache.
DISTRO = "poky"
meta
meta-oe
NOTE: Tasks Summary: Attempted 372 tasks of which 372 didn't need to be rerun and all succeeded.
DISTRO = "poky"
meta
meta-oe
0+0 records in
0+0 records out
0 bytes (0 B) copied, 5.5098e-05 s, 0.0 kB/s
Model: (file)
Disk /home/peter/workspace/fsl-release-bsp/build/tmp/deploy/images/imx6qsabresd/core-image-minimal-imx6qsabresd-20161103015104.rootfs.sdcard: 25.2MB
Disk Flags:
ERROR: Logfile of failure stored in: /home/peter/workspace/fsl-release-bsp/build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs.3106
NOTE: Tasks Summary: Attempted 1882 tasks of which 1881 didn't need to be rerun and 1 failed.
No currently running tasks (1881 of 1883)
13,723 次查看
anjojohn
Hi Peter,
13,723 次查看
petertseng
Hi John,
After I removed
get the following results
$ bitbake u-boot
Parsing recipes: 100% |###################################################################| Time: 00:00:37
DISTRO = "poky"
meta
meta-oe
NOTE: Tasks Summary: Attempted 372 tasks of which 363 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
DISTRO = "poky"
meta
meta-oe
NOTE: Tasks Summary: Attempted 1883 tasks of which 1881 didn't need to be rerun and all succeeded.
But in the "build/tmp/deploy/images/" directory does not UBOOT image.
13,723 次查看
anjojohn
Your build is complete. I guess the u-boot configuration for emmc is not
present.
u-boot binary is in your "build/tmp/deploy/<machine-name>/images"
directory
13,723 次查看
petertseng
Hi John,
I found the U-BOOT image link file in this path:
build/tmp/deploy/images/imx6qsabresd/u-boot.imx
If I want to recompile it also need to download from the Internet?
13,723 次查看
anjojohn
No need to download again. The downloaded source will be in your download/ directory. No internet will be needed after first compilation.
For cleaning
 bitbake -c clean u-boot
or
bitbake-c cleansstate uboot
Then make the u-boot again.
13,723 次查看
petertseng
Hi John,
If I successfully build the image file in the ubuntu 14.04.1  machine needs to execute command:
    $ bitbake u-boot
Now, I can successfully build the image file in the ubuntu 14.04.4 machine.
But I do not need additional execute this command.
What is the difference between these two ubuntu versions?
Which version do you recommend to build?
13,723 次查看
anjojohn
Hi Peter,
There is no difference, the first command
bitbake u-boot
tells bitbake to make only u-boot, no other packages. This command is used
when you want to recompile u-boot after some modification.
On the other hand bitbkake core-image-minimal tells bitbake to make a
target which is an entire working build including u-boot, kernel and rootfs
with programs.
u-boot is a recipe and core-image-minimal is a target name.
13,723 次查看
anjojohn
Hi Peter,
Please see the .bb files for core-image-minimal and fsl-image-multimedia.
make a new target image with your name project name. Inherit the core-image-minimal bb file and add your additional packages through "CORE_IMAGE_EXTRA_INSTALL" or adding those to the local.conf file in your build directory.
13,723 次查看
petertseng
Hi John,
Can you please provide a detailed method of operation?
13,723 次查看
anjojohn
Hi Peter,
In my target bb file i have like
inherit core-image
CORE_IMAGE_EXTRA_INSTALL += " \
packagegroup-fsl-gstreamer \
packagegroup-fsl-tools-gpu \
packagegroup-fslc-gstreamer1.0 \
this will not contain the x11 or wayland. please take a look at the
meta-fsl-demos/recipes-fsl/images/fsl-image-multimedia.bb
13,721 次查看
petertseng
Hi John,
Where is the .bb files for core-image-minimal and fsl-image-multimedia?
13,721 次查看
anjojohn
sources/meta-fsl-demos/recipes-fsl/images/fsl-image-multimedia.bb
