How to apply weston 2.0.0 to i.MX6 ?
huhyangjae
Hello. I'm using i.mx6 quad, and I'm building the file system via Yocto.
I was tried repo init -u git: //git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga -m imx-4.1.15-1.1.2.xml and Qt 5.8 build was a success. However, wayland version is 1.9.0 and weston version is 1.9.0.
I want  for wayland version 1.9.0 or later, and weston version 2.0.0.
I find it necessary to modify the wayland folder in recipes-graphics in meta-fsl-bsp-release, but I do not know what to do. Please let me know if you have any links or links to helpful materials.
Bio_TICFSL
Hi Huh,
Since weston 2.0.0 changes EGL_KHR_swap_buffers and porting backends to new API for output setup, support for DRM_FORMAT_YUV444 buffers in the gl backend, I think this is going to change for new BSP do not recommend to change it.
huhyangjae
OK. Thanks for your reply.
