How to build OpenVG programs and run them on i.MX8MPlus
guo-ho
I found some example code on GitHub(https://github.com/nxp-imx/gtec-demo-framework/tree/master/DemoApps/OpenVG ) related to OpenVG, but I'm not sure how to integrate it with the SDK for i.MX8M Plus. If you have instructions or resources on how to build and run this sample code on the i.MX8M Plus platform, I would appreciate it.
Sanket_Parekh
Hi @guo-ho,
I hope you are doing well
One can take the reference of the imx-gpu-sdk. The OpenVG programs are integrated into the same.
The reference built can be downloaded from the below link.
Thanks & Regards,
Sanket Parekh
