How to boot i.MX6 from iSSD Card
2,186 次查看
RobMauro
Hello All,
Does anyone have experience or tips for booting an i.MX6 from a Sandisk iSSD card?  I'm doing development on the Boundary Devices Nitrogen6X SOM but will eventually spin a discrete design.  I would like to use the iSSD card with both.  Any help would be greatly appreciated.  The OS is Linux.
标签 (2)
1 回复
1,764 次查看
xinyu_chen
Hi Rob
What's the interface of i.MX6 for your iSSD used? SATA?
If so, you gotta to change the boot pin to SATA, and download uboot to SSD with offset of 1K same as SD/eMMC.
Almost the same as boot from eMMC/SD
