How to build Ltib with hard float
2,820 次查看
zhenghuyu
when I build ltib with setting -mfloat-abi=hard  in config, I get the error msg: -mfloat-abi=soft and -mfloat-abi=hard may not be used together.
so how to build ltib with hard float
4 回复数
2,485 次查看
Hi zhenghu
one can follow attached document from ltib note i.MX has not fpu, only neon.
2,485 次查看
zhenghuyu
I can not find where the flag  -mfloat-abi=soft has been set。I only set the c compile flag   -mfloat-abi=hard
and the u-boot builds successfully  but the kernel doesn't and show the error message
2,485 次查看
2,485 次查看
zhenghuyu
Can you give me some more detail instrutions?
