How to boot wince7.0 from nandflash on imx6q
2,173件の閲覧回数
leoyanfeng
Hello everybody:
     I want to boot wince7.0 from nandflash on my imx6 board.Now,my board can boot from SD,and then write fcb,dbbt and eboot.nb0 to nandflash.But when switching to boot from nandflash,the board can't boot.The waveforms of date0 and data7 are absolutely same.When boot from SD,read\write\formt nandflash operations are ok.The flash is K9F2G08U0C.SLC(2048+64).Anybody can help me.Thank you.
     PS:some questions about fcb:
     1.when writing fcb,ecc need to be enable or not?
     2.In imx28 refence manual,there is 12 bytes offset before fcb.The offset is needed in imx6?And Is the offset including meta data?
     Sorry for my poor english.
1,968件の閲覧回数
leoyanfeng
Hi everybody:
     Everything is ok now.The device can boot from nandflash now.
     1.FCB data(There are 12 bytes offset at the beginning of databug.When ecc is disable, there is no metadata.Firstly,gpmi  write pagebuf to nand and secondly write auxbuf.
        When ecc is enable,gpmi  write  auxbuf to nand firstly.)
        00 00 00 00 00 00 00 00  00 00 00 00 05 fb ff ff
        46 43 42 20 00 00 00 01  50 3c 19 06 00 00 00 00
        00 08 00 00 40 08 00 00  40 00 00 00 00 00 00 00
        00 00 00 00 00 00 00 00  04 00 00 00 00 02 00 00
        00 02 00 00 04 00 00 00  0a 00 00 00 03 00 00 00
        00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
        00 00 00 00 00 02 00 00  00 41 00 00 cc 00 00 00
        cc 00 00 00 00 01 00 00  cf 07 00 00 00 00 00 00
        00 08 00 00 00 00 00 00  00 00 00 00 00 00 00 00
        00 00 00 00 00 00 00 00  00 00 00 00 0f 15 06 06
        10 1f 03 07 00 00 00 1c  0f 17 1f 05 00 00 00 00
        00 19 00 00 15 19 00 00  15 00 00 00 00 00 00 00
        00 00 00 00 00 00 00 00  13 00 00 00 00 16 00 00
        00 16 00 00 13 00 00 00  0f 00 00 00 0a 00 00 00
        00 00 00 00 00 16 00 00  00 09 00 00 11 00 00 00
        11 00 00 00 00 1c 00 00  1b 19 00 00 00 00 00 00
        00 19 00 00 00 00 00 00  00 00 00 00 00 00 00 00
OOB:
        ff ff ff ff ff ff ff ff
         2.dbbt:
         bold data is metadata.10 bytes.Ecc is enable now.
        00 ff ff ff ff ff ff ff  ff ff              00 00 00 00 44 42
        42 54 00 00 00 01 00 00  00 00 01 00 00 00 00 00
        00 00 00 00 00 00 00 00  00 00 c3 c9 0f f0 55 65
        1c 05 7d d8 fa dd e6 00  00 00 00 00 00 00 00 00
OOB:
        ff 00 00 00 00 00 00 00
        00 92 2a bd 77 36 7e e7
        bd 28 20 22 28 92 00 00
        3.You should cut the first 4K data in eboot.nb0 if the eboot.nb0 has rom signature.Then you should add 1k padding to the eboot.nb0 for IVT.
        4.You can find more information from the imx50's bsp.
         Thanks.
4 返答(返信)
1,969件の閲覧回数
leoyanfeng
Hi everybody:
OOB:
         2.dbbt:
OOB:
         Thanks.
1,968件の閲覧回数
Hi leo
for analyzing fcb one can write eboot to nand using kobs-ng tool, it automatically write
fcb to necessary place to nand. Use mfg tools from one of i.MX6 product
pages (replace uboot with eboot) and use profiles for Sabre-AI board
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=RDIMX6SABREBRD&fpsp=1&tab=Design_Tool...
1. regarding ecc, according to sect.8.5.2.2 NAND Flash Boot Flow and
    Boot Control Blocks (BCB) i.MX6DQ Reference Manual (rev.3  7/2015)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
The hardware ECC level to use is embedded inside FCB block. The FCB data structure is
also protected using ECC. Driver reads raw 2112 bytes of first sector and runs through
software ECC engine that determines whether FCB data is valid or not.
2. FCB is the first sector in the first good block. (sect.8.5.2.3 RM)
1,968件の閲覧回数
leoyanfeng
Hi igor:
     Thanks for you reply.
     I can write uboot to nand with mfgtool.And My board can boot from nand now.
     But when replacing uboot with eboot,the board can not boot.
     I dump the data in nandflash and have some questions.
     1.The layout of nand dump data is real layout in nandflash.Is it right?
     2.When ecc is disable,there is no metadata.The driver write 2048 bytes to nandflash.
     3.Is the oob area last 64 bytes in nandflash?
     4.where are the logic address data used by filesystem written to?
=> nand info
Device 0: nand0, sector size 128 KiB
  Page size      2048 b
  OOB size         64 b
  Erase size   131072 b
=> nand device
  Page size      2048 b
  OOB size         64 b
  Erase size   131072 b
=> nand dump 0
Page 00000000 dump:
OOB:
nand: device found, Manufacturer ID: 0xec, Chip ID: 0xda
nand: Samsung NAND 256MiB 3,3V 8-bit
nand: 256MiB, SLC, page size: 2048, OOB size: 64
Bad block table not found for chip 0
Scanning device for bad blocks
Bad eraseblock 394 at 0x000003140000
Bad eraseblock 562 at 0x000004640000
Bad eraseblock 954 at 0x000007740000
Bad eraseblock 1380 at 0x00000ac80000
Bad eraseblock 1663 at 0x00000cfe0000
Bad eraseblock 1682 at 0x00000d240000
Bad block table written to 0x00000ffe0000, version 0x01
Bad block table written to 0x00000ffc0000, version 0x01
4 cmdlinepart partitions found on MTD device gpmi-nand
Creating 4 MTD partitions on "gpmi-nand":
0x000000000000-0x000004000000 : "boot"
0x000004000000-0x000005000000 : "kernel"
0x000005000000-0x000006000000 : "dtb"
0x000006000000-0x000010000000 : "rootfs"
gpmi-nand 112000.gpmi-nand: driver registered.
fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unregistered net_device): Using random MAC address: ae:27:a1:6e:83:d2
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
egalax_ts 0-0004: Failed to read firmware version
egalax_ts: probe of 0-0004 failed with error -110
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video19
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video20
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Galcore version 5.0.11.25762
th=/dev/mtd0 $FILE"
MTD CONFIG:
  chip_0_device_path = "/dev/mtd0"
  chip_1_device_path = "(null)"
  search_exponent = 2
  data_setup_time = 80
  data_hold_time = 60
  address_setup_time = 25
  data_sample_time = 6
  row_address_size = 3
  column_address_size = 2
  read_command_code1 = 0
  read_command_code2 = 48
  boot_stream_major_version = 1
  boot_stream_minor_version = 0
  boot_stream_sub_version = 0
  ncb_version = 3
  boot_stream_1_address = 0
  boot_stream_2_address = 0
-- We add the 1k-padding to the uboot.
.tmp_kobs_ng: verifying using key '00000000000000000000000000000000'
.tmp_kobs_ng: is a valid bootstream for key '00000000000000000000000000000000'
mtd: opening: "/dev/mtd0"
mtd: '/dev/mtd0' bad block @ 0x3140000 (MTD)
NFC geometry :
        ECC Strength       : 8
        Page Size in Bytes : 2112
        Metadata size      : 10
        ECC Chunk Size in byte : 512
        ECC Chunk count        : 4
        Block Mark Byte Offset : 1999
        Block Mark Bit Offset  : 0
mtd: opened '/dev/mtd0' - '(null)'
mtd: max_boot_stream_size_in_bytes = 33030144
mtd: boot_stream_size_in_bytes = 417792
mtd: boot_stream_size_in_pages = 204
mtd: #1 0x00100000 - 0x02080000 (0x00166000)
mtd: #2 0x02080000 - 0x04000000 (0x020e6000)
FCB
  m_u32Checksum = 0x00000000
  m_u32FingerPrint = 0x20424346
  m_u32Version = 0x01000000
  m_NANDTiming.m_u8DataSetup = 80
  m_NANDTiming.m_u8DataHold = 60
  m_NANDTiming.m_u8AddressSetup = 25
  m_NANDTiming.m_u8DSAMPLE_TIME = 6
  m_u32PageDataSize = 2048
  m_u32TotalPageSize = 2112
  m_u32SectorsPerBlock = 64
  m_u32NumberOfNANDs = 0
  m_u32TotalInternalDie = 0
  m_u32CellType = 0
  m_u32EccBlockNEccType = 4
  m_u32EccBlock0Size = 512
  m_u32EccBlockNSize = 512
  m_u32EccBlock0EccType = 4
  m_u32MetadataBytes = 10
  m_u32NumEccBlocksPerPage = 3
  m_u32EccBlockNEccLevelSDK = 0
  m_u32EccBlock0SizeSDK = 0
  m_u32EccBlockNSizeSDK = 0
  m_u32EccBlock0EccLevelSDK = 0
  m_u32NumEccBlocksPerPageSDK = 0
  m_u32MetadataBytesSDK = 0
  m_u32EraseThreshold = 0
  m_u32Firmware1_startingPage = 512
  m_u32Firmware2_startingPage = 16640
  m_u32PagesInFirmware1 = 204
  m_u32PagesInFirmware2 = 204
  m_u32DBBTSearchAreaStartAddress = 256
  m_u32BadBlockMarkerByte = 1999
  m_u32BadBlockMarkerStartBit = 0
  m_u32BBMarkerPhysicalOffset = 2048
  m_u32BCHType = 0
  m_NANDTMTiming.m_u32TMTiming2_ReadLatency = 0
  m_NANDTMTiming.m_u32TMTiming2_PreambleDelay = 0
  m_NANDTMTiming.m_u32TMTiming2_CEDelay = 0
  m_NANDTMTiming.m_u32TMTiming2_PostambleDelay = 0
  m_NANDTMTiming.m_u32TMTiming2_CmdAddPause = 0
  m_NANDTMTiming.m_u32TMTiming2_DataPause = 0
  m_NANDTMTiming.m_u32TMSpeed = 0
  m_NANDTMTiming.m_u32TMTiming1_BusyTimeout = 0
  m_u32DISBBM = 0
  m_u32BBMarkerPhysicalOffsetInSpareData = 0
DBBT
  m_u32FingerPrint = 0x54424244
  m_u32DBBTNumOfPages = 1
BBTN#0
  uNAND = 0
  uNumberBB = 1
  BADBLOCKS:
     0x18a
Firmware: image #0 @ 0x100000 size 0x66000 - available 0x1f80000
Firmware: image #1 @ 0x2080000 size 0x66000 - available 0x1f80000
-------------- Start to write the [ FCB ] -----
mtd: erasing @0:0x0-0x20000
mtd: Writing FCB0 [ @0:0x0 ] (840) *
mtd: erasing @0:0x20000-0x40000
mtd: Writing FCB1 [ @0:0x20000 ] (840) *
mtd: erasing @0:0x40000-0x60000
mtd: Writing FCB2 [ @0:0x40000 ] (840) *
mtd: erasing @0:0x60000-0x80000
mtd: Writing FCB3 [ @0:0x60000 ] (840) *
mtd_commit_bcb(FCB): status 0
-------------- Start to write the [ DBBT ] -----
mtd: erasing @0:0x80000-0xa0000
mtd: Writing DBBT0 [ @0:0x80000 ] (800) *
mtd: erasing @0:0xa0000-0xc0000
mtd: Writing DBBT1 [ @0:0xa0000 ] (800) *
mtd: erasing @0:0xc0000-0xe0000
mtd: Writing DBBT2 [ @0:0xc0000 ] (800) *
mtd: erasing @0:0xe0000-0x100000
mtd: Writing DBBT3 [ @0:0xe0000 ] (800) *
mtd_commit_bcb(DBBT): status 0
mtd: PUTTING down DBBT0 BBTN0 @0x82000 (0x800)
mtd: PUTTING down DBBT1 BBTN0 @0xa2000 (0x800)
mtd: PUTTING down DBBT2 BBTN0 @0xc2000 (0x800)
mtd: PUTTING down DBBT3 BBTN0 @0xe2000 (0x800)
---------- Start to write the [ .tmp_kobs_ng ]----
mtd: Writting .tmp_kobs_ng: #0 @0: 0x00100000 - 0x00166000
mtd: erasing @0:0x100000-0x120000
mtd: erasing @0:0x120000-0x140000
mtd: erasing @0:0x140000-0x160000
mtd: erasing @0:0x160000-0x180000
mtd: We write one page for save guard. *
mtd: Writting .tmp_kobs_ng: #1 @0: 0x02080000 - 0x020e6000
mtd: erasing @0:0x2080000-0x20a0000
mtd: erasing @0:0x20a0000-0x20c0000
mtd: erasing @0:0x20c0000-0x20e0000
mtd: erasing @0:0x20e0000-0x2100000
UTP: sending Success to kernel for command $ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE.
utp_poll: pass returned.
UTP: received command '$ echo Update Complete!'
UTP: executing "echo Update Complete!"
Update Complete!
UTP: sending Success to kernel for command $ echo Update Complete!.
1,968件の閲覧回数
